20
The following Scala code works and can be passed to a Java method expecting a function. Is there a cleaner way to do this? Here's my first pass:
val plusOne = new java.util.function.Function[Int,Int] {
  override def apply(t:Int):Int = t + 1
  override def andThen[V](after:function.Function[_ >: Int, _ <: V]):
    function.Function[Int, V] = ???
  override def compose[V](before:function.Function[_ >: V, _ <: Int]):
    function.Function[V, Int] = ???
Here's my second pass - it uses a generic wrapper for the Java-8 Function interface to make the Scala syntax simpler:
// Note: Function1 is Scala's functional interface,
// Function (without the 1) is Java 8's.
case class JavaFunction1[U,V](f:Function1[U,V]) extends Function[U,V] {
  override def apply(t: U): V = f(t)
  override def compose[T](before:Function[_ >: T, _ <: U]):
    Function[T, V] = ???
  override def andThen[W](after:Function[_ >: V, _ <: W]):
    Function[U, W] = ???
val plusOne = JavaFunction1((x:Int) => x + 1)
val minusOne = JavaFunction1((x:Int) => x - 1)
Can we do better?
As a follow-up, is there any chance that Scala will someday use the invoke-dynamic op-code as Java 8 does for its first-class function application? Will that make everything magically work, or will there still need to be a syntactic conversion?
GlenPeterson
  • 14,890
  • 47
  • 75
You can make the conversion implicit:
implicit def toJavaFunction[U, V](f:Function1[U,V]): Function[U, V] = new Function[U, V] {
    Function[T, V] = toJavaFunction(f.compose(x => before.apply(x)))
    Function[U, W] = toJavaFunction(f.andThen(x => after.apply(x)))
implicit def fromJavaFunction[U, V](f:Function[U,V]): Function1[U, V] = f.apply
You shouldn't actually need to override compose and andThen, but maybe Scala compiler doesn't know about Java 8 default interface methods yet. (EDIT: it should work in 2.10.3.)
Also, you should be able to assign Scala lambdas (i.e. x => ...) to Function and any other SAM types in Scala 2.11, and Java 8 lambdas to Function1. (EDIT: this actually got added in Scala 2.12, not 2.11.)
Alexey Romanov
  • 1,467
  • `you should be able to assign Scala lambdas` - This means that, in Scala 2.11, a Scala function can be passed as an argument for a Java8 Lambda? – Kevin Meredith Nov 08 '16 at 02:36
  • Whether it can be passes as an _argument_ depends on the lambda's type; if it's e.g. `java.util.function.Consumer[scala.Function1[Integer, String]]` then it can be done before 2.11 too. – Alexey Romanov Nov 08 '16 at 06:31
