72
In my education I have been told that it is a flawed idea to expose actual primary keys (not only DB keys, but all primary accessors) to the user.
I always thought it to be a security problem (because an attacker could attempt to read stuff not their own).
Now I have to check if the user is allowed to access anyway, so is there a different reason behind it?
Also, as my users have to access the data anyway I will need to have a public key for the outside world somewhere in between. Now that public key has the same problems as the primary key, doesn't it?
There has been the request of an example on why do that anyway, so here is one. Keep in mind that the question is meant to be about the principle itself not only if it applies in this example. Answers addressing other situations are explicitly welcome.
Application (Web, Mobile) that handles activity, has multiple UIs and at least one automated API for intersystem communication (e.G. the accounting department wants to know how much to charge the customer based on what has been done). The Application has multiple customers so separation of their data (logically, the data is stored in the same DB) is a must have of the system. Each request will be checked for validity no matter what.
Activity is very fine granular so it is together in some container object, lets call it "Task".
Three usecases:
  1. User A wants to send User B to some Task so he sends him a link (HTTP) to get some Activity done there.
  2. User B has to go outside the building so he opens the Task on his mobile device.
  3. Accounting wants to charge the customer for the Task, but uses a third party accounting system that automatically loads the Task / Activity by some code that refers to the REST - API of the Application
Each of the usecases requires (or gets easier if) the agent to have some addressable identifier for the Task and the Activity.
Tsundoku
  • 137
Angelo Fuchs
  • 1,086
    related: [Should a surrogate key ever be exposed to a user?](http://programmers.stackexchange.com/q/204394/31260) "You need to be ready for any identifier that is exposed to users/customers needing to be changed, and changing the identity of a row in a database and propagating that change to all foreign keys is just asking to break data..." – gnat Nov 13 '13 at 08:09
  • @gnat `ON UPDATE CASCADE` was made for that (mysql specific?), although if the issue is security then the access checking should be on the backend and not trust the user anyway – Izkata Nov 13 '13 at 18:11
    @Izkata Yeah, except when you reference them in a different datastore (UserID in LDAP as a simple example), or you need to have to recover some data from a backup. gnat has a good point there. – Angelo Fuchs Nov 13 '13 at 19:12
  • Can you pelase elaborate on what you mean with "expose"? An actual example might help. :-) – CodeCaster Nov 13 '13 at 19:24
  • "expose" means showing it to the user. (By user I mean a human mostly, but the question seems valid for machines as well) – Angelo Fuchs Nov 13 '13 at 21:01
  • @CodeCaster I added an example. – Angelo Fuchs Nov 13 '13 at 21:13
  • For instance printing the number on the users monthly account statement. – Michael Durrant Nov 14 '13 at 12:40
9 Answers9
54
Exactly. Take the stateless HTTP, who would otherwise not know what resource it should request: it exposes your question's ID 218306 in the URL. Perhaps you're actually wondering whether an exposed identifier may be predictable?
The only places where I've heard a negative answer to that, used the rationale: "But they can change the ID in the URL!". So they used GUIDs instead of implementing proper authorization.
I can imagine one situation where you don't want your identifiers to be predictable: resource harvesting. If you have an site that publicly hosts certain resources others may be interesting in, and you host them like /images/n.jpg or /videos/n.mp4 where n just is an incrementing number, anyone looking at traffic to and from your website can harvest all your resources.
So, to directly answer your question: no, it is not bad to directly "expose" identifiers that only have meaning to your program, usually it is even required for your program to succesfully operate.
