56
The example used in the question pass bare minimum data to a function touches on the best way to determine whether the user is an administrator or not. One common answer was:
user.isAdmin()
This prompted a comment which was repeated several times and up-voted many times:
A user shouldn't decide whether it is an Admin or not. The Privileges or Security system should. Something being tightly coupled to a class doesn't mean it is a good idea to make it part of that class.
I replied,
The user isn't deciding anything. The User object/table stores data about each user. Actual users don't get to change everything about themselves.
But this was not productive. Clearly there is an underlying difference of perspective which is making communication difficult. Can someone explain to me why user.isAdmin() is bad, and paint a brief sketch of what it looks like done "right"?
Really, I fail to see the advantage of separating security from the system that it protects. Any security text will say that security needs to be designed into a system from the beginning and considered at every stage of development, deployment, maintenance, and even end-of-life. It is not something that can be bolted on the side. But 17 up-votes so far on this comment says that I'm missing something important.
GlenPeterson
  • 14,890
  • 47
  • 75
    I don't think its bad, especially if it's only a flag in the user db table. *Should* there be changes in the future, change it in the future. You may as well call the security system from the user object. I have once read about the design pattern that every db/resource access should go through the current-user object, to make sure you never try to do something that is not allowed. Might be a bit much, but the user could provide a "privileges" object that covers all security-related stuff. – Cephalopod Nov 04 '13 at 12:31
  • I think there was a misunderstanding. For you, "User" means the person who uses the software. For them, "User" means the code which uses your functionality. – Philipp Nov 04 '13 at 12:35
    Not that you asked, but the thing I would most be careful of in this case is an IsAdmin() method at all, wherever you put it. I would usually recommend having an "Admin" not be hard-coded, but just have a set of possible permissions and an "Admin" just happens to have the whole set. That way when you need to split up the Admin role later, things are *much* easier. And it cuts down on special case logic. – psr Nov 04 '13 at 17:46
    @Philipp I don't think so... Both sites are explicitly talking about a `User` object with an `isAdmin()` method (whatever it does behind the scenes) – Izkata Nov 04 '13 at 20:41
  • Too late to edit; I meant "Both sides", not "Both sites"... =P – Izkata Nov 05 '13 at 00:27
11 Answers11
42
That comment was badly worded.
The point isn't whether the user object "decides" whether it is an admin, a trial user, a superuser or anything in or out of the ordinary. Obviously it doesn't decide any of those things, the software system at large, as implemented by you, does. The point is whether the "user" class should represent the roles of the principal that its objects represent, or whether this is a responsibility of another class.
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
    Ouch (it was my comment), but you do put it a lot better than I did. – Marjan Venema Nov 04 '13 at 12:38
  • You are saying to model roles in a separate Role class, not on the User class? You are not recommending a separate system like LDAP? What if every single decision that the Role class makes requires querying the appropriate user record and requires no other information? Should it still be separate from the User and if so, why? – GlenPeterson Nov 04 '13 at 12:41
  • This is interesting. I wonder if you are slicing the problem of system design from a functional perspective and I am slicing from an object/data perspective. You put the verbs first, and I have put the nouns first? – GlenPeterson Nov 04 '13 at 12:47
    @GlenPeterson: not necessarily, just that classes <> tables and usually there are a lot more classes to be discerned than tables. Being data-oriented does lead to defining sublists on classes though, when many times these lists should be defined on another "ledger" (orders) or some such class passing in the user (or the order) for which to retrieve the... It is more a matter of responsibilities than of verbs and nouns. – Marjan Venema Nov 04 '13 at 12:50
    Think about the User as a key, and the permissions as a value. Different contexts might have different permissions for each user. As the permissions are context-relevant, you would either have to change the user for each context. So it's better you put that logic somewhere else (e.g. the context class). – Wilbert Nov 04 '13 at 13:15
    @Wilbert: Context! That is particularly enlightening! Yes, if you have more than one context for those permissions then everything makes sense to me. Usually I see these permissions in a single context, and sticking them on the user is the simplest solution in that case. Clearly they don't belong there if they apply differently in a second context. If you write that as an answer, I am likely to accept it. Thank you. – GlenPeterson Nov 04 '13 at 13:31
  • @Wilbert: It's been a couple of days and no-one has answered my question nearly as well as you. I cannot "accept" a comment, only an answer. Your comment has been up-voted 8 times which tells me you've already lost at least 85 potential reputation points (8x10=80 +5 for chosen answer) by not cutting and pasting your comment into an answer. Just saying... – GlenPeterson Nov 07 '13 at 12:52
  • Haha, ok :) Doing that now. – Wilbert Nov 07 '13 at 13:28
30
I wouldn't have chosen to word the original comment the way it was worded, but it does identify a potentially legitimate issue.
