Is it legal to use a third party library in a software project that is itself licensed under MPL 2.0?
So some potential project hierarchies would look like this
  • Library Project [MPL 2.0] (Open Source, Distributed)
    • Third party library [Proprietary] (Closed source, not distributed)
  • Someone else's project [MPL 2.0] (Open source, distributed)
My practical feeling is that this is fine otherwise there could be no use of this license on many platforms whose base libraries are proprietary, like on iOS for example. The only difference being that these libraries are distributed to registered developers.
gnat
  • 21,442
  • 112
  • 288
nacross
  • 123
It should be sufficient to just read the MPL.
3.2. If You distribute Covered Software in Executable Form then:
  • Such Covered Software must also be made available in Source Code Form, as described in Section 3.1, and You must inform recipients of the Executable Form how they can obtain a copy of such Source Code Form by reasonable means in a timely manner, at a charge no more than the cost of distribution to the recipient; and
  • You may distribute such Executable Form under the terms of this License, or sublicense it under different terms, provided that the license for the Executable Form does not attempt to limit or alter the recipients’ rights in the Source Code Form under this License.
3.3. Distribution of a Larger Work
  • You may create and distribute a Larger Work under terms of Your choice, provided that You also comply with the requirements of this License for the Covered Software. If the Larger Work is a combination of Covered Software with a work governed by one or more Secondary Licenses, and the Covered Software is not Incompatible With Secondary Licenses, this License permits You to additionally distribute such Covered Software under the terms of such Secondary License(s), so that the recipient of the Larger Work may, at their option, further distribute the Covered Software under the terms of either this License or such Secondary License(s).
So the MPL isn't viral in the sense that the GPL is. MPL software can't be re-licensed under your own incompatible license, but you can distribute it with any other code under any other license as long as the other license doesn't conflict with the MPL (as the GPL does), and as long as you still distribute the MPL source.
Also, if you're not distributing the software to anyone, then the discussion is moot, as you're not required to distribute source to anyone to whom you don't distribute binaries.
tylerl
  • 4,850
  • 32
  • Thanks tylerl, The intention would be to distribute the MPL licensed project. For me it still isn't clear whether I am violating the MPL by relying on third-party code/libraries that I do not have any right/desire to distribute myself. – nacross Oct 15 '13 at 06:51
    @nacross: If you are not distributing those third-party libraries at all (not even as a binary), then there is no question about license violations. You can't violate a license by not distributing something that isn't even subject to that license. But it does raise the question what value your project has to others. – Bart van Ingen Schenau Oct 15 '13 at 07:37
  • @BartvanIngenSchenau Right so in my example about Apples iOS CocoaTouch libraries, linking against these proprietary libraries would not violate the license because I never distribute these libraries. Based on that logic however I would not be able to use something like http://pspdfkit.com/ in this project because I would be distributing it in binary form, and the license for this library is proprietary and not compatible with MPL? – nacross Oct 15 '13 at 08:36
    @nacross: Your conclusion about pspdfkit.com does not follow. I don't know the details of that license, but most closed-source licenses are *not* incompatible with the MPL, as both licenses usually restrict themselves only to the code that is explicitly covered by it (in contrast to a copyleft license like the GPL). – Bart van Ingen Schenau Oct 16 '13 at 06:32
    @BartvanIngenSchenau thanks for clearing that up I didn't understand that point. – nacross Oct 16 '13 at 07:46
