53
There are answers to the question on how test classes that connect to a database, e.g. "Should service test classes connect ..." and "Unit testing - Database coupled app".
So, in short let's assume you have a class A that needs to connect to a database. Instead of letting A actually connect, you provide A with an interface that A may use to connect. For testing you implement this interface with some stuff - without connecting of course. If class B instantiates A it has to pass a "real" database connection to A. But that means B opens a database connection. That means to test B you inject the connection into B. But B is instantiated in class C and so forth.
So at which point do I have to say "here I fetch data from a database and I will not write a unit test for this piece of code"?
In other words: Somewhere in the code in some class I must call sqlDB.connect() or something similar. How do I test this class?
And is it the same with code that has to deal with a GUI or a file system?
I want to do Unit-Test. Any other kind of test is not related to my question. I know that I will only test one class with it (I so agree with you Kilian). Now, some class has to connect to a DB. If I want to test this class and ask "How do I do this" many say: "Use Dependency Injection!" But that only shifts the problem to another class, doesn't it? So I ask, how do I test the class that really, really establishes the connection?
Bonus question: Some answers here boil down to "Use mock objects!" What does that mean? I mock classes that the class-under-test depend upon. Shall I mock the class-under-test now and actually test the mock (which comes close to the idea of using Template Methods, see below)?
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
TobiMcNamobi
  • 1,171
  • Is it the database connection that you are testing? Would creating a temporary in memory database (such as [derby](http://db.apache.org/derby/)) be acceptable? –  Jul 30 '13 at 14:23
  • @MichaelT Still I have to replace the temporary in memory DB with a real database. Where? When? How is it unit tested? Or is it OK not to unit test this code? – TobiMcNamobi Jul 30 '13 at 14:33
    There is nothing to "unit test" about the data base. It is maintained by other people, and if there were a bug in it, you would have to let them fix it rather than do it yourself. The only thing that should differ between actual use of your class and use during tests should be the parameters of the database connection. It is unlikely that the property-file reading code, or the Spring injection mechanism or whatever you use to weave your app together is broken (and if it were, you couldn't fix it yourself, see above) - so I consider it acceptable not to test this bit of plumbing functionality. – Kilian Foth Jul 30 '13 at 14:39
    @KilianFoth that is purely related to work environment and employee roles. It doesn't really have anything to do with the question. What if there is no one person responsible for the database? – Reactgular Jul 30 '13 at 14:57
  • Some mocking frameworks allow you to inject mock objects into pretty much anything, even into private and static members. This makes testing with things like mock db connections sooo much easier. Mockito + Powermock is what works for me these days (they're Java, not sure what you're working in). – FrustratedWithFormsDesigner Jul 30 '13 at 15:58
  • Tests that involve an actual database are not unit tests; they are *integration* tests. – Robert Harvey Aug 01 '13 at 16:03
6 Answers6
31
The point of a unit test is to test one class (in fact, it should usually test one method).
This means that when you test class A, you inject a test database into it - something self-written, or a lightning-fast in-memory database, whatever gets the job done.
However, if you test class B, which is a client of A, then usually you mock the entire A object with something else, presumably something that does its job in a primitive, pre-programmed way - without using an actual A object and certainly without using a database (unless A passes the entire database connection back to its caller - but that's so horrible I don't want to think about it). Likewise, when you write a unit test for class C, which is a client of B, you would mock something that takes the role of B, and forget about A altogether.
If you don't do that, it's no longer a unit test, but a system or integration test. Those are very important as well, but a whole different kettle of fish. To begin with, they are usually more effort to set up and run, it isn't practicable to demand to pass them as a precondition to check-ins, etc.
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
14
Performing unit tests against a database connection is perfectly normal, and a common practice. It's simply not possible to create a purist approach where everything in your system is dependency injectable.
The key here is to test against a temporary or testing only database, and having the lightest possible start up process for building that test database.
For unit testing in CakePHP there are things called fixtures. Fixtures are temporary database tables created on the fly for a unit test. The fixture has convenience methods for creating them. They can recreate a schema from a production database inside the testing database, or you can define the schema using a simple notation.
The key to success with this is to not implement the business database, but to focus only on the aspect of the code you are testing. If you have a unit test that verifies that a data model reads only published documents, then the table schema for that test should only have the fields required by that code. You don't have to re-implement an entire content management database just to test that code.
