21
I'm somewhat new to programming (I'm a mechanical engineer by trade), and I'm developing a small program during my downtime that generates a (solidworks) part based on input from various people from around the plant.
Based on only a few inputs (6 to be exact), I need to make hundreds of API calls that can take up to a dozen parameters each; all generated by a set of rules I've gathered after interviewing everyone that handles the part. The rules and parameters section of my code is 250 lines and growing.
So, what is the best way to keep my code readable and manageable? How do I compartmentalize all my magic numbers, all the rules, algorithms, and procedural parts of the code? How do I deal with a very verbose and granular API?
My main goal is to be able to hand someone my source and have them understand what I was doing, without my input.
user2785724
  • 321
    Can you provide some examples of these API calls? – Robert Harvey Feb 17 '14 at 22:33
  • [The particular interface I'm dealing with right now](http://help.solidworks.com/2013/English/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.ISketchManager_members.html?id=0fff4c1631cd4337bc5f11b37837ca2f#Pg0) – user2785724 Feb 18 '14 at 13:48
  • "All problems in computer science can be solved by another level of indirection" -- [David Wheeler](http://en.wikipedia.org/wiki/David_Wheeler_%28computer_scientist%29) – Phil Frost Feb 18 '14 at 14:00
  • ...except too many levels of indirection :) – Dan Lyons Feb 18 '14 at 18:12
    It's hard to answer your question without seeing your code. You can post your code on http://codereview.stackexchange.com/ and get advice from other programmers. – Gilbert Le Blanc Feb 19 '14 at 02:16
7 Answers7
26
Based on what you describe, you're probably going to want to explore the wonderful world of databases. It sounds like many of the magic numbers you describe - particularly if they are part dependent - are really data, not code. You'll have much better luck, and find it far easier to extend the application in the long run, if you can categorize how the data relates to the parts and define a database structure for it.
Keep in mind, 'databases' don't necessarily mean MySQL or MS-SQL. How you store the data is going to depend a lot on how the program is used, how you are writing it, etc. It may mean an SQL type database, or it may simply mean a formatted text file.
GrandmasterB
  • 37,990
  • 78
  • 131
    Agreed with codifying the data in a database, although it does seem like he has larger problems. – Robert Harvey Feb 17 '14 at 22:34
  • If I were creating a program that makes completely different parts, yeah, this would be the way to go. It's only one part with four slightly different configurations, though. It will never be a huge thing (unless they hire a developer to make something like it, in which case it doesn't matter). Although, I guess it would be a great learning experience after I finished and wanted to refactor. – user2785724 Feb 18 '14 at 13:37
    Sounds like [soft coding](http://thedailywtf.com/Articles/Soft_Coding.aspx). Databases are for mutable state. Magic numbers are not mutable, by definition. – Phil Frost Feb 18 '14 at 14:03
    @PhilFrost: You can make them immutable. Just don't write to them after initial table creation. – Robert Harvey Feb 18 '14 at 14:16
  • @RobertHarvey sure, and you can implement the entire program in the database, too. That doesn't mean it's a good idea. If you are not going to change the numbers, then what's the point of putting them in a database? What's the difference between a database, and a static constant? Mutability. And, the database is a lot more complex, harder to deploy, harder to learn, more resource intensive... Look at *the* magic number program: [file](http://unixhelp.ed.ac.uk/CGI/man-cgi?file). Does it have a database? No, it just has [libmagic](http://linux.die.net/man/3/libmagic). – Phil Frost Feb 18 '14 at 14:22
    @PhilFrost: Well, I've now seen [the API](http://help.solidworks.com/2013/English/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.ISketchManager_members.html?id=0fff4c1631cd4337bc5f11b37837ca2f#Pg0) that he's dealing with. It is remarkable only for its sheer size. He may not need a database at all, unless he does. – Robert Harvey Feb 18 '14 at 14:25
  • @PhilFrost A database isnt 'hard to deploy'. As I say *very clearly* in my answer, it can be as simple as keeping the data in a text file. Remember, his question refers to a 'very large set' of magic numbers and rules. – GrandmasterB Feb 18 '14 at 16:59
  • @GrandmasterB I think if you had used "datastore" instead of "database", you might get a better reaction. – Tundey Feb 19 '14 at 15:01
  • @RobertHarvey: yes, the API is deservedly large and complex. It's doing complex things. It's got all the power of a 3D graphics API with a huge pile of extra functionality on top. The good news is that most things you can do in the program you can do through the API. The bad news is the same :) – Móż Feb 20 '14 at 04:51
14
Unless you anticipate extending this to multiple parts I'd be reluctant to add a database just yet. Having a database means a big pile of stuff to learn for you, and more stuff to install to get it to work for other people. Adding an embedded database keeps the final executable portable, but someone with your source code now has one more thing to get working.
