I'm replacing a guy who was in his first job as a programmer. You'd think being fresh out of school means the basics are fresh in one's mind, but think again.
The code base is horrible, Ctrl+C / Ctrl+V is apparent in lots of areas, about 60% of the logic is coded in forms and the rest is in a monstruous module called helpers. It hits the database in a If condition and re-hits the database with the exact same query inside the Else part. In general, it's as if declaring a variable had a higher cost than hitting the database or querying XML with an xPath.
Logic is scattered between stored procedures, table-valued functions (with an inexistent naming convention so you don't know if you're looking for a SP or a TVF) and inline SQL (string concatenations), and the seldom comment will just rephrase the code it's commenting.
Complex conditional logic is written in nested If blocks with a cyclomatic complexity that's just off the charts, in arrow-shaped procedures that can reach 1200 lines of code.
I can deal with all of the above... to a certain degree. But recently I came across something that just blew my mind.
The author was declaring a String variable with a meaningful name (call it smurfName), passed it to a table-valued function to get an integer value, and then used that integer value to determine another string value that gets used further down the process, here's a simplified illustration:
Dim smurfName As String
smurfName = (run some inline xPath on a IXMLDOMNode to get a string value)
smurfName = (call a helper to run inline SQL, pass smurfName as a parameter, returns a count)
If smurfName = 0 Then
    smurfName = "abc"
ElseIf smurfName > 1 Then
    smurfName = "def"
End If
smurfName = (call another SQL procedure, pass smurfName as a parameter)
And it just keeps going.
Is reusing a variable (/giving it a new meaning) a common practice or it's just another "WTF" in that code base I'm stuck with? Is there any valid reason for doing that? If not, then what drives a programmer to work like this? I'm a self-taught programmer, maybe this guy knows things that I don't (I didn't know about xPaths until I saw them in that code base), but when I tried understanding the meaning of that variable, this picture came to my mind:
WTFs/Minute
Mathieu Guindon
  • 1,720
  • @pdr posted a good link. In short, that is generally a code smell. Reuse of variables generally means that items should be moved into smaller methods that stand alone. BTW, I like the cartoon. ;) – RobM Aug 18 '13 at 17:42
0 Answers0