Specifically, the concerns that warrant separation are authentication vs. authorization.
Authentication refers to the process of logging in and getting an identity. It is how the systems knows who you are, and used for things like personalization, object ownership, etc.
Authorization refers to what you are allowed to do, and this (generally) is not determined by who you are. Instead, it is determined by some security policy like roles or permissions, which don't care about things like your name or email address.
These two can change orthogonally to each other. For example, you might change the authentication model by adding OpenID/OpenAuth providers. And you might change the security policy by adding a new role, or changing from RBAC to ABAC.
If all of this goes into one class or abstraction, then your security code, which is one of your most important tools for risk mitigation, becomes, ironically, high-risk.
I have worked with systems where authentication and authorization were too tightly coupled. In one system, there were two parallel user databases, each for one type of "role". The person or team who designed it apparently never considered that a single physical user might be in both roles, or that there might be certain actions which were common to multiple roles, or that there could be problems with User ID collisions. This is an admittedly extreme example, but it was/is incredibly painful to work with.
Microsoft and Sun/Oracle (Java) refer to the aggregate of authentication and authorization information as the Security Principal. It's not perfect, but it works reasonably well. In .NET, for example, you have IPrincipal, which encapsulates the IIdentity - the former being a policy (authorization) object while the latter is an identity (authentication). You could reasonably question the decision to put one inside of the other, but the important thing is that most code you write will be for just one of the abstractions which means it is easy to test and refactor.
There's nothing wrong with a User.IsAdmin field... unless there is also a User.Name field. This would indicate that the "User" concept isn't properly defined and this is, sadly, a very common mistake among developers who are a bit wet behind the ears when it comes to security. Typically, the only thing that should be shared by identity and policy is the User ID, which, not coincidentally, is exactly how it is implemented in both the Windows and *nix security models.
It's completely acceptable to create wrapper objects that encapsulate both identity and policy. For example, it would facilitate the creation of a dashboard screen where you need to display a "hello" message in addition to various widgets or links that the current user is permitted to access. As long as this wrapper just wraps the identity and policy information, and doesn't claim to own it. In other words, as long as it's not being presented as an aggregate root.
A simplistic security model always seems like a good idea when you're first designing a new application, because of YAGNI and all that, but it almost always ends up coming back to bite you later, because, surprise surprise, new features get added!
So, if you know what's best for you, you'll keep authentication and authorization information separate. Even if the "authorization" right now is as simple as an "IsAdmin" flag, you'll still be better off if it's not part of the same class or table as the authentication information, so that if and when your security policy needs to change, you don't need to do reconstructive surgery on your authentication systems which already works fine.