I think a list of clearly named constants and rule-implementing functions will help a lot. If you give everything natural names and focus on literate programming techniques you should be able to make a readable program.
Ideally you'll end up with code that says:
LeftBearingHoleDepth = BearingWidth + HoleDepthTolerance;
if (not CheckPartWidth(LeftBearingHoleDepth, {other parameters})
    {whatever you need to adjust}
Depending on how local the constants are I'd be tempted to declare them in the functions they're used in where possible. It's quite useful to turn:
SomeAPICall(10,324.5, 1, 0.02, 6857);
into
const NumberOfOilDrainHoles = 10
const OilDrainHoleSpacing = 324.5
{etc}
SomeAPICall(NumberOfOilDrainHoles, OilDrainHoleSpacing, {etc}
That gives you largely self-documenting code and also encourages anyone who modifies the code to give similarly meaningful names to what they add. Starting local also makes it easier to deal with the total number of constants you'll accumulate. It gets a bit annoying if you have to keep scrolling through a long list of constants to make sure the value is the one you want.
One tip for names: put the most important word on the left. It may not read quite as well, but it makes finding things easier. Most of the time you're looking at a sump and wondering about the bolt, not looking at a bolt and wondering where it does, so call it SumpBoltThreadPitch not BoltThreadPitchSump. Then sort the list of constants. Later, to extract all the thread pitches you can get the list in a text editor and either use the find function, or use a tool like grep to return only the lines that contain "ThreadPitch".
Móż
  • 1,252
    also consider creating a Fluent interface – Ian Feb 18 '14 at 13:01
  • Here's an actual line from my code. Does it make sense what is going on here (arguments are x1,y1,z1,x2,y2,z2 as double), if you knew what the variable names meant? `.CreateLine(m_trunion_support_spacing / 2, -((m_flask_length / 2) + m_sand_ledge_width + m_wall_thickness), -m_flange_thickness, m_trunion_support_spacing / 2, -((m_flask_length / 2) + m_sand_ledge_width + m_wall_thickness), -m_flask_height + m_flange_thickness)` – user2785724 Feb 18 '14 at 13:40
  • You could also use [ctags](http://ctags.sourceforge.net/) with [editor integration](http://blog.stwrt.ca/2012/10/31/vim-ctags) to find the constants. – Phil Frost Feb 18 '14 at 14:06
    @user2785724 That's a mess. What is it doing? Is it making a groove of a particular length and depth? Then you could create a function called `createGroove(length, depth)`. You need to implement functions that describe what you want to accomplish as you would describe them to a mechanical engineer. That's what literate programming is about. – Phil Frost Feb 18 '14 at 14:09
  • That's the [API call](http://help.solidworks.com/2013/English/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.ISketchManager~CreateLine.html) to draw **one** line in 3d space. Each of the 6 arguments are on different lines in the program. The whole API is crazy. I didn't know where to make the mess, so I made it there. If you knew what the API call was and its arguments, you'd see what the endpoints were, using parameters familiar to you, and be able to relate it back to the part. If you want to become familiar with SolidWorks, the API is absolutely labyrinthine. – user2785724 Feb 18 '14 at 22:16
  • I suggest wrapping it if you can, even just as "draw a surface", if not "draw a block"/"draw a cut". A rectangular prism only has 8 vertexes, but it's made of 6 planes that each have 4... better where you can to pass the 8. But that's probably also why the API is so ugly, there's a lot of flxibility. – Móż Feb 18 '14 at 23:26
I think your question reduces to: how do I structure a computation? Please notice you want to manage "a set of rules", which are code, and "a set of magic numbers", which are data. (You can see them as "data embedded in your code", but they are data nonetheless).
