looking for a specific use case where both a subclass and a class within the same package needs to access a protected field or method...
Well to me, such a use case is rather general than specific, and it stems from my preferences to:
- Start with as strict access modifier as possible, resorting to weaker one(s) only later as deemed necessary.
- Have unit tests reside in the same package as tested code.
From above, I can start designing for my objects with default access modifiers (I would start with private
but that would complicate unit testing):
public class Example {
public static void main(String [] args) {
new UnitTest().testDoSomething(new Unit1(), new Unit2());
static class Unit1 {
void doSomething() {} // default access
static class Unit2 {
static class UnitTest {
void testDoSomething(Unit1 unit1, Unit2 unit2) {
unit1.doSomething();
unit2.doSomething();
Side note in above snippet, Unit1
, Unit2
and UnitTest
are nested within Example
for simplicity of presentation, but in a real project, I would likely have these classes in separate files (and UnitTest
even in a separate directory).
Then, when a necessity arises, I would weaken access control from default to protected
public class ExampleEvolved {
protected void doSomething() {} // made protected
// ---> no changes needed although UnitTest doesn't subclass
// ...and, hey, if I'd have to subclass... which one of Unit1, Unit2?
You see, I can keep unit test code in ExampleEvolved
unchanged due to protected methods being accessible from the same package, even though accessing object is not a sub-class.
Less changes needed => safer modification; after all I changed only access modifiers and I did not modify what methods Unit1.doSomething()
and Unit2.doSomething()
do, so it is only natural to expect unit test code to continue run without modifications.
