This week I could optimize using a reduced C library that allowed a drastic shrinkage in code size - from about 60 K to about 6 K and then we could load the code in the 8 K on-chip memory of an FPGA (Altera DE2) which I suppose is SRAM so there is SRAM both on-chip and off-chip(?)
The program was rather small itself and we noticed that most of the size was from libraries and doing embedded system we reduce the libraries to only what is needed so that the footprint is minimized.
It makes me wonder about something I heard in the media which was a story, maybe fictious, that Microsoft had to deliver a C compiler in only 20 K or so in the 70s or early 80s when there was not much memory available for software, is it true? What is a feasible size of the footprint for a small C compiler?
Niklas Rosencrantz
  • 8,008
  • 56
  • 95
    You may wish to investigate an existing project such as http://bellard.org/tcc/ – Greg Hewgill Oct 11 '13 at 04:32
  • I'm not sure about how legit Microsoft's story is, but this should give you an idea on how small the first c compiler is https://github.com/mortdeus/legacy-cc . its around 50K for the source, might be smaller once compiled. – Maru Oct 11 '13 at 04:45
    The size of the compiler has nothing to do with the size of the binaries it generates, which seemed to be your problem (unless you're putting the compiler on the fpga) – James Oct 11 '13 at 08:19
    use the optimization setting for space instead of for speed – ratchet freak Oct 11 '13 at 08:45
The Software Toolworks C compiler for CP/M came on one 8" SSSD floppy, and compiled most of the language as of about 1982. It required a machine with 56K of memory and one floppy drive. I don't remember how much the resident portion of CP/M required.
Turbo Pascal 1.0 required 64K on a CP/M machine, and included an IDE. It was a single-pass compiler, written in heavily-optimized assembly language, and did EVERYTHING in RAM, making it BLINDINGLY fast. (Bill Gates was reportedly NOT happy about it: it made Microsoft look really bad.)
John R. Strohm
  • 18,043
  • 56
    I remember Turbo Pascal 1.0. It compiled in 10 *seconds* a program I wrote that took 10 *minutes* to compile on an Apple IIe using the Apple Pascal compiler. – Robert Harvey Oct 11 '13 at 05:46
  • Says a lot, if you think about it: the authors of Turbo Pascal didn't use Pascal inside their compiler. It might be fast, but the code produced clearly wasn't that efficient. – MSalters Oct 11 '13 at 09:43
  • @MSalters: Well, Pascal as a language wasn't designed specifically for writing compilers. People could still get the same performance that the compiler got by writing their programs the way Borland wrote their compiler, with the accompanying tradeoffs. I think that there is a general sense in the programming community that all languages should be capable of everything, but that's just not reality. FWIW programs written and compiled in Turbo Pascal did perform pretty well. Microsoft's C# compiler is written in C++; the Mono compiler is self-hosting. – Robert Harvey Oct 12 '13 at 02:27
  • @MSalters: The code wasn't terribly efficient, but it was loads better than BASIC. Further, I had a free third-party tool to take a suitably-formatted assembly-language source file and produce an "inline" directive, using `>identifier` and similar notations to identify variables by name. The difference between what the compiler generated and optimal code was more significant for small routines than big ones, so a dozen or so lines of assembly could in some cases allow a ten-fold *overall* performance boost. – supercat Feb 20 '15 at 19:46
  • @RobertHarvey: FYI, the most recent version of the C# compiler is written in C#. – supercat Feb 20 '15 at 19:47
  • @supercat: Thanks for pointing out the obvious on a post that's over a year old. – Robert Harvey Feb 20 '15 at 21:22
Writing a tiny C compiler is easy, if you don't care about the performance of the generated code. TinyCC (originally by F.Bellard, now here) is such a compiler: it compiles quite quickly C programs (perhaps with a compilation time 5 to 10 times faster than GCC ...) but the produced executable is very slow (often more than 3 times slower than what gcc -O2 gives you). And nwcc is small, but probably generates slow code (w.r.t. what gcc -O2 can produce). The tcc compiler (i.e. TinyCC) is quite small (a few dozens of thousand lines of C code) and the executable (on x86-64) is about 190Kbytes.
But on current processors, you need an optimizing compiler to get most of the performance from the compiled executable code. And good optimizations are hard to achieve and need a big lot of compiler code: both GCC and Clang/LLVM have several millions lines of source code (some of which is generated by specific programs producing C or C++ code). See also this reply to a related question.
Basile Starynkevitch
  • 32,434
  • 84
  • 125