Aaronaught
  • 44,005
  • 92
  • 126
    Oh I wish I had had the time to write this. Then again, I probably wouldn't have been able to put it as well as you did without a lot more thought on my part. A lot times my gut instinct tells me to go one way or the other, but explaining why - to myself or someone else - takes a lot more thought and effort. Thanks for this post. Would have multiple-plussed it, but SE won't let me... – Marjan Venema Nov 04 '13 at 18:52
  • This sounds shockingly similar to a project I am working on and your answer gave me another perspective. Thank you so much! – Brandon Nov 05 '13 at 02:50
  • "There's nothing wrong with a User.IsAdmin field... unless there is also a User.Name field" you write. But what `isAdmin` is a method? It might just delegate to an object whose responsibility it is to keep track of permissions. What is best practice in the design of a relational model (what fields an entity has) is not necessarily translatable to what is best practice in an OO model (what messages an object can respond to). – KaptajnKold Nov 05 '13 at 12:07
  • @KaptajnKold: I keep reading this sentiment in various Q&A threads in this forum. If a method exists, it doesn't matter if it *directly* performs the operations or it *delegates* them, *it still counts as a responsibility because other classes may rely on it*. Your `User.IsAdmin` might very well be a one-liner that does nothing but call `PermissionManager.IsAdmin(this.Id)`, but if it gets referenced by 30 other classes, you can't change or remove it. That's why the SRP exists. – Aaronaught Nov 06 '13 at 00:34
  • And, @KaptajnKold, as far as relational models go, I'm not sure what you're getting at; it's even *worse* to have an `IsAdmin` *field*. It's the kind of field that tends to stick around long after the system has evolved into RBAC or something more complex, and gradually gets out of sync with the "real" permissions, and people forget that they aren't supposed to use it anymore, and... well, just say no. Even if you think you only have two roles, "admin" and "non-admin", don't store it as a boolean/bit field, normalize properly and have a permission table. – Aaronaught Nov 06 '13 at 00:37
  • @Aaronaught Yes, User.isAdmin() might be called be 30 other classes, but why is this is problem? You keep hammering on SRP, but fail to explain the nature of the risk I run by violating your definition of it. – KaptajnKold Nov 06 '13 at 08:40
  • @KaptajnKold: It's a *potential* problem (read: it depends) for all the reasons explained in my answer. I was responding to your comment that "it might just delegate" which, as I explained, is largely irrelevant in terms of SRP and dependency management. A user class with an `isAdmin` method is *responsible* for determining whether or not the user is an administrator - whether or not it performs the underlying check internally or delegates it. It's not good to couple that responsibility with authentication information because of the likelihood of each changing on different terms. – Aaronaught Nov 07 '13 at 02:40
  • @supercat Please take long discussions to a [chatroom](http://chat.stackexchange.com/rooms/13765/discussion-between-aaronaught-and-supercat) like this one that I have made for you. –  Mar 25 '14 at 13:31
28
Well, at the very least it violates single responsibility principle. Should there be changes(multiple admin levels, even more different roles?) this kind of design would be fairly messy and awful to maintain.
Consider the advantage of separating the security system from the user class, so that both can have single, well defined role. You end up with cleaner, easier to maintain design overall.
Zavior
  • 1,334
  • Yup, SRP certainly plays a role here! – Marjan Venema Nov 04 '13 at 12:43
  • Interesting. If security were not required, there might be no "User" class. I wonder if I shouldn't separate the "user-info" (name, email address, phone) into a separate record. User-info and User-permissions? – GlenPeterson Nov 04 '13 at 12:44
    @GlenPeterson: Nope, users can very well exist without security. What about my name, my display name, my address, my e-mail address etc. Where would you put those? Identification (authentication) and authorization are different beasts altogether. – Marjan Venema Nov 04 '13 at 12:53
    `class User` is a core component in the security triplet of _Identification, Authentication, Authorization_. These are intimately tied at design level, so it's not unreasonable for the code to reflect this interdependency. – MSalters Nov 04 '13 at 12:54
    The question is, should the User class contain all the logic for handling the triplet! – Zavior Nov 04 '13 at 12:57
  • @Zavior: Probably no. It should be _an API_ to access such logic. After all, there's presumably also a richer API to grant permissions, which in general wouldn't be done through the User class. But the User object, which exists by virtue of being in a security subsystem, obviously is tied to and aware of that security subsystem. – MSalters Nov 04 '13 at 13:07
    @MSalters: if it is an API to such logic, it knows about it even if it delegates elsewhere for the exact logic. The point being made is that Authorization (permissions) is about a combination of a user with something else and therefore should not be part of either the user or the something else, but part of the permissions systems that is rightly aware of both users and whatever is being given permission for. – Marjan Venema Nov 04 '13 at 13:10
  • Not sure how valid this is, but... If two systems are related in reality, they will have (maybe _should_ have) some degree of coupling in code. Seems to me that if a user represents a triplet of Identity, Authentication, and Authorization, then the user should have getters that return objects that know about those things. Like `user.getRole().isAdmin()`, `user.getIdentity().getEmail()`, etc. So the user object doesn't really know much about these other systems, but it can direct you to them. – Phil Nov 04 '13 at 15:22
    `Should there be changes` - well, we don't know that there are going to be changes. YAGNI and all. Do those changes when it becomes necessary, right? – Izkata Nov 04 '13 at 20:44
    @Phil: `user.getRole().isAdmin()` implies that a given user has only a single role. That's even worse than `user.isAdmin()`, which implies only that a given user either *is* an administrator *everywhere* or is *not* an administrator *anywhere*. – ruakh Nov 05 '13 at 05:28
13
Different contexts might have different permissions for each user. As the permissions are context-relevant, you would have to change the user for each context. So it's better you put that logic somewhere else (e.g. the context class), and just look up the permissions where needed.
