In C#, functional programming is a proper tool when you have to navigate through collections. In those cases, functional programming makes the code much shorter and helps focusing on the problem instead of its implementation, while reducing the risk of making mistakes.
You can hardly be accountable of reducing the codebase and the margin for errors by using a proper tool.
The issue you have with your colleagues, I have it in the company I'm currently working in. Most programmers there don't know very well neither C#, nor programming in general, which makes me a not so popular person, given that my colleagues have a hard time understanding the code which uses parallel programming, functional paradigms, code contracts and other features of .NET Framework.
One of the rules each developer should follow is that their code should be understandable in a given context. This conflicts with the fact that one shouldn't be forced to reduce code quality just because he works with unskilled people.
There are two solutions:
Teach your colleagues functional programming and other things you know and they don't, trying to increase their level at yours. This is what I've chosen in my case and what I would suggest to anyone.
Pros: the quality of the codebase will only increase, and you may appreciate better to work with more skilled colleagues.
Cons: many programmers don't want to learn things. They work for money, and they don't care about their work. Trying to teach them anything would be an extremely difficult task and one should be ready to receive heavy resistance.
Start writing crappy code written for beginners. Given that this may be disastrous for the motivation, this solution should be taken only when working with people who are unable and/or unwilling to learn and in a circumstance when you can quit soon.
Pros: this can enhance relations with coworkers if they don't want to learn things and don't want to make effort reading your code.
Cons: this will decrease the quality of the codebase. Working on badly done projects which would inevitably fail is not very motivating.
Finally, should programmers know functional programming? It depends. It would be mandatory for any person who works daily with C# to know what are anonymous types and lambda expressions and how to use them in C#; on the other hand, I wouldn't say that the same person who don't know what a monad is should be treated as an incompetent.
The difference is that anonymous types and lambda expressions are the inherent part of C# nowadays, while the term monad doesn't exist in C# world.
On the other hand, I'm expecting a developer to be familiar to functional programming concepts like monads, even if this developer never used them. This is because developers are expected not only to write code in a given language, but have enough general culture and curiosity beyond the tools they use daily.
