It's not clear to me that you need any design pattern -- at least not in the sense of the "Gang of Four" book.
From your description of the problem:
Every combination of arguments needs a different algorithm
what you need is some way to get from input -> output where input is "combination of arguments" and output is "algorithm". This is essentially just a hash table (or a function), in which:
- keys: some property of the specific arguments present
- values: algorithms (the exact implementation could be functions, objects, etc. depending on which language you're using and how convenient each choice is).
The second part of your problem -- "The .createBuffer method has required and optional arguments" -- isn't well-specified enough to give a sure answer, and will also depend on your choice of language. If your language supports optional arguments and default values, this problem nearly solves itself:
def createBuffer(self, radius, direction="outside")
If you're in Java, you can use reference types and check for null
, converting them to default values where necessary. Or even better, try this -- it helps clarify your intention to use nullable types to other programmers!
public void createBuffer(float radius, Optional<Direction> direction) {
if ( direction.isAbsent() ) {
direction = new Direction("outside");
As others mentioned, you could also throw the Builder pattern at it, but personally I wouldn't unless I was sure that I needed it, because a single method with a single type signature is simpler and easier to use.