A side-effect is that it might make your system more secure, because you cannot forget to clear the admin flag for places where it's not relevant.
Wilbert
  • 1,703
I think that the issue, perhaps phrased poorly, is that it puts too much weight on the User class. No, there is no security issue with having a method User.isAdmin(), as was suggested in those comments. After all, if someone is deep enough in your code to inject malicious code for one of your core classes, you have serious problems. On the other hand, it doesn't make sense for the User to decide if it is an administrator for every context. Imagine that you add different roles: moderators for your forum, editors who can publish posts to the front page, writers who can write content for the editors to publish, and so on. With the approach of putting it on the User object, you'll end up with too many methods and too much logic living on the User that isn't directly related to the class.
Instead, you could use an enum of different types of permissions, and a PermissionsManager class. Perhaps you could have a method like PermissionsManager.userHasPermission(User, Permission), returning a boolean value. In practice, it might look like (in java):
if (!PermissionsManager.userHasPermission(user, Permissions.EDITOR)) {
  Site.renderSecurityRejectionPage();
It's essentially equivalent to the Rails method before_filter method, which provides an example of this type of permissions check in the real world.
asthasr
  • 3,439
    How is that different from `user.hasPermission(Permissions.EDITOR)`, except that it is more verbose and procedural instead of OO? – Cephalopod Nov 04 '13 at 12:36
    It's a matter of style. In Java I'd probably be more likely to use a `PermissionsManager` approach because I could then replace the given object with a test double. In more dynamic languages, that's not much of a concern, so Ruby or Python would probably use a method on `User`. One could argue whether putting it on the user violates SRP, I suppose. – asthasr Nov 04 '13 at 12:39
    @Arian: because `user.hasPermissions` puts too many responsibilities into the user class. It necessitates the user knowing about permissions, while a user (class) should be able to exists without such knowledge. You don't want a user class knowing about how to print or display (build a form) itself either, you leave that to a printer renderer/builder or display renderer/builder class. – Marjan Venema Nov 04 '13 at 12:42
    `user.hasPermission(P)` is the correct API, but that's only the interface. The real decision must of course be made in a security subsystem. To address syrion's comment on testing, during testing you could swap out that subsystem. However, the benefit of the straightforward `user.hasPermission(P)` is that you do not pollute all code just so you can test `class User`. – MSalters Nov 04 '13 at 12:52
    @MarjanVenema By that logic, User would remain a data object with no responsibilities at all. I'm not saying that the entire permission management should be implemented in the user class, *if* there is need for such a complex system. You say that a user doesn't need to know about permissions, but I don't see why every other class needs to know how to resolve permissions for a user. This makes mocking and testing much harder. – Cephalopod Nov 04 '13 at 12:53
  • @MSalters: No it isn't. You are making the user class aware of stuff it really doesn't have to deal with. That it might be convenient to code it like this doesn't make it correct. – Marjan Venema Nov 04 '13 at 12:55
    @Arian: while anemic classes are a smell, some classes just don't have any behaviour... User, imho, is one such class that is better used as a parameter to a whole bunch of other stuff (who want to do things/make decisions based on who is asking for them), than being used as a container for all kinds of behaviour just because it seems convenient to code it like that. – Marjan Venema Nov 04 '13 at 12:58
Object.isX() is used to represent a clear relationship between the object and X, that can be expressed as a boolean result, for example:
Water.isBoiling()
Circuit.isOpen()
User.isAdmin() assumes a single meaning of 'Administrator' within every context of the system, that a user is, in every part of the system, an administrator.
