To start off, your code is broken. Returning a reference or the address of a local variable is returning garbage. Never do this. Here I've rewritten your example to return something real.
int xByAddress = 20;
int xByReference = 30;
int* returnByAddress()
return &xByAddress;
int& returnByReference()
return xByReference;
int main()
returnByReference() = 23; //possible
int x = 23;
returnByAddress() = &x; //not a lvalue error
*returnByAddress() = 245; //possible
return 0;
In this example, xByReference
is assigned the value 23. xByAddress
is assigned the value 245. Of course, returnByAddress() = &x;
is invalid.
The rule is: functions return rvalues. The only way around this is to return a reference.
returnByAddress()
returns a pointer by rvalue. You can deference the pointer to get an lvalue of the thing pointed at.
Following this rule, you can return a reference to the pointer.
int *xPointer = nullptr;
int*& returnByPointerReference()
xPointer = &xByAddress;
return xPointer;
int main()
int x = 23;
returnByPointerReference() = &x; //not a lvalue error
return 0;
This code changes xPointer
to point at the address of x
