I read that virtual calls make the code slower than calling non-virtual ones in C#.
However, the IL instruction for both are the same callvirt
except in cases where base.somemethod()
is called.
So how does virtual method hurt performance?
is called.
You are making single mistake : thinking that IL code has effect on performance. The thing is, the machine code compiler can still do tons of optimizations based on the IL code itself. And it sure can differentiate between call of virtual and nonvirtual method, even if they use same opcode. This then results in different machine code and different performance.
Here is simple performance benchmark I did:
class ClassA
public int Func1(int a)
return a + 1;
public virtual int Func2(int a)
return a + 2;
class ClassB : ClassA
public override int Func2(int a)
return a + 3;
class Program
public static void Main()
int x = 0;
ClassA a = new ClassA();
ClassB b = new ClassB();
ClassA c = new ClassB();
Stopwatch watch = new Stopwatch();
watch.Start();
for (int i = 0; i < 10000000; i++)
x = x + 1; // no function
watch.Stop();
System.Console.WriteLine(watch.ElapsedTicks);
watch.Restart();
x = a.Func1(x); // non virtual
watch.Stop();
watch.Restart();
x = a.Func2(x); // virtual on a
watch.Stop();
watch.Restart();
x = b.Func2(x); // virtual on b
watch.Stop();
watch.Restart();
x = c.Func2(x); // virtual on B typed as A
watch.Stop();
System.Console.WriteLine(x); // so the compiler doesn't optimize it away
When I run it (Release, without debugging, Any CPU, .NET 4.5, x64 Windows 8.1) I get those results:
9904
8921
56921
60076
58289
First interesting thing is that calling the non-virtual method is no different than not using method at all. This clearly shows the compiler is inlining the method's code in place so there is no function call overhead. Second clearly shows that virtual methods don't have this inlining and add need of additional lookup. Making them much slower than non-virtual method calls.
But don't get the wrong idea. In the grand scheme of things, overhead caused by virtual methods is negligible compared to algorithm overhead and cache misses due to memory access.
As pointed out here, calling callvirt
is slower, but by a very small margin. I'm not sure how you're getting the CIL code, but as Eric Gunnerson points out, .NET never uses call
for instance classes. It always uses callvirt
, and he even states in a follow-up post that the difference in performance impact is minimum.
Just a very quick test, where all classes have a void PrintTest()
method (which only prints a message to the console)...
BaseVirtual
is a base class with the method defined as virtual
.DerivedVirtual
and DerivedVirtual2
use override
to redefine the virtual method, inheriting from BaseVirtual
.Base
is a regular class with a regular instance method (no virtual
or sealed
).Seal
is a sealed
class, just for the kicks.Stat
is a class with the method defined as static
.Here's the main code:
using System;
namespace CSharp
class Program
static void Main(string[] args)
BaseVirtual baseVirtual = new BaseVirtual();
DerivedVirtual derivedVirtual = new DerivedVirtual();
DerivedVirtual2 derivedVirtual2 = new DerivedVirtual2();
Base regularBase = new Base();
Seal seal = new Seal();
baseVirtual.PrintTest();
derivedVirtual.PrintTest();
derivedVirtual2.PrintTest();
regularBase.PrintTest();
seal.PrintTest();
Stat.PrintTest();
And, here's the CIL code:
.method private hidebysig static void Main(string[] args) cil managed
.entrypoint
// Code size 68 (0x44)
.maxstack 1
.locals init ([0] class CSharp.BaseVirtual baseVirtual,
[1] class CSharp.DerivedVirtual derivedVirtual,
[2] class CSharp.DerivedVirtual2 derivedVirtual2,
[3] class CSharp.Base regularBase,
[4] class CSharp.Seal seal)
IL_0000: newobj instance void CSharp.BaseVirtual::.ctor()
IL_0005: stloc.0
IL_0006: newobj instance void CSharp.DerivedVirtual::.ctor()
IL_000b: stloc.1
IL_000c: newobj instance void CSharp.DerivedVirtual2::.ctor()
IL_0011: stloc.2
IL_0012: newobj instance void CSharp.Base::.ctor()
IL_0017: stloc.3
IL_0018: newobj instance void CSharp.Seal::.ctor()
IL_001d: stloc.s seal
IL_001f: ldloc.0
IL_0020: callvirt instance void CSharp.BaseVirtual::PrintTest()
IL_0025: ldloc.1
IL_0026: callvirt instance void CSharp.BaseVirtual::PrintTest()
IL_002b: ldloc.2
IL_002c: callvirt instance void CSharp.BaseVirtual::PrintTest()
IL_0031: ldloc.3
IL_0032: callvirt instance void CSharp.Base::PrintTest()
IL_0037: ldloc.s seal
IL_0039: callvirt instance void CSharp.Seal::PrintTest()
IL_003e: call void CSharp.Stat::PrintTest()
IL_0043: ret
} // end of method Program::Main
Nothing too fancy, but this shows that only the static
method used call
Even so, I don't think this will really make a difference for most applications, so we shouldn't sweat on the small stuff and worry about this.
So, in conclusion, as the SO post states, you may get a performance hit because of the lookup the runtime needs to call the virtual methods. Compared to static methods, you get the overhead of callvirt
... Well, that was fun...