Furthermore, making your code "understandable to others" is in fact the general goal of all programming paradigms (see e.g. "Implementation Patterns" by Kent Beck, or "Clean Code" by Robert C. Martin for authors on software who state the same goal as you, for any program).
All hints in these books would apply to your question. Let me extract some hints specifically for "magic numbers" and "sets of rules":
  1. Use named constants and Enumerations to replace magic numbers
    Example of constants:
    if (partWidth > 0.625) {
        // doSomeApiCall ...
    return (partWidth - 0.625)
    should be replaced with a named constant so that no later changes can introduce a typo and break your code, e.g. by changing the first 0.625 but not the second.
    const double MAX_PART_WIDTH = 0.625;
    if (partWidth > MAX_PART_WIDTH) {
    return (partWidth - MAX_PART_WIDTH)
    Example of Enumerations:
    Enumerations can help you put together data that belong together. If you are using Java, remember that Enums are objects; their elements can hold data, and you can define methods that return all elements, or check some property. Here an Enum is used in constructing another Enum:
    public enum EnginePart {
        CYLINDER (100, Materials.STEEL),
        FLYWHEEL (120, Materials.STEEL),
        CRANKSHAFT (200, Materials.CARBON);
        private final double maxTemperature;
        private final Materials composition;
        private EnginePart(double maxTemperature, Materials composition) {
            this.maxTemperature = maxTemperature;
            this.composition = composition;
    public enum Materials {
        STEEL,
        CARBON
    The advantage being: now nobody can wrongly define an EnginePart that is not made out of steel or carbon, and nobody can introduce an EnginePart called "asdfasdf", as would be the case if it was a string that would be checked on content.
  2. The Strategy pattern and the Factory method pattern describe how to encapsulate "rules" and pass them to another object that makes use of them (in the case of the Factory pattern, the usage is building something; in the case of the Strategy pattern, the usage is whatever you want).
    Example of Factory method pattern:
    Imagine you have two types of Engines: one where each part has to be connected to the Compressor, and one where each part can be freely connected to whatever other parts. Adapted from Wikipedia
    public class EngineAssemblyLine {
        public EngineAssemblyLine() {
            EnginePart enginePart1 = makeEnginePart();
            EnginePart enginePart2 = makeEnginePart();
            enginePart1.connect(enginePart2);
            this.addEngine(engine1);
            this.addEngine(engine2);
        protected Room makeEngine() {
            return new NormalEngine();
    And then in another class:
    public class CompressedEngineAssemblyLine extends EngineAssemblyLine {
        @Override
        protected Room makeRoom() {
            return new CompressedEngine();
    The interesting part is: now your AssemblyLine constructor is separated of what type of Engine it is handling. Maybe the addEngine methods are calling a remote API...
    Example of Strategy pattern:
    The Strategy pattern describes how to introduce a function into an object in order to change its behavior. Let us imagine you sometimes want to polish a part, sometimes you want to paint it, and by default you want to review its quality. This is a Python example, adapted from Stack Overflow
    class PartWithStrategy:
        def __init__(self, func=None) :
            if func:
                self.execute = func
        def execute(self):
            # ... call API of quality review ...
            print "Part will be reviewed"
    def polish():
        # ... call API of polishing department ...
        print "Part will be polished"
    def paint():
