This question is intended to apply to any OO programming language that supports exception handling; I am using C# for illustrative purposes only.
Exceptions are usually intended to be raised when an problem arises that the code cannot immediately handle, and then to be caught in a catch
clause in a different location (usually an outer stack frame).
Q: Are there any legitimate situations where exceptions are not thrown and caught, but simply returned from a method and then passed around as error objects?
This question came up for me because .NET 4's System.IObserver<T>.OnError
method suggests just that: exceptions being passed around as error objects.
Let's look at another scenario, validation. Let's say I am following conventional wisdom, and that I am therefore distinguishing between an error object type IValidationError
and a separate exception type ValidationException
that is used to report unexpected errors:
partial interface IValidationError { }
abstract partial class ValidationException : System.Exception
public abstract IValidationError[] ValidationErrors { get; }
(The System.Component.DataAnnotations
namespace does something quite similar.)
These types could be employed as follows:
partial interface IFoo { } // an immutable type
partial interface IFooBuilder // mutable counterpart to prepare instances of above type
bool IsValid(out IValidationError[] validationErrors); // true if no validation error occurs
IFoo Build(); // throws ValidationException if !IsValid(…)
Now I am wondering, could I not simplify the above to this:
partial class ValidationError : System.Exception { } // = IValidationError + ValidationException
partial interface IFoo { } // (unchanged)
bool IsValid(out ValidationError[] validationErrors);
IFoo Build(); // may throw ValidationError or sth. like AggregateException<ValidationError>
Q: What are the advantages and disadvantages of these two differing approaches?
