21
It seems to me like pre-order traversal and DFS are same as in both the cases we traverse from root till the left branch and back to root and then to the right branch recursively. Could any please correct me if I am wrong?
Thanks in advance!
Srikanth Kandalam
  • 313
    More answers here: https://stackoverflow.com/questions/21571745/is-pre-order-traversal-on-a-binary-tree-same-as-depth-first-search – Janac Meena May 14 '20 at 00:45
pre order traversal is a traversal, it visits every node in a binary tree
Depth First Search is a search, it goes around an arbitrary graph looking for a certain node (that it works best in a non cyclic graph (a.k.a. tree) is irrelevant)
this alone is a large enough difference to call them difference names
ratchet freak
  • 25,706
  • 62
    +1, but I'd like to add that pre- and post-order traversals are just special cases of the more general DFS strategy. – Frank Feb 05 '14 at 08:42
    Doesn't pre-order traversal simply mean processing nodes before their children? Where does it say that the nodes form a binary tree, or even a tree? – Kilian Foth Feb 05 '14 at 08:54
  • @KilianFoth I would expect the implication of a node having children (as opposed to neighbors) to imply a tree structure since it suggests a hierarchy of nodes. The top of the hierarchy being the root of the tree. But I can imagine pre order traversal and post order traversal making sense on any tree even those that are not binary. – YoungJohn Jul 22 '15 at 19:48
  • Per these being for _binary_ trees only, that is patently untrue. Only _inorder_ traversal applies specifically to binary trees; pre- and post-order are general graph traversal terms. – Engineer Mar 05 '21 at 11:05
Pre-order traversal and DFS can produce the same result. However, their capabilities are different, in that traversals are only for trees, but DFS is for any graph. All trees are graphs, but not all graphs are trees.
Tree traversal means you visit every node in the tree. Depth-First-Search means you are searching for one specific node in a graph. There are 4 acknowledged tree traversals:
  1. Pre-order
  2. In-order
  3. Post-order
  4. Level-order (BFS)
Of these traversals, DFS will produce an identical result to pre-order, when you use DFS as a traversal. The way to do this would be to specify an element that does not exist in the graph, and process all the elements DFS encounters along the way - this would essentially become a traversal.
Here's an excerpt from a notable algorithms textbook
Depth-first search (DFS) is a method for exploring a tree or graph. In a DFS, you go as deep as possible down one path before backing up and trying a different one. DFS algorithm works in a manner similar to preorder traversal of the trees. Like preorder traversal, internally this algorithm also uses stack. - Data Structures and Algorithms Made Easy Java 5ed by Karumanchi N.
Janac Meena
  • 141
  • `> Depth-First-Search means you are searching for one specific node in a graph.` I'm not so sure about that. DFS is graph traversal, the idea is to for given graph `G` and starting vertice `s` return collection of all vertices reachable from vertice `s`. – aleksandarbos Jan 25 '23 at 13:13
Yes, but it should be the opposite way: DFS is similar to PreOrder.
Term PreOrder is more relevant to binary trees and parsers.
It is used to compare with other traversal orders of a binary tree: InOrder, PostOrder and PreOrder.
Topological Sort is similar to Post Order traversal (push the node into stack after visiting all the adjacent nodes).
Ahmed Nabil
  • 109
user640554
  • My thoughts are similar to this answer. More specifically, a pre-order is a specific implementation of the parent category of DFS. Pre-order child traversal is rigidly left then right; whereas for generic (parent) DFS, the children's traversal order is not defined and could be any order. – Jerred S. Feb 10 '20 at 14:20
To traverse a binary tree in Preorder, following operations are carried-out
  1. Visit the root
  2. Traverse the left subtree
  3. Traverse the right subtree
That is in the below image the pre order traversal would be, 1,2,3,6,4,5,7,8,9,10,11,12
In the same image 1,2,3,4,5,6,7,8,9,10,11,12 would be for DFS
DFS Source : http://datastructuresnotes.blogspot.in/2009/02/binary-tree-traversal-preorder-inorder.html
Pre Order Source : Wiki
DFS
Zedaiq
  • 109