CodeCaster
  • 2,394
    Unguessable urls (e.g. containing a cryptographically random 128 bit token) are one form of proper authorization. – CodesInChaos Nov 13 '13 at 10:20
    Proper as in extremely sensitive to replay attacks? It's nice for a one-time use like a password reset URL, but less so to identify a static resource, as once the token is out in the open anyone can use it, without you being able to change it without breaking any legitimate reference to it. – CodeCaster Nov 13 '13 at 10:24
  • hm? Obviously it requires SSL, but that's the case no matter how you authenticate and authorize. Over SSL an attacker can't learn the token (just like they can't learn cookies) and it also prevents replay attacks. The main downside of this approach is that you can't revoke access for individual users, so I prefer using it only for immutable resources. Revoking access to immutable resources is meaningless since an attacker could simply store a local copy. – CodesInChaos Nov 13 '13 at 10:27
    I seem to be incapable these days of actually expressing what I mean, I'm sorry. I mean using a random token for a static resource as opposed to an incremental ID is fine, if you want the resource to be publicly-accessible but not guessable. For any other use though I'd prefer a one-time use, because of the revocation thing. – CodeCaster Nov 13 '13 at 10:34
  • Well, an exposed identifier (like a sequential PK) is of course predictable, but who cares? One needs to have proper authentication anyway, so whats the gain (except resource harvesting) of using GUIDs instead? – Angelo Fuchs Nov 13 '13 at 12:29
    None, my point exactly. Can you perhaps elaborate on what you mean with "expose" then? – CodeCaster Nov 13 '13 at 12:29
  • I've used apps where record PK's are displayed read-only at the bottom of forms for technical support purposes. – JeffO Nov 13 '13 at 14:02
37
Because Primary Keys are an implementation detail.
If you migrate databases, your primary keys might change due to order of insertion, removal of old records... a few different reasons. If you migrate database platforms you may no longer have an actual primary key at all. Exposing the PK above the data access layer is a leaky abstraction, with all of the coupling concerns that entails.
Telastyn
  • 108,850
  • 239
  • 365
    How will an application layer uniquely identify a resource it wants to retrieve from or update in the data layer without a primary key? – CodeCaster Nov 13 '13 at 14:13
    @CodeCaster - either by some unique indexed set of data, or by a **non-public** primary key that is returned as part of the object supplied by the data access layer. – Telastyn Nov 13 '13 at 14:31
    While that sounds perfect in theory, it also sounds distant from reality. How will a (totally disconnected, because of the statelessness of HTTP) web layer update the user input in the data layer without a PK to refer to the entity to update? Send the original values along with the updated ones so the data layer can look up the existing item? What if the item has been updated by another user in the meantime? And what do you mean by a non-public PK? – CodeCaster Nov 13 '13 at 14:50
    @CodeCaster - There's plenty of ways to create a token that allows the callback to specify what operation is being done, and certainly not all of them just pass the primary key right through. – Telastyn Nov 13 '13 at 14:55
    But that requires the data layer to know which token belongs to (or translates to) which PK. To me that sounds like an added layer of unnecessary complexity, merely for the sake of hiding the PK. What purpose does that serve, apart from satisfying the architect? I do agree with your point, I just don't find it applicable in real-world usage and would appreciate an actual example. – CodeCaster Nov 13 '13 at 15:04
    @CodeCaster - No, the middle tier actually does its job and abstracts that there's data access at all from the UI. There are plenty of bad architects in the world, but many of the best practices of program design exist for a reason. Some apps can take the risk of that leaky abstraction and some cannot. – Telastyn Nov 13 '13 at 15:08
    @Telastyn "best practices... exist for a reason" Yes. This question is about "What is the reason behind this best practice". Your answer gave one. – Angelo Fuchs Nov 13 '13 at 21:29
    +1 thanks for posting the correct answer so I didn't have to. Implementations change, as soon as external systems rely on implementations, you've set a time bomb for yourself. Well said. – Jimmy Hoffa Aug 28 '17 at 19:04
34
You shouldn't expose it because people who see it will start to use it as their 'account number' which it is NOT. For example, for my bank account I know what my account number is. I've memorized it, I use it on the phone with customer service, I use it when filling out forms for other banks to do transfers, for legal documents, for my auto-pay service, etc, etc. I don't want it to change. The primary key (for my account) on the other hand, I don't know or ever see.
The system that stores it changes over the years from one system to another, through bank merges, system upgrades and replacements, etc, etc.
The primary keys may change through some of these transformation, so if its never been exposed, written down or remembered by any regular user that's a real good thing.
Keys with no business meaning are often termed surrogate keys and are often (but not always) used as primary keys.
btw, this even happens internally when people built interfaces and programs that misuse and expose primary keys and make them part of such systems instead of them just doing one thing - uniquely identifying a database record internally. I actually learned the above through a 6 year stint supporting a data warehouse system in a hospital.