        # ... call API of painting department ...
        print "Part will be painted"
    if __name__ == "__main__" :
        strat0 = PartWithStrategy()
        strat1 = PartWithStrategy(polish)
        strat2 = PartWithStrategy(paint)
        strat0.execute()  # output is "Part will be reviewed"
        strat1.execute()  # output is "Part will be polished"
        strat2.execute()  # output is "Part will be painted"
    You may expand this to holding a list of Actions you want performed, and then calling them in turn from the execute method. Maybe this generalization could be better described as a Builder pattern, but hey, we don't want to get picky, do we? :)
logc
  • 2,190
You may want to use a rules engine. A rules engine gives you a DSL (Domain Specific Language) that is designed to model the criteria needed for a certain outcome in an understandable way, as explained in this question.
Depending on the implementation of the rules engine, the rules may even be changed without recompiling the code. And because the rules are written in their own, simple language, they can be changed by the users as well.
If you're lucky there is a ready-to-use rules engine for the programming language you are using.
The downside is that you have to get acquainted with a rules engine which may be hard if you're a programming beginner.
zilluss
My solution to this problem is quite different: layers, settings, and LOP.
First wrap the API in a layer. Find sequences of API calls that are used together and combine them into your own API calls. Eventually there should be no direct calls to the underlying API, just calls to your wrappers. The wrapper calls should start to look like a mini language.
Second, implement a 'settings manager'. This is a way to associate names with values dynamically. Something like this. Another mini language.
Baseplate.name="Base plate"
Baseplate.length=1032.5
Baseplate.width=587.3
Finally, implement your own mini language in which to express designs (this is Language Oriented Programming). This language should be understandable to the engineers and designers who contribute the rules and settings. The first example of such a product that comes to mind is Gnuplot, but there are many others. You could use Python, although personally I wouldn't.
I understand that this is a complex approach, and may be overkill for your problem, or requiring skills you have yet to acquire. It's just how I would do it.
david.pfx
  • 8,105
  • 44
I'm not sure I got the question correctly, but it sounds like you should group things in some structures. Say if you are using C++, you can define things like:
struct SomeParametersClass
    int   p1;  // this is for that
    float p2;  // this is a different parameter
    SomeParametersClass() // constructor, assigns default values
        p1 = 42; // the best value that some guy told me
        p2 = 3.14; // looks like a know value, but isn't
struct SomeOtherParametersClass
    int   v1;  // this is for ...
    float v2;  // this is for ...
    SomeOtherParametersClass() // constructor, assigns default values
        v1 = 24; // the best value
        v2 = 1.23; // also the best value
You can instanciate these at beginning of program:
int main()
    SomeParametersClass params1;
    SomeOtherParametersClass params2;
Then your API calls will look like (assuming you can't change the signature):
 SomeAPICall( params1.p1, params1.p2 );
If you can change the signature of API, then you can pass the whole structure:
 SomeAPICall( params1 );
You can also group all the parameters into a larger wrapper:
struct AllTheParameters
    SomeParametersClass      SPC;
    SomeOtherParametersClass SOPC;
kebs
  • 101
I'm surprised that no one else has mentioned this...
So let me say this, most of the other answers are on the right track. I definitely think databases could help you out. But another thing that will help you out is commenting, good variable names, and proper organization / separation of concerns.
All the other answers are heavily technical based, but they're ignoring the fundamentals that most programmers learn. Since you're a mech engie by trade, my guess is you're not used to this style of documentation.
Commenting and choosing good, succinct variable names helps immensely with readability. Which is easier to understand?
var x = y + z;
Or:
//Where bandwidth, which was previously defined is (1000 * Info Rate) / FEC Rate / Modulation * carrier spacing / 1000000
float endFrequency = centerFrequency + (1/2 bandwidth);
This is pretty language independent. No matter what platform, IDE, language, etc. you're working with, proper documentation is the cleanest, easiest way to make sure someone can understand your code.
Next it's on to managing those magic numbers and tons of concerns, but I think GrandmasterB's comment handled that pretty well.
Drew