While it sounds simple enough, a real world program will almost never fit this model, there will most certainly be a requirement for a user to administer [X] resource but not [Y], or for more distinct types of administrators (a [project] administrator vs a [system] administrator).
This situation usually requires an investigation of the requirements. Rarely, if ever, will a client want the relationship that User.isAdmin() actually represents, so I would hesitate to implement any such solution without clarification.
FMJaguar
  • 3,039
The poster merely had a different and more complicated design in mind. In my opinion, User.isAdmin() is fine. Even if you later introduce some complicated permissions model, I see little reason to move User.isAdmin(). Later, you may want to split the User class into an object representing a logged-in user and a static object representing the data about the user. Or you may not. Save tomorrow for tomorrow.
kevin cline
  • 33,608
  • 71
  • 142
    `Save tomorrow for tomorrow`. Yeah. When it you figure out that the tightly coupled code you just wrote has pigeonholed you and you have to rewrite it because you didn't take the extra 20 minutes to decouple it... – MirroredFate Nov 04 '13 at 16:37
    @MirroredFate: It is entirely possible to have a `User.isAdmin` method connected to an arbitrary permission mechanism without coupling the User class to that specific mechanism. – kevin cline Nov 04 '13 at 17:43
    For User.isAdmin to be coupled to an arbitrary permissions mechanism, even without coupling to a specific mechanism, requires... well... coupling. The minimum of which would be to an interface. And that interface should simply not be there. It is giving the user class (and interface) something for which it should simply not be responsible. [Aaronaught](http://programmers.stackexchange.com/a/216481/1324) explains it a lot better than I can (as does the combination of all other answers to this question). – Marjan Venema Nov 04 '13 at 18:57
    @MirroredFate: I don't care if I have to rewrite a simple implementation to meet more complex requirements. But I have had really bad experiences with overly complex APIs designed to meet imagined future requirements that never arose. – kevin cline Nov 04 '13 at 19:58
    @kevincline While overly-complex APIs are (by definition) a bad thing, I was not suggesting that one should write overly-complex APIs. I was stating that `Save tomorrow for tomorrow` is a terrible design approach because it makes problems that would be trivial if the system was implemented correctly far worse. In fact, that mentality is what results in overly-complex APIs, as layer upon layer is added to patch up the initial poor design. I guess my stance is `measure twice, cut once`. – MirroredFate Nov 04 '13 at 22:33
    Responding specifically to the "save tomorrow for tomorrow" debate: There's a well-known quote in the scientific community: *A month in the laboratory can often save an hour in the library.* Developers should not try to anticipate future *business requirements* in their code, but there's no excuse for failing to understand or follow well-known and well-tested industry standards, unless there's a clear rationale. Security is a particularly sensitive area because the cost of a mistake is extraordinarily high - privilege elevation, leaked passwords, that sort of thing. So think before coding. – Aaronaught Nov 05 '13 at 00:25
    @Aaronaught: this is true, but it has little to do with whether or not the User class has an 'isAdmin' method. It has everything to do with the implementation of user authentication. – kevin cline Nov 05 '13 at 17:46
Not really a problem...
I don't see a problem with User.isAdmin(). I certainly prefer it to something like PermissionManager.userHasPermission(user, permissions.ADMIN), which in the holy name of SRP makes the code less clear and does't add anything of value.
