I am using signals (specifically Boost signals2
) to create an event driven protocol API and model.
Most elements have their own signals, and there are usually multiple of each element.
Consider a basic entity, a user
; amongst others, the user may leave the system, so I need to have a leave signal.
The question is, should the user object itself be passed to the signal handler? I.e.:
class user {
signals<void(user&)> on_leave;
If there was std::bind
and lambda then this decision would be easier to make, but with those passing the user back seems rather redundant, i.e.:
user.connect_on_leave(
[](user& u) {
//well I could already refer to user if I wanted to
And same with binding, I could do something like this
user.connect_on_leave(std::bind(my_hander, std::ref(usr));
Also, generally speaking, is it better for each signal to just pass to the user whatever it's concerned about, or have some sort of message
type which all signals operate with?
And my final question: at what point should I stop normalising data? If several signals share the same "payload", is it better to have separate signals like,
on_change_name(str)
on_msg_sent(str)
on_leave(str)
or
on_action(action, str)
