Many Builder Pattern
examples make the Builder
an inner class of the object it builds.
This makes some sense since it indicates what the Builder
builds. However, in a statically typed language we know what the Builder
builds.
On the other hand if the Builder
is an inner class, you should know what class the Builder
builds without looking inside of the Builder
Also, having the builder as an inner class reduces the number of imports since it can be referenced by the outer class--if you care about that.
And then there are practical examples where the Builder
is in the same package, but not an inner class, like StringBuilder
. You know that the Builder
should build a String
because it is named so.
That being said, the only good reason I can think of for making a Builder
an inner class is that you know what the class' Builder
is without knowing its name or relying on naming conventions. For example, if StringBuilder
was an inner class of String
I probably would have known it existed sooner than I did (speculative).
Are there any other reasons to make the Builder
an inner class or does it just come down to preference and ritual?
