I have been trying to design a library to do some simple geometric computations in an Euclidean space regardless of its dimension. While it is easy to represent points, vectors, hyperspheres and hyperplanes in a generic fashion, I am still unable to find a generic way to represent a (infinite) line, even though lines share properties across dimensions.
My best guess is that I could store some of the parameters of its parametric equation since it is easy to extend a parametric equation to a line in a space of any dimension:
x = x0 + at
y = y0 + bt
z = z0 + ct
// can be extended to any dimension
But even with this equation, I can't find what should be stored and what should not be in order to compare lines. With an ideal solution, two objects of type Line:
  • would be programmatically equal (with operator==),
  • would have equal representations in the memory.
What should I store in order to achieve that?
Morwenn
  • 1,736
    How about two points on the line? – Robert Harvey Dec 17 '13 at 23:39
    You would do it the same way in math... two points on the line or one point and a slope – Jimmy Hoffa Dec 17 '13 at 23:47
    The problem is that neither of those are unique descriptions of a given line. Morween asked for a method that would allow implementation of '=='. The slope and intercept uniquely identify a line. Two lines are equal iff their slopes and intercepts are equal. Store two tuples: the coordinates of the intercept (x0, y0, and z0) and the components of the slope (a, b, c). – Charles E. Grant Dec 17 '13 at 23:56
    @CharlesE.Grant Storing points would allow implementation of `operator==` as you can calculate all the rest of it from those points. However, it does fail the "equal representations in memory" part. – Izkata Dec 18 '13 at 00:45
  • I withdrew my answer, as it doesn't meet the requirement for equal representations in memory, but I would suggest reconsidering or questioning that requirement. – Steven Evers Dec 18 '13 at 00:50
  • Are you looking for a bound line of finite length? Or an infinite line? – Dancrumb Dec 18 '13 at 01:41
  • @Dancrumb An infinite line. If I was looking for a line segment, I would store two points. – Morwenn Dec 18 '13 at 09:52
  • @Morwenn, quite so, but you never know if something that is obvious to you is obvious to another :) – Dancrumb Dec 18 '13 at 13:43
  • @Dancrumb Well, that's true :) – Morwenn Dec 18 '13 at 15:57
  • @SteveEvers Actally, the question about "which is the best representation for a line" is also a good on. However, since it's probably highly subjective, I asked a narrower question about a possible implementation :) – Morwenn Dec 27 '13 at 15:27
I think you're on the right track with your parametric equation.
What you have there is the vector form of the line equation.
L = R + tV
Where R is [x0, y0, z0] and V is [a, b, c].
You just need to normalize your equations. You would do that by finding the value of R such that |R| is at a minimum, which occurs when R is perpendicular to V, or R.V = 0.
Also, since t can be scaled by any value, without changing the line, you should normalize V by dividing every coefficient by |V|
Dancrumb
  • 571
At a minimum, all you need to compare lines for equality is the parametric equation you already have.
Given lines L,M expressed as Dancrumb suggests:
L = X + tV
M = Y + tW
then L == M if V and W are parallel (or equal if they're normalized to unit length and some "positive" direction), and Y=X+tV for some t.
To get memberwise equality, normalizing the vector length & direction is the first step, but you also need some rule to normalize the point. You could, for example, choose the point on your line which is closest to the origin, and use that.
Pseudo code for normalizing your vectors and points:
vec normalize_vec(vec v) {
  // 1. force unit length
  v = v/v.length();
  // 2. force positive direction
  for (int i = 0; i < v.dimension(); ++i) {
    if (v[i] < 0) {
      v = v * -1;
      break;
    if (v[i] > 0)
      break;
    // keep going until the first nonzero element
  return v;
point closest(point p, line l) {
  return (a-p).dot(l.vec) * l.vec;
line normalize_line(line l) {
  point new_pt = closest(point::origin, l);
  vec new_vec = normalize(l.vec);
  return line(new_pt, new_vec);
Useless
  • 12,380