I think SRP is being interpreted a little to literally by some. I think it's fine, even preferable for a class to have a rich interface. SRP just means that an object must delegate to collaborators anything that doesn't fall within it's single responsibility. If the admin role of a user is something more involved than a boolean field, it might very well make good sense for the user object to delegate to a PermissionsManager. But that doesn't mean that it isn't also a good idea for a user to keep it's isAdmin method. In fact it means that when your application graduates from simple to complex, you want have to change the code that uses the User object. IOW, your client doesn't need to know what it really takes to answer the question of whether or not a user is an admin.
... but why do you really want to know?
That said, It seems to me like you rarely need to know if a User is an admin except to be able to answer some other question, like whether or not a user is allowed to perform some specific action, say like updating a Widget. If that is the case, I would prefer to have a method on Widget, like isUpdatableBy(User user):
boolean isUpdatableBy(User user) {
    return user.isAdmin();
That way a Widget is responsible for knowing what criteria must be satisfied for it to be updated by a user, and a user is responsible for knowing if it is an admin. This design communicates clearly about its intentions and makes it easier to graduate to more complex business logic if and when that time comes.
[Edit]
The problem with not having User.isAdmin() and using PermissionManager.userHasPermission(...)
I thought I would add to my answer to explain why I greatly prefer calling a method on the User object to calling a method on a PermissionManager object if I want to know if a user is an admin (or has an admin role).
I think it's fair to assume that you are always going to depend on the User class wherever you need to ask the question is this user an admin? That's a dependency you cannot get rid of. But if you need to pass the user to a different object to ask a question about it, that creates a new dependency on that object on top of the one you already have on the User. If the question gets asked a lot, that's a lot places where you create an extra dependency, and it's a lot of places you may have to change if either of dependency demand it.
Compare this with moving the dependency into the User class. Now, suddenly you have a system where client code (code that needs to ask the question is this user an admin) is not coupled to the implementation of how this question get answered. You are free to change the permission system completely, and you only have to update one method in one class to do it. All the client code remains the same.
Insisting on not having an isAdmin method on the User for fear of creating a dependency in the User class on the permissions subsystem, is to my mind akin to spending a dollar to earn a dime. Sure, you avoid one dependency in the User class, but at the cost of creating one in every place where you need to ask the question. Not a good bargain.
KaptajnKold
  • 933
    "SRP just means that an object must delegate to collaborators anything that doesn't fall within it's single responsibility" - *false*. The definition of the SRP encompasses everything that an object does directly **and** everything it delegates. A class that only performs one task directly, but performs 50 other tasks indirectly via delegation, is still (probably) violating the SRP. – Aaronaught Nov 04 '13 at 23:09
  • KaptajnKold: I +1'd because I agree with you and I feel a little guilty about that. Your post adds to the discussion, but it doesn't answer the question. – GlenPeterson Nov 05 '13 at 00:28
  • @GlenPeterson Well, I tried to address the part of the question which was 'what it looks like done "right"' Also: You should absolutely not feel guilty about agreeing with me :) – KaptajnKold Nov 05 '13 at 12:49
  • `admins.Contains(user)` would be more appropriate to identify if a user is a group member. – James Snell Nov 05 '13 at 13:30
    @JamesSnell Maybe. If. But that's an implementation detail which I would still confine within the isAdmin method on User. That way your client code doesn't have to change when the "admin-ness" of a User evolves from being a boolean field to something more advanced. You might have many places where you need to know if a User is an admin and you don't want to have to change them every time your authorisation system changes. – KaptajnKold Nov 05 '13 at 13:55
  • @KaptajnKold - `IsAdmin` is useful only if you work on the assumption that being admin is Boolean and global and will never change. As soon as the permissions become more granular then everything that touches it will need a rewrite. – James Snell Nov 05 '13 at 14:58
    @JamesSnell Maybe we misunderstand each other? The question of _whether or not a user is an admin_ is not the same as the question of _whether or not a user is permitted to perform a specific action_. The answer to the first question is always independent from the context. The answer to the second is very much dependent on the context. This is what I tried to address in the second half of my original answer. – KaptajnKold Nov 05 '13 at 15:23