Since myself and others found the @Euphoric benchmark above illuminating, below is an expanded version that adds interfaces, lambdas, delegates and static. As one example, with .Net 4.5.2 and x86 output the result (in million iterations per seconds) consistently grouped into three buckets:
No function 1,388.9 MOps/s
Non-virtual 1,479.3 MOps/s
Static 1,201.9 MOps/s
Virtual via class 456.2 MOps/s
Overridden via class 425.9 MOps/s
Base class 394.3 MOps/s
Non-virtual via interface 357.4 MOps/s
Virtual via interface 466.0 MOps/s
Lambda 286.9 MOps/s
Delegate 277.6 MOps/s
Expanded benchmark:
using System;
using System.Diagnostics;
interface IClassA
int Func1(int a);
int Func2(int a);
class ClassA : IClassA
return a + 2;
return a + 2;
public static int StaticFunc(int a)
return a + 2;
return a + 2;
delegate int MyDelegate(int a);
class Program
static int forDelegate(int a)
return a + 2;
MethodCall();
public static void MethodCall()
const int loops = 500000000;
int x = 0;
Console.WriteLine("Method Call Overhead:");
watch.Start();
for (int i = 0; i < loops; i++)
x = x + 2;
watch.Stop();
Report("No function", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
watch.Restart();
x = a.Func1(x);
watch.Stop();
Report("Non-virtual", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
watch.Restart();
x = ClassA.StaticFunc(x);
watch.Stop();
Report("Static", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
watch.Restart();
x = a.Func2(x);
watch.Stop();
Report("Virtual via class", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
watch.Restart();
x = b.Func2(x);
watch.Stop();
Report("Overridden via class", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
watch.Restart();
x = c.Func2(x);
watch.Stop();
Report("Base class", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
IClassA iClassA = a;
watch.Restart();
x = iClassA.Func1(x);
watch.Stop();
Report("Non-virtual via interface", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
watch.Restart();
x = iClassA.Func2(x);
watch.Stop();
Report("Virtual via interface", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
Func<int, int> func = l => l + 2;
watch.Restart();
x = func(x);
watch.Stop();
Report("Lambda", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
MyDelegate myDelegate = forDelegate;
watch.Restart();
x = myDelegate(x);
watch.Stop();
Report("Delegate", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
System.Console.ReadKey();
static void Report(string message, int iterations, long milliseconds)
System.Console.WriteLine(string.Format("{0,-26:} {1,10:N1} MOps/s, {2,7:N3} s", message, (double)iterations / 1000.0 / milliseconds, milliseconds / 1000.0));
Hope it helps!
I was curious why Lambdas and Delegates performed so badly in the test of @Kristian Wedberg
I thought perhaps they should be called once before the test starts to make sure they are JITed, as that might distort the time.
In my test on .NET 4.6.1 and x86 the lambda consistently performs about as well as the interface calls, only the delegate was slower.
I then split the delegate test case in 3 to test different ways of creating the delegate:
Results:
No function 1.404,5 MOps/s, 0,356 s
Non-virtual 429,2 MOps/s, 1,165 s
Static 432,9 MOps/s, 1,155 s
Virtual via class 427,7 MOps/s, 1,169 s
Overridden via class 399,4 MOps/s, 1,252 s
Base class 363,6 MOps/s, 1,375 s
Non-virtual via interface 331,3 MOps/s, 1,509 s
Virtual via interface 337,2 MOps/s, 1,483 s
Lambda 339,4 MOps/s, 1,473 s
Delegate (inst. mthd grp) 338,5 MOps/s, 1,477 s
Delegate (stat. mthd grp) 204,0 MOps/s, 2,451 s
Delegate (lambda) 341,5 MOps/s, 1,464 s
Interestingly, 1) and 3) consistently perform as well as the lambda or interface tests, only 2) is slower (this was the version used in Kristian's test). I'm baffled as to why a static method of all things should be slower.
Here is the modified test:
using System;
using System.Runtime.CompilerServices;
interface IClassA {
int Func1(int a);
int Func2(int a);
class ClassA : IClassA {
[MethodImpl(MethodImplOptions.NoInlining)]
public int Func1(int a) {
return a + 2;
public virtual int Func2(int a) {
return a + 2;
public static int StaticFunc(int a) {
return a + 2;
class ClassB : ClassA {
public override int Func2(int a) {
return a + 2;
class Program {
static int staticDelegate(int a) {
return a + 2;
static Func<int, int> GetFunc() {
return l => l + 2;
public static void Main() {
MethodCall();
public static void MethodCall() {
int x = 0;
watch.Start();
for (int i = 0; i < loops; i++) {
x = x + 2;
watch.Stop();
x -= 2 * loops;
watch.Restart();
x = a.Func1(x);
watch.Stop();
x -= 2 * loops;
watch.Restart();
watch.Stop();
x -= 2 * loops;
watch.Restart();
x = a.Func2(x);
watch.Stop();
x -= 2 * loops;
watch.Restart();
x = b.Func2(x);
watch.Stop();
x -= 2 * loops;
watch.Restart();
x = c.Func2(x);
watch.Stop();
x -= 2 * loops;
watch.Restart();
watch.Stop();
x -= 2 * loops;
watch.Restart();
watch.Stop();
x -= 2 * loops;
Func<int, int> func = GetFunc();
x += func(0) - 2; // call once to JIT
watch.Restart();
x = func(x);
watch.Stop();
x -= 2 * loops;
MyDelegate myDelegate;
myDelegate = a.Func1;
x += myDelegate(0) - 2; // call once to JIT
watch.Restart();
x = myDelegate(x);
watch.Stop();
Report("Delegate (inst. mthd grp)", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
myDelegate = Program.staticDelegate;
watch.Restart();
x = myDelegate(x);
watch.Stop();
Report("Delegate (stat. mthd grp)", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
myDelegate = new MyDelegate(i => i + 2);
watch.Restart();
x = myDelegate(x);
watch.Stop();
Report("Delegate (lambda)", loops, watch.ElapsedMilliseconds);
x -= 2 * loops;
Console.ReadKey();
static void Report(string message, int iterations, long milliseconds) {