Some additional references.
http://en.wikipedia.org/wiki/Test_fixture
http://phpunit.de/manual/3.7/en/database.html
http://book.cakephp.org/2.0/en/development/testing.html#fixtures
Reactgular
  • 13,040
  • 81
  • 42
    I disagree. A test requiring a database connection is not a unit test, because the test by its very nature will have side effects. That doesn't mean you can't write an automated test, but such a test is by definition an integration test, exercising areas of your system beyond your codebase. – KeithS Jul 30 '13 at 14:59
  • @KeithS what side effects????? – Reactgular Jul 30 '13 at 15:03
  • I assume he means you are dependent on the data in the DB, but you simply set up a DB connection in your unit test framework, start a transaction, truncate the relevant tables, insert known data, then rollback at the end. Its exactly how you unit test a stored procedure, for example. – gbjbaanb Jul 30 '13 at 15:17
  • @gbjbaanb yea, that is what fixtures do in CakePHP. They build and insert the data for you, easily and quickly. It doesn't change unless you change the unit test. The majority of Cake developers have a database they can use for testing. – Reactgular Jul 30 '13 at 15:19
    Call me a purist, but I hold to the tenet that a unit test should not perform any actions that leave the "sandbox" of the testing runtime environment. They shouldn't touch databases, file systems, network sockets, etc. This is for several reasons, not the least of which is dependency of the test on external state. Another is performance; your unit test suite should run quickly, and interfacing with these external data stores slow tests by orders of magnitude. In my own development, I use partial mocks to test things like my repositories, and I'm comfortable defining an "edge" to my sandbox. – KeithS Jul 30 '13 at 15:29
    @gbjbaanb - That sounds fine at first, but in my experience it's very dangerous. Even in the best-architected test suites and frameworks, the code to rollback this transaction may not execute. If the test runner crashes or is aborted inside a test, or the test throws out a SOE or OOME, best-case is you have a hanging connection and transaction in the DB that will lock up the tables you touched until the connection's killed. The ways you prevent this causing problems, such as using SQLite as a test DB, have their own downsides, for instance the fact you're not *really* exercising the *real* DB. – KeithS Jul 30 '13 at 15:38
    @KeithS I think we're debating over semantics. It's not about what the definition of a unit test is or an integration test is. I use fixtures to test code dependant upon a database connection. If that's an integration test, than I'm fine with that. I need to know that test passes. I couldn't care about the dependencies, performance or risks. I won't know if that code works unless that test passes. For the majority of tests there are no dependencies, but for the ones where there are, then those dependencies can't be uncoupled. It's easy to say they should be, but they simply can't be. – Reactgular Jul 30 '13 at 15:45
    I think we are as well. I use a "unit-testing framework" (NUnit) for my integration tests as well, but I do make sure to segregate these two categories of tests (often in separate libraries). The point I was trying to make is that your unit test suite, the one you run several times a day prior to each check-in as you follow the iterative red-green-refactor methodology, should be completely isolatable, so that you *can* run these tests several times a day without stepping on your co-workers' toes. – KeithS Jul 30 '13 at 16:35
  • @KeithS What if your code is a database abstraction layer? Should one simply assert on the generated SQL string and then replicate nearly identical tests for the integration suite? – leo Aug 01 '13 at 16:34
    @leo: yes, because they would test two different things. The unit test, asserting on generated SQL, would assert that the SQL matched what you expected the generator to produce, which is what you want to know when you're coding the generator. The integration test that used this SQL to retrieve results from the RDBMS would then test many other things, mostly ensuring that the generator, when plugged in, works as expected in the larger system. – KeithS Aug 01 '13 at 16:40
    Testing against a database is fine, but that's not a _unit_ test. That's an integration test. – 425nesp Dec 01 '16 at 19:49
    Never test against a database in unit tests. which is suppose to be isolated and fast. – Jeryl Cook Sep 20 '19 at 15:54
  • If you're a nodejs dev, you should check out my lib https://github.com/oguimbal/pg-mem to get rid of the isolation problem :) – Olivier Aug 03 '20 at 08:44
There is, somewhere in your codebase, a line of code that performs the actual action of connecting to the remote DB. This line of code is, 9 times in 10, a call to a "built-in" method provided by the runtime libraries specific to your language and environment. As such, it's not "your" code and so you don't need to test it; for the purposes of a unit test, you can trust that this method call will perform correctly. What you can, and should, still test in your unit test suite are things like ensuring the parameters that will be used for this call are what you expect them to be, such as making sure the connection string is correct, or the SQL statement or stored procedure name.
This is one of the purposes behind the restriction that unit tests should not leave their runtime "sandbox" and be dependent upon external state. It's actually quite practical; the purpose of a unit test is to verify that the code you wrote (or are about to write, in TDD) behaves the way you thought it would. Code that you didn't write, such as the library you are using to perform your database operations, shouldn't be part of the scope of any unit test, for the very simple reason that you didn't write it.
In your integration test suite, these restrictions are relaxed. Now you can design tests that touch the database, to make sure that the code you did write plays nicely with code you didn't. These two test suites should remain segregated, however, because your unit test suite is more effective the faster it runs (so you can quickly verify that all the assertions made by developers about their code still hold), and almost by definition, an integration test is slower by orders of magnitude because of the added dependencies on external resources. Let the build-bot handle running your full integration suite every few hours, executing the tests that lock up external resources, so that the developers aren't stepping on each other's toes by running these same tests locally. And if the build breaks, so what? A lot more importance is placed on ensuring the build-bot never fails a build than probably should be.
