I'm currently working with a company that uses Java / Tomcat / Spring for the back end of our web applications. As a front-end developer, I'm feeling more and more strongly that the back end should be a separate project from the front end, for a few reasons:
1) Building the project - many modern projects build with grunt and other front-end tools. The front-end build goals (concatenation, minification, front end tests, pre-processing CSS) are completely different from the back end goals (compiling java code, passing back end tests, deploying to a continuous integration server)
2) Deployment: When I commit a javascript or html file to our git repo, it doesn't make sense that our continuous deployment tool should rebuild and redeploy the whole project, but it has no way to tell the difference between a front-end commit and a back-end commit.
So, how would you restructure a project that previously automatically deployed from a single war file, living in a single git repo, to make a separate back end and front end? Can I actually do this, given that we use Spring framework?
Right now, my files live in a mixture of the /webapp/WEB-INF
directory (for html pages / velocity templates) and the /webapp/resources
directory for everything else (js, css, images). I'm slightly confused about how I should go about this when tomcat deploys a huge bulk of files to the /target
directory, as well? If I keep a separate git repo for front end files, won't it be wiped out if I re-deploy the back end project?
(Originally I come from an Apache background, where it seemed so nice and simple...)