  • KaptajnKold: You stated my own viewpoint more eloquently than I: "if you need to pass the user to a different object to ask a question about it, that creates a new dependency" So true! However, I tried to keep my viewpoint out of my question, because my goal in posting here is to understand the *opposing* viewpoint. What is "other" right way to do this why it's desirable. Wilbert wrote the answer in a comment: If user permissions apply differently in different contexts, you cannot meaningfully store them on the user. They then belong on a user-context relationship. – GlenPeterson Nov 07 '13 at 12:46
  • @GlenPeterson I agree, and part of my answer was that it is the Context (_Widget_ in my example) that is responsible for deciding what a given User is permitted to do. It may decide based on the Role of the User (is it an Admin? Does it have at least 50 karma points?) or on whether the User has some special relationship with the Context (think of a file or a blog post: Is the User the owner or the creator?) or on some other policy (Is the User on the list? Is it monday?). Whatever the policy though, you should still only depend on the User object and the Context object in the client code. – KaptajnKold Nov 13 '13 at 09:05
  • @Aaronaught Bob Martin (who coined the term SRP) clearly doesn't agree with your definition of SRP: http://butunclebob.com/ArticleS.UncleBob.SrpInRuby – KaptajnKold Nov 20 '13 at 09:28
  • If you read the *article*, you'll see that it doesn't even come close to justifying your position. It's talking about a form of mixins, or, alternatively, what the .NET world calls partial classes (there are probably similar concepts in other frameworks). This does not in any way mean that it is OK for an object to have redundant responsibilities because it delegates, it's just a semi-convenient tool for combining SRP with encapsulation, and not without risk as the comments clearly indicate. This isn't about *physical* construction of a class, it's about the *semantics* of responsibilities. – Aaronaught Nov 20 '13 at 15:19
  • I was adressing your claim that a class that indirectly performs 50 tasks not directly related to its area of responsibility, is in violation of SRP. I claim that it is not, if the responsibility of actually performing the work is kept out of the class. This is the point of view that the article lends weight to, and I'm baffled that you don't see that. It is obvious that Robert Martin sees no problem with a class having a wide interface that exposes behavior it is not itself directly responisble for. In fact he seems to consider it a good thing. – KaptajnKold Nov 22 '13 at 10:39
This discussion reminded me of a Blog Post by Eric Lippert, which was brought to my attention in a similar discussion about class design, security and correctness.
Why Are So Many Of The Framework Classes Sealed?
In particular, Eric raises the point:
  1. Secure. the whole point of polymorphism is that you can pass around objects that look like Animals but are in fact Giraffes. There are potential security issues here.
Every time you implement a method which takes an instance of an unsealed type, you MUST write that method to be robust in the face of potentially hostile instances of that type. You cannot rely upon any invariants which you know to be true of YOUR implementations, because some hostile web page might subclass your implementation, override the virtual methods to do stuff that messes up your logic, and passes it in. Every time I seal a class, I can write methods that use that class with the confidence that I know what that class does.
This may seem like a tangent, but I think it dovetails with the point other posters have raised about the SOLID single-responsibility principle. Consider the following malicious class as a reason not to implement a User.IsAdmin method or property.
public class MyUser : User
    public new boolean IsAdmin()
        // You know it!
        return true;
    // Anything else we can break today?
Granted, it's a bit of a stretch: no one yet suggested making IsAmdmin a virtual method, but it could happen if your user/role architecture ended up being bizarrely complex. (Or perhaps not. Consider public class Admin : User { ... }: such a class might have exactly that code above in it.) Getting a malicious binary into place is not a common attack vector and has a lot more potential for chaos than an obscure user library - then again, this could be the Privilege Escalation bug that opens the door to the real shenanigans. Finally, if a malicious binary or object instance did find its way into the run time, it's not much more of a stretch to imagine the "Privilege or Security System" being replaced in a similar manner.
But taking Eric's point to heart, if you put your user code in a particular type of vulnerable system, maybe you did just lose the game.
Oh, and just to be precise for the record, I agree with the postulate in the question: “A user shouldn't decide whether it is an Admin or not. The Privileges or Security system should.” A User.IsAdmin method is a bad idea if you are running the code on system you do not remain in 100% control of the code - you should instead do Permissions.IsAdmin(User user).