Now, how strictly you can adhere to this is dependent on your exact strategy for connecting to and querying the database. In many cases where you must use the "bare-bones" data access framework, such as ADO.NET's SqlConnection and SqlStatement objects, an entire method developed by you may consist of built-in method calls and other code that is dependent on having a database connection, and so the best you could do in this situation is mock the entire function and trust your integration test suites. It also depends on how willing you are to design your classes to allow specific lines of code to be replaced for testing purposes (such as Tobi's suggestion of the Template Method pattern, which is a good one because it allows "partial mocks" that exercise some methods of a real class while overriding others that have side effects).
If your data persistence model relies on code in your data layer (such as triggers, stored procs, etc) then there simply is no other way to exercise code you yourself are writing than to develop tests that either live inside the data layer or cross the boundary between your application runtime and the DBMS. A purist would say this pattern, for this reason, is to be avoided in favor of something like an ORM. I don't think I'd go quite that far; even in the age of language-integrated queries and other compiler-checked, domain-dependent persistence operations, I see the value in locking the database down to only the operations exposed via stored procedure, and of course such stored procedures must be verified using automated tests. But, such tests are not unit tests. They are integration tests.
If you have a problem with this distinction, it's usually based on a high importance placed on complete "code coverage" aka "unit test coverage". You want to ensure every line of your code is covered by a unit test. A noble goal on its face, but I say hogwash; that mentality lends itself to anti-patterns stretching far beyond this specific case, such as writing assertionless tests that execute but do not exercise your code. These types of end-runs solely for the sake of coverage numbers are more harmful than relaxing your minimum coverage. If you want to ensure that every line of your codebase is executed by some automated test, then that's easy; when computing code coverage metrics, include the integration tests. You could even go one step further and isolate these disputed "Itino" tests ("Integration in name only"), and between your unit test suite and this sub-category of integration tests (which should still run reasonably fast) you should get darn near close to full coverage.
KeithS
  • 21,994
  • 52
  • 79
Unit tests should never connect to a database. By definition, they should test a single unit of code each (a method) in total isolation from the rest of your system. If they don't, then they are not a unit test.
Semantics aside, there are a myriad of reasons why this is beneficial:
  • Tests run orders of magnitude faster
  • Feedback loop becomes instant (<1s feedback for TDD, as an example)
  • Tests can be run in parallel for build/deploy systems
  • Tests don't need a database to be running (makes build much easier, or at least quicker)
Unit tests are a way to check your work. They should outline all of the scenarios for a given method, which typically means all of the different paths through a method. It is your specification that you are building to, similar to double-entry bookkeeping.
What you are describing is another type of automated test: an integration test. While they are also very important, ideally you will have much less of them. They should verify that a group of units integrate with each other properly.
So how do you test things with database access? All of your data access code should be in a specific layer, so your application code can interact with mockable services instead of the actual database. It shouldn't care whether those services are backed by any type of SQL database, in-memory test data, or even remote webservice data. That is not their concern.
Ideally (and this is very subjective), you want the bulk of your code covered by unit tests. This gives you confidence that each piece works independently. Once the pieces are built, you need to put them together. Example - when I hash the user's password, I should get this exact output.
Let's say that each component is made up of roughly 5 classes - you'd want to test all of the points of failure within them. This equates to a lot less tests just to ensure everything is wired properly. Example - test you can find the user from the database given a username/password.
Finally, you want some acceptance tests to actually ensure you are meeting business objectives. There are even less of these; they may ensure the application is running and does what it was built to do. Example - given this test data, I should be able to log in.
Think of these three types of tests as a pyramid. You need a lot of unit tests to support everything, and then you work your way up from there.
Adrian Schneider
  • 1,809
Testing with external data is integration test. Unit test means you are testing the unit only. It is mostly done with your business logic. To make your code unit testable you have to follow some guidelines, like you have to make your unit independent from other part of your code. During unit test if you need data then you need to forcefully inject that data with dependency injection. There are some mocking and stubbing framework out there.
Arnab
  • 377
The Template Method Pattern might help.
You wrap the calls to a database in protected methods. To test this class you actually test a fake object which inherits from the real database connetion class and overrides the protected methods.
This way the actual calls to the database are never under unit tests, that's right. But it's only these few lines of code. And that is acceptable.
TobiMcNamobi
  • 1,171
    In case you wonder why I answer my own question: Yes, this **could** be an answer but I am quite unsure if it is the right one. – TobiMcNamobi Jul 30 '13 at 14:35
