I am a bit in a dilemma: Let's suppose I have a very general function and a specialization of it for convenience reasons. Let's also assume that the specialized function is used 90 per cent of the time, hence being "the common case".
Should I use a shorter function name for the general case (e.g. do
) and a longer
one for the special (do_something_special
) or the other way around (e.g.
do_something_general
and do
)? When applying Larry Wall's words (make simple
things easy and hard ones possible), I'd use a shorter form for the more often
used case.
EDIT: Just to make this a bit more clear: in this example, do
is just a placeholder for a short, descriptive name. Of course it could be longer, e.g. run_task
or process_file
. What I want to know is, if I have a function called run_task_in_specific_way
that is used most of time should actually be called run_task
(although being more specific) or the general abstraction.
EDIT 2: To clarify once more: The functions I am talking about are neither providing more than one functionality nor should they be replaced by a class-based design. The reason is: they are abstract in the same sense as qsort, e.g. taking callable from users to fulfill a specific action. Wrapping them into some auxiliary class does not make much sense.