Glorfindel
  • 3,137
Patrick M
  • 246
  • Huh? How is this pertinent? No matter where you put the security policy, you could always potentially subclass it with something insecure. It doesn't matter if that something is a User, Principal, Policy, PermissionSet, or whatever. It's a totally unrelated issue. – Aaronaught Nov 04 '13 at 23:11
  • It's a security argument in favor of Single Responsibility. To directly answer your point, the security & permissions module is darn well going to be a sealed class, but certain designs might desire the User class to be virtual & inherited. It's the last point on the blog article (thus perhaps the least likely/important?), and perhaps I'm conflating the issues a bit, but given the source, it's clear that polymorphism can be a security threat and therefore limiting the responsibilities of a given class/object is more secure. – Patrick M Nov 04 '13 at 23:31
  • I'm not sure why you say that. Lots of security and permissions frameworks are highly extensible. Most of the core .NET types related to security (IPrincipal, IIdentity, ClaimSet, etc.) are not only *not* sealed but are in fact interfaces or abstract classes so that you can plug in whatever you want. What Eric is talking about is that you wouldn't want something like `System.String` to be inheritable because all kinds of critical framework code makes very specific assumptions about how it works. In practice, most "user code" (including security) is inheritable to allow for test doubles. – Aaronaught Nov 05 '13 at 00:15
    Anyway, polymorphism isn't mentioned anywhere in the question, and if you follow the author's link to where the original comment was made, it's clear that it wasn't referring to inheritance or even class invariants in general - it was about responsibilities. – Aaronaught Nov 05 '13 at 00:17
  • I know it wasn't mentioned, but the principle of class responsibilities is directly related to polymorphism. If there isn't an `IsAdmin` method to override/co-opt, there isn't a potential security hole. Reviewing the methods of those system interfaces, `IPrincipal` and `IIdentity`, it's clear that the designers disagree with me, and so I concede the point. – Patrick M Nov 05 '13 at 06:03
The problem here is:
if (user.isAdmin()) {
   doPriviledgedOp();
} else {
   // maybe we can anyway!
   doPriviledgedOp();
Either you have set up your security properly in which case the privileged method should check if the caller has sufficient authority -- in which case the check is superfluous. Or you have not and are trusting an un-priviledged class to make its own decisions on security.
James Anderson
  • 18,049
  • 42
  • 72
    What is an unpriviledged class? – Brandon Nov 05 '13 at 02:55
    There really is nothing you can do to prevent this sort of code from being written. No matter how you design your app, *somewhere* there is going to be an explicit check like this, and *someone* could write it to be insecure. Even if your permissions system is as streamlined as decorating a method with a role or permission attribute - somebody could incorrectly throw a "public" or "everyone" permission on it. So I don't really see how this makes a method like `User.IsAdmin` *specifically* a problem. – Aaronaught Nov 06 '13 at 00:29
Security is a tricky topic. There's not always clean clear-cut answers.
In some very simplistic systems, user.isAdmin() may be a completely legitimate approach. This is especially true if
  • There is only one meaning for "admin" in the context of the system
  • A user either is an admin, or is not.
The latter is something that creates pitfalls. Consider the case of revoking admin access from a user. How is it done? Every user class needs to have been written in a way that handles all possible revocations. The worst case scenario is when an employee is fired, their admin is revoked, and after they have been fired, they have access to an old "user" object that still has admin.
This has the potential to make "User" a spider's nest of functionality, handling not just admin but other similar user attributes that may have different revocation rules managed by different groups. It's a pain.
That being said, I have seen a pattern where user.isAdmin() is a thin wrapper that just makes a call to the correct permissions system. And that can be fine too. However, you have now added security-critical elements to User, so you have to make sure all future updates to User are reviewed with a security mindset (and likely by individuals who can speak for a security organization). Patrick M points out an obvious example of what could go wrong here. Make sure it was worth it!
Cort Ammon
  • 10,840
  • 32
