There are a couple of differences. First, when a code executes GOTO, it gives up control, and there's no guarantee that it will regain control. A publisher in pub/sub, however, will keep running and performing its logic, sending off messages as appropriate. Its behavior is understandable and predicable.
Secondly, the subscriber will receive messages, and unlike with GOTO, the message itself carries context. Both the type of message, and any properties it carries, help tell the subscriber perform its role. And, after handling a message, the subscriber is still able to take new messages. So it's behavior too is understandable and predictable.
The big difference is that the publisher and subscriber have a well-defined flow of execution, and they will, in essence, keep looping and doing their jobs, while sending and receiving messages. Code with GOTOs can be well-written and orderly, but it can also degrade, and there isn't the same guarantee of clearly understood behavior.
You're right, though. Someone could write a pub/sub system with so many messages and so many little jumps that keeping track of the processing flow could become a nightmare. And on the other hand, you could write a system with GOTOs that behaves extremely orderly and is easily understood. (I'm thinking of assembly code for very complex systems before symbolic languages took over.)
But typically, the decoupling you gain from pub/sub simplifies the problem of distributed processing and decouples logic within your system. Also typically, straight-up GOTOs tend to create complicated systems where understanding the flow of control becomes problematic.
