Problem Description
I am wanting to use voice recognition as part of a hardware project, which I would like to be completely self containing (I'm using small low power, low speed devices such as Arduino's and Raspberry Pi's, Kinects etc, no running traditional computer with an OS is involved. So a closed / self containing project).
Voice recognition can be very complicated depending on the level of sophistication you desire. I have what I believe a comparatively simple set of requirements. I only want to recognise my own voice, and I have a small dictionary of 20 or so words I'd like to recognise. Thus I don't require complex speech-to-text and voice recognition libraries or any of the excellent 3rd party software I find via Internet search engines (there is no shortage of these!). I believe my requirements are "simple enough" (within reason) that I can code my own solution. I am wondering if anyone has written their own process like this, and is my method is massively flawed? Is there a better way to do this without requiring a high level of mathematics or having to write a complex algorithm? That is the solution I have tried to think up below.
Solution Description
I will be writing this in C but I wish to discuss a language agnostic process, focussing on the process its self. So lets ignore that if we can.
1 . I will pre-record my dictionary of words to match those being spoken. We can imagine I have 20 recordings of my 20 different words, or perhaps short phrases or sentences of two or three words. I believe this makes the process of comparing two recording files easier than actually converting the audio to text and comparing two strings.
2 . A microphone is connected to my hardware device running my code. [1]. The code is continuously taking fixed length samples, say 10msec in length for example, and storing 10 consecutive samples for example, in a circular logging style. [2]. (I'm inventing these figures off the top of my head so they are only examples to describe the process).
[1] This would likely be connected through a band-pass filter and op-amp, as would the dictionary recordings be made, to keep the stored and collected audio samples smaller.
[2] I'm not sure exactly how I will take a sample, I need to work out a method though were I produce a numerical figure (integer/float/double) that represents the audio of a 10msec sample (perhaps a CRC value or MD5 sum etc of the audio sample), or a stream of figures (a stream of audio readings of frequencies perhaps). Ultimately a "sample" will be a numerical figure or figures. This part is going to be much more hardware involved so not really for discussion here.
3 . The code looks at it's stored 10 consecutive samples and looks for a volume increase to indicate a word or phrase is being said (a break from silence) and then increases is consecutive sample collecting to say 500 samples for example. That would mean it captures 5 seconds of audio in 10 msec samples.
It is these samples or "slices" that are compared between the stored sound and captured sound. If a high enough percentage of samples captured matched the equivalent stored ones, the code assumes its the same word.
The start of a store recording of the world "hello" for example,
stored words are split into 10 msec samples also
Stored Sample No | 1| 2| 3| 4| 5| 6| 7| 8|
Stored Sample Value |27|38|41|16|59|77|200|78|
Incoming audio (me saying "hello") with some "blank" samples
at the start to symbolise silence
Incoming Sample No | 1| 2| 3| 4| 5| 6| 7| 8| 9|10| 11|12|
Incoming Sample Value | | | |20|27|38|46|16|59|77|200|78|
4 . Once the code has collected a full sample stream, it then chops off the blanks samples at the start to produce the following audio recording. It could also move the sample set backwards and forwards a few places to better align with the stored sample.
This produces a sample set like the below:
Incoming Sample No |-1| 1| 2| 3| 4| 5| 6| 7| 8|
Incoming Sample Value |20|27|38|46|16|59|81|201|78|
5 . I believe that by having a percentage value for how close each sample must be, so sample 7 differs by a value of 1 which is less than %1, and a percentage value for the total number of samples which must be within their sample matching percentage, the code has an easily tunable level of accuracy.
I have never done anything like this with audio before, it could be a lot of work. This is why I am asking this question, if you perhaps already know the answer to this question to be obvious (what ever that answer may be). I am hoping this won't be a computationally massive tasks as some of the hardware I will be using will be low sec stuff. In the hundreds of Megahertz (Maybe 1Ghz using an over-clocked Rasp Pi). So this is a rather crude way to match audio samples using lower computational power. I'm not aiming for instant results, but less than 30 seconds for a decent proof of concept.
PS I don't have the rep to tag this with a new tag like "audio", "audio recognition", "voice", "voice recognition" etc.