Michael Durrant
  • 13,101
  • 60
    +1 but what you are describing here is actually a *surrogate* key. Not every table has a surrogate key and even if it does the surrogate may not be the "primary" key. – nvogel Nov 14 '13 at 04:33
    +1 I thought the account number would be the surrogate key but I read up on it and you are 100% correct :) – Michael Durrant Nov 14 '13 at 12:35
    +1 exposing it to users adds implicit requirements (e.g. remain static) – Matt Nov 18 '13 at 18:31
    Great answer. My shorthand way of saying this is that surrogate keys are useful because no one cares about them and no one therefore cares if you change them or don't change them. If you expose them, people will start to care about them. – JimmyJames Aug 28 '17 at 19:26
  • tl;dr: because the future. If something external comes to rely on a key, things get messy if implementation changes later on; so keep them more or less hidden to make things easier. – Adam Tolley Aug 28 '17 at 22:16
  • I know this is an old answer, but... What are the alternatives to exposing PK? – user2652379 Nov 10 '20 at 05:55
  • Using a private surrogate key – Michael Durrant Nov 10 '20 at 10:20
22
This is a combination answer of the other ones (aka. what I have learned). If you feel like upvoting this one, you should at least upvote one of the other ones as well as they did the actual work. If you are more interested, read the other answers instead.
You should not expose the databases primary key but instead use a surrogate key
  1. If you want your users to be able to remember (at least a bit) or recognize the identifier of an entry. (Graystone28s Answer)
  2. If you want to plan ahead and consider that you might change systems (Database or otherwise) that will likely change your PK. (Telastyns Answer)
  3. If you want to ensure your users have a consistent way of accessing data that wont change even if your company shifts ownership and the data is thous migrated into a different system altogether. (Michael Durrants Answer)
  4. If your PK is predictable (like a sequence) your system can suffer resource harvest problems. (CodeCasters Answer) This only applies if your system has information that is worth harvesting and that is accessible by anybody or at least somebody who has a harvesting interest.
Note: Your created key should be (kinda) human comprehensible (Sqlvogels Answer).
If your system has no need for 1. to 4. then there is no reason not to use the databases PK as your public identifier (several of the answers). Also security is not an issue here (several of the answers).
Angelo Fuchs
  • 1,086
One reason I've found, in the fullness of time I've seen end users request that their identifier means something (like having a prefix, or an indicator of the year it was incepted). Changing a PK is hard, but a surrogate is much easier.
Your primary key will likely be something you want your database indexing on for performance reasons, and you may in time for technical reason change it for example from a number to a guid... you just don't know what reasons new technologies or knowledge might guide you down. Your pk is your technical item of data, the public key is for end users consumption.
Wayne M
  • 154
    Question is: _"Is it bad to expose primary keys?"_. Your answer: _"Users may want to have their own identifiers"_. I don't get the relation. I expose `InvoiceNumber`, which has a meaning to and is changeable by the customer, but I also expose `InvoiceID`, which my code uses to uniquely identify the invoice. You don't have to (and more often don't _want_ to) let the user-key be the storage-key. This question is about the latter. – CodeCaster Nov 13 '13 at 12:32
  • I think this is a nice example because if you move to multi-tenant version of your APP, you can keep the same syntax and have multiple invoices of the same `InvoiceNumber` (for different tenants) but have different primary keys -- a point (kind of) mentioned in the answer also. – recluze Nov 13 '13 at 14:43
    @CodeCaster this question is actually about "why don't you want them to be the same"? – Angelo Fuchs Nov 13 '13 at 21:23
  • In that case see Telastyns [answer](http://programmers.stackexchange.com/a/218328/35973). – CodeCaster Nov 13 '13 at 21:34
For most applications it's pretty much essential that you DO expose keys to users. To use an information system effectively the users of that system will normally need a way to identify the information within it and to relate that information to something in the world outside the database. In relational database terms, those identifiers are keys.
One well-used design pattern is to create an additional, purely "technical" key for database tables as a means of abstraction. For example to provide a stable (relatively unchanging) key where some alternative key is subject to change. Such technical keys typically aren't exposed to end users because doing so undermines the intended abstraction from user requirements. It has nothing to do with security.
The problem / misunderstanding implicit in your question is due to inappropriate use of the term primary key. A primary key is just one among several "candidate" keys (several possible identifiers in a database table). The primary key doesn't necessarily require any fundamentally different property to any other key so assertions and design principles that apply specifically to primary keys and not to other keys are always suspect and often wrong.
