Separating out different parts of a web application from each other as separate wars means that one can stop and restart individual applications at the application server and possibly simplifies the access control on each application. The separate applications means that, in theory one can deploy changes to the admin (take it off line, redeploy it) while the main application is still running (note that theory is emphasized - more on this later).
Thats really about it for benefits. One might see some very slight performance increase on the admin pages because of a reduced number of sessions there. It is unlikely one would see any improved performance on the main application.
Now the implications that make this much more challenging and take away some of the possible gains.
Consider if you have a user
object. This has methods on it like changePassword
that can be done by the admin or the user.
Consider these two options:
- you're using hibernate or some other orm to annotate the user table to the user object
- you've got a data access layer running native queries against the database
You again have two options for these:
- two copies of the user object / data layer - one in each war
- one external jar that both wars load
Whenever you make a schema change (anything that necessitates updating the user or the data layer) you will either have at least twice as much work (reload both applications and make sure they stay in sync), or you will have to reload the shared jar and restart both applications (and if the app server is being fussy, restart it).
At the end of the day, you are going to find that you have copied the entire set of data objects (and data layer). The admin may have a few more, but likely everything that is in the main app will be in the admin.
There is a real damager of bugs if the two duplicate the data/model. Furthermore, you'll find yourself duplicating views (the admin view of a user update page vs the main app view of a user update page).
Ultimately, you'll likely find that there are only minor differences in the authorization between the two applications - you want to share the same authentication, the same data, and likely the same views. They are just different controllers for admin and normal user.
From this, its likely best to just keep it all as one application. Don't Repeat Yourself. Don't duplicate the views and don't duplicate the models.
