I have some JSON data in this format (5,000 instances for now):
{"id":"123456","icon":"icon.png","caseName":"name of case"}
I am allowing the user to search for the name of the case and then return the id and icon to them, and in some situations, use the case id to run other functions, based on the search.
How should I read this data? I'm currently leaning towards a switch because I want the switch to allow me to define multiple cases giving me the same result:
name of case and name-of-case should return me the id 123456
I can easily use a switch based on the string, listing out different cases, to do this. Probably going to be extremely tedious, but it's an option.
So, my options I can think of are as follows:
- Run a massive switch based on the query string (probably in a separate PHP file)
- Store this result in a MySQL database, then based on the query string, retrieve the data, and I probably need to do indexing (which I understand, but have no idea how to implement).
Also, I would like to prepare for the scenario that this 5,000 instances increases to 10,000 instances at some point in time.
What's the best way of going about this?
Thanks.
