I'm exploring using HMAC style secret-key authentication with timestamp expiry, but am struggling to get my head around how you validate the timestamp portion.
On the client side you would do:
my_hmac = hmac(my_secret, my_values)
Where you would have a timestamp
field in my_values
On the server (where you also know my_secret
) you would attempt to rebuild the HMACd string with the request parameters:
my_hmac_to_compare = hmac(my_secret, my_values_from_http_request)
Is it simply a case of embedding the timestamp as a parameter so it's hashed in to the HMAC string and then ensuring the timestamp is within N minutes of when we process the request?
I have odd visions of having to iterate over 5 minutes worth of timestamps, rebuilding the HMAC string on the server attempting to find the needle-in-the-haystack that will generate the correct HMAC string.
Bonus question: Is there a consensus on how you would initially transfer the secret key to a client from a server? It obviously becomes "dirty" after it goes over the wire, but in a user facing application you can't have someone pasting in an extensive secret key, especially if it's a mobile client.
