I often see the advice that you should try to make each library independent. And yet in reality I can never seem to achieve this. Is this BS advice or is it actually possibly in any realistic way?
Example: I write a 2D Vector library, I then use that to make a 2D collision library. I then build a 2D physics library that uses both the 2D Vector Library and the 2D Collision library. Am I seriously expected to figure out a way to make the physics library not depend on the other 2 libraries? Likely I'll eventually want to be able to serialize/deserialize the physics and collision data which will mean I'll want to make them further depend on some serialization library.
Another example: I have a string library with lots of string functions (think endsWith(str, ending)
and startsWith(str, start)
or whatever. I then write a templating library that uses my string library.
I rarely seem to be able to write a new library that doesn't use other libraries.
I could write interfaces and then write adaptors for all of those to attempt to decouple one library from another but it's unlikely to be performant and often the models of the different libraries mean that even if I could decouple with an interface trying to use a different library than the one originally decoupled will end up being impossible or massively non-performant.
So, is that original advice BS or is there some way to actually apply the advice in the real world?
