In F#, I want to build a hierarchical data structure in a way with a minimum amount of language noise. The actual problem is trying to build an RSpec inspired framework using F#. RSpec allows the construction of tests in a nested way. For example.
describe Order do
context "with no items" do
it "behaves one way" do
end
end
context "with one item" do
it "behaves another way" do
end
end
end
I have something working here, but there are some potential problems with the current solution. In particular general setup/teardown code can become somewhat ugly.
My primary concern is to write an API that allows the user to write tests/specifications in a way, where the language gets as little in the way as possible.
I think that using computation expressions could allow my to create a better API, but I am struggling with implementing nested contexts.
Currently I do have a builder that allows me to write:
let specs =
describe "Some feature" {
it "has some behavior" (fun () ->
// Test code goes here
But in order to have nested contexts I need to be able to write something like this:
let specs =
describe "in some context" {
describe "in some other context" {
I have no idea how to implement the nested context. Or even if it is possible to bend F# in a way to allow me to create such a builder.
I did make an experiment, that allowed me to write this:
let specs =
desribe "Some feature" {
child (describe "in some other" {
child (describe "in some context" {
But the added parenthesis and explicit builder construction is exactly what I want to avoid in the first place.
type DescribeBuilder(name : string) =
[<CustomOperation("it")>]
member __.It (x, name, test : unit -> unit) =
let t = TestContext.createTest name test
x |> TestContext.addTest t
[<CustomOperation("child")>]
member __.Child(x, child :TestContext.T) =
x |> TestContext.addChildContext child
member __.Yield y =
TestContext.create name
member __.Delay (x) =
x()
let describe name = new DescribeBuilder(name)
