I have an exercise in Python as follows:
a polynomial is given as a tuple of coefficients such that the powers are determined by the indexes, e.g.: (9,7,5) means 9 + 7*x + 5*x^2
write a function to compute its value for given x
Since I am into functional programming lately, I wrote
def evaluate1(poly, x):
coeff = 0
power = 1
return reduce(lambda accu,pair : accu + pair[coeff] * x**pair[power],
map(lambda x,y:(x,y), poly, range(len(poly))),
0)
which I deem unreadable, so I wrote
def evaluate2(poly, x):
power = 0
result = 1
return reduce(lambda accu,coeff : (accu[power]+1, accu[result] + coeff * x**accu[power]),
poly,
(0,0)
)[result]
which is at least as unreadable, so I wrote
def evaluate3(poly, x):
return poly[0]+x*evaluate(poly[1:],x) if len(poly)>0 else 0
which might be less efficient (edit: I was wrong!) since it uses many multiplications instead of exponentiation, in principle, I do not care about measurements here (edit: How silly of me! Measuring would have pointed out my misconception!) and still not as readable (arguably) as the iterative solution:
def evaluate4(poly, x):
result = 0
for i in range(0,len(poly)):
result += poly[i] * x**i
return result
Is there a pure-functional solution as readable as the imperative and close to it in efficiency?
Admittedly, a representation change would help, but this was given by the exercise.
Can be Haskell or Lisp aswell, not just Python.