Given that you will usually need to expose a key to your user, what should that key be? Try to make your keys Familiar, Simple and Stable. Familiarity and simplicity make keys easy to read and remember and will help avoid data entry errors. Stability means the key changes infrequently which also helps avoid the possibility of misidentification.
nvogel
  • 604
    it depends... on what? I want to learn what the reasons are behind that generic concept to know when to apply it and when not. – Angelo Fuchs Nov 13 '13 at 21:34
    Hi Customer, please give me your id so I can help you. Sure, its gfds789gxb3456bgfx789fgh98076hytd6734nhg5678nghf875nhgf456. Hmm, how about your social? ... surrogate id – Michael Durrant Nov 13 '13 at 22:52
  • @Michael, Answer updated. Is that a familiar, simple and stable key? – nvogel Nov 14 '13 at 04:28
It's completely normal for entities have a unique identifier that is exposed to the outside world. For some objects it might be possible to find an identifier that actually has a meaning (for example invoice number) but for other no such identifier exists and therefore it has to be generated.
For the sake of consistency and readability I find it a good practice for all the entities in a system to use the exact same type and name for their identifier. Normally this identifier would be exposed (<type> getId()) in some abstract base class.
For the same reason each service in the system (for example invoice service) should provide identical methods for accessing entities by their identifier. Normally this method (findById(<type> id)) would be inherited from a generic service interface or base class.
This identifier doesn't have to be the primary key of the entity but it can be one. Only thing one has to ensure is that the key generation strategy produces reasonably unique identifiers (not necessary universally unique but at least within the system).
If the system is later migrated (big if in my experience) to another database then it's not a problem to use a different strategy (not based on primary keys) for creating the identifiers as long as the strategy is compatible with the original one.
Muton
  • 617
  • Could you explain what in your answer has not been answered in the other ones? – Angelo Fuchs Nov 14 '13 at 21:36
    In my answer I'm disagreeing at least with points 2. and 3. of your summary. I don't think these are valid reasons of not using PKs as object identifiers. – Muton Nov 15 '13 at 07:01
This is from a comment on Greystone28's answer by CodeCaster. It is an example of what you are saying:
I expose InvoiceNumber, which has a meaning to and is changeable by the customer, but I also expose InvoiceID, which my code uses to uniquely identify the invoice. You don't have to (and more often don't want to) let the user-key be the storage-key. This question is about the latter.
What purpose in your app does diplaying the InvoiceID serve?
By expose, I'm assuming you mean the user can see it. Only expose it if the user needs it to use your app. It could be used by techniical support or some administrative stuff. I've worked with a few apps that do this. It does make it easier to provide support when I know the specific record in question.
JeffO
  • 36,816
  • 57
  • 124
  • Invoices have natural identifiers (numbers) but only for the ones you write. What about the ones you get? They have InvoiceNumbers but they overlap (because two companies use the same one and both send you an invoice). In this situation your InvoiceID is unique, the Number isn't and what makes it unique would be the Customername which is no good identifier for data (too long, changes too often, may contain obscure characters...) – Angelo Fuchs Nov 13 '13 at 21:26
  • @AngeloNeuschitzer - If the user can uniquely identify an invoice by Customer name and number, the user doesn't need the InvoiceID PK, but the database and underlying code can use it. They're mutually exclusive functions. – JeffO Nov 13 '13 at 22:44
  • See cases 1 - 3 of my example. In none of that cases Customer Name is a useful way of addressing that Object for the User (be it human or machine). InvoiceID PK is. – Angelo Fuchs Nov 14 '13 at 06:11
Primary key is there, just as a handle to the tuple (record, row) you try to access as a developer. It's also used in referential integrity (foreign key constraints), and maybe it has one or more use cases too.
Essentially, there is nothing bad about exposing it to users, or even hackers. Because I don't know of an attack that uses primary key for example.
But in security, we have many principles (which we accept and don't approve) and we need to adhere them:
  1. The principle of lease privilege
  2. Security through obscurity
And some other principles. What they say essentially is that:
If you don't need to expose your data, why would you at all?
gnat
  • 21,442
  • 112
  • 288
Saeed Neamati
  • 18,142
  • 87
  • 125
  • The handle part is where I agree. The security is not. It *might* be security relevant, but having an independent internal key that is not visible to the user is mostly not really about security. I would call that a nice side-effect. – JensG Nov 13 '13 at 19:48
  • Why would you: see the example I added to the question. – Angelo Fuchs Nov 13 '13 at 21:13
