What is the real use of interfaces in Java? What is meant by programming to interfaces?
I heard these things several times but I don't know what it is and why it is used.
One day, a junior programmer was instructed by his boss to write an application to analyze business data and condense it all in pretty reports with metrics, graphs and all that stuff. The boss gave him an XML file with the remark "here's some example business data".
The programmer started coding. A few weeks later he felt that the metrics and graphs and stuff were pretty enough to satisfy the boss, and he presented his work. "That's great" said the boss, "but can it also show business data from this SQL database we have?".
The programmer went back to coding. There was code for reading business data from XML sprinkled throughout his application. He rewrote all those snippets, wrapping them with an "if" condition:
if (dataType == "XML")
... read a piece of XML data ...
else
.. query something from the SQL database ...
When presented with the new iteration of the software, the boss replied: "That's great, but can it also report on business data from this web service?" Remembering all those tedious if statements he would have to rewrite AGAIN, the programmer became enraged. "First xml, then SQL, now web services! What is the REAL source of business data?"
The boss replied: "Anything that can provide it"
An interface is a simple contract.
The interface defines methods and you can call methods on any object that implements this interface. It does not matter which object this is.
Also an object can implement multiple interfaces and therefore you can see this as implementing different contracts.
By programming against the interfaces you do not depend on a certain class and can replace the implementation without changing the rest of you code.
As example:
If you use List
in your application you can switch between LinkedList
and ArrayList
without changing your code.
You program to an interface because it's easier to handle. The interface encapsulates the behavior of the underlying class. This way, the class is a blackbox. Your whole real life is programming to an interface. When you use a tv, a car, a stereo, you are acting on its interface, not on its implementation details, and you assume that if implementation changes (e.g. diesel engine or gas) the interface remains the same. Programming to an interface allows you to preserve your behavior when non-disruptive details are changed, optimized, or fixed. This simplifies also the task of documenting, learning, and using.
Also, programming to an interface allows you to delineate what is the behavior of your code before even writing it. You expect a class to do something. You can test this something even before you write the actual code that does it. When your interface is clean and done, and you like interacting with it, you can write the actual code that does things.
