So, what you're saying is that the software acts one way when the software is in one state and another thing when the software is in another state. Well, welcome to the State Pattern.
The short story is that you want two classes, each implementing the same interface. the interface should have two methods -- OnMachineConnectSelected and OnMachineDoubleClick.
The first class is called DisconnectedState, the second class is called ConnectedState.
- DisconnectedState performs Connect and ShowWindow from OnMachineConnectSelected.
- DisconnectedState performs Connect from OnMachineDoubleClick.
- ConnectedState performs ShowWindow from both OnMachineConnectSelected and OnMachineDoubleClick.
(It's hard to tell without more specifics, but you can and probably should have Connect and ShowWindow as methods on your form or other application object and pass a reference, probably via another interface, into the constructor of your state class.)
Now your application simply needs an object on which it can call those methods, as the actions occur, and you can switch that object between an instance of DisconnectedState and ConnectedState as the actual state of your application changes.
See what this does for you?
First, it models your application very well. Look at the bullet-points above. You wouldn't have to rearrange the words much to explain what was going on to a user or non-technical manager. You are separating out the concepts of state (software/hardware decisions) and action (user decisions) neatly.
Second, it allows for extensibility. When you realise that you need to act very differently, while connecting and disconnecting, you can simply add two new state classes. Or if you need to add a new action that depends on the state, you can simply add a new method to all your state objects.
Third, it is more maintainable. When a business person says "Hey, currently, when the application is Disconnected and you Select Connect on a machine, it Connects and Shows the Window; but we want it to simply connect," you know EXACTLY where that logic exists in the code and can edit it easily, safe in the knowledge that you aren't breaking any of the other conditions.
Finally, it's more unit-testable. There is only one path through each method. Pass a mock form into your class constructor, call the OnX method and make sure it performs the right actions. And, on the form, you can test that your action calls the right method, no matter what state it's in.
