19
When unit testing I often find myself debating how much of the data I feed to, and expect back from my units under test, I should include in the actual test files.
The tradeoff I constantly struggling with is:
  • If a large portion of the test (in code volume) consists of input and output data, it seems difficult to actually read the test, but I can easily see the actual in-and outputs.
  • If I load the test data from files, I can easily test a bunch of variations on possible data input, easily reuse test data for multiple tests, but I have to leave the source code to look at another file to see what exactly the inputs are.
Is either one of these an anti-pattern?
DudeOnRock
  • 1,079
To answer your question directly - no, I don't believe either is an anti-pattern when used correctly.
--- More verbose answer ---
From my experience, I think this depends heavily on the goal of your test. Here's the rule of thumb I've used in the past and it's helped me decide:
Are you actually testing a small unit of code? (A true unit test)
If yes, then I've found it's much easier to create the data inside the test itself exactly because I can see what is being passed in. In these cases, I will usually look for a Jasmine-like library to use because I find that it makes creating and maintaining the test data easier. That's a personal preference though - use whatever makes your job easier.
If no, then you're probably actually testing the system itself. In these cases, I often do load data from an external source, the reasons here being:
  1. This test isn't about code clarity for programmers (although that is still important - someone has to maintain this), it's about running enough different types of data through the entire chunk of the system to be reasonably sure it works.
  2. Often I will write the plumbing code to load and use the test data, but the data itself is created by someone else (usually a QA staff member in my case). These people aren't usually programmers so I can't expect them to be editing code.
So long answer short, it depends on what you're testing and why. Both approaches are useful and have their place - choose what works best for your situation.
nadrees
  • 136
I don't see a trade-off here. Source code is supposed to describe algorithms, or at least business logic, not big amounts of data. If you write a Fourier transform, you want to verify that a sinus tone is correctly mapped to a single peak, a mixed sound to more peaks etc., but for that it is completely sufficient to feed a file named sinus.wav into the routine and verify that the output structure is what you expect.
Sure, technically you don't have an immediate assurance that sinus.wav really does contain a sinus tone, but as you said, listing the 100,000 amplitude values in the source doesn't really give you that either - in fact, it is worse, because you can at least play an external file with an audio player to check, while data values buried in source code are essentially impossible to do anything with.
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
