I am currently writing a transformation from model space to clip space for use in OpenGL. From what i have seen, programmers typically use a traditional rectangular frustum to define the clipping boundaries in their model space. I personally had in mind a shape like a frustum, except the near and far planes are spheres centered at the apex of the frustum (the camera). So something that looks like this:
Circular sector
The yellow region corresponds to OpenGL's clip space, and the two spheres (depicted as circles in this cross-section image) correspond to OpenGL's z=-1 (inner sphere) and z=1 (outer sphere).
Is this a more realistic way to model the projection, or should i stick with the traditional rectangular frustum when designing my projection matrix?
creXALBO
  • 41
Recognize that you are not just clipping against a rectangular window into space, the (angular) edges of which correspond to the boundaries of the screen (or window).
You are also projecting onto a plane, the screen surface.
The traditional clipping pyramid gives you both of these attributes. Your "spherical pyramid" would require correction from the sphere surface to the screen flatness.
John R. Strohm
  • 18,043
  • 56
