19
JVM supports so many languages other than Java like Groovy,Clojure,Scala etc which are functional languages unlike Java(I am referring to Java before Version 8 where Lambda's are not supported) that doesn't support functional capabilities.On a high level what makes the JVM so versatile that it can support both Object Oriented as well as Functional languages?
Geek
  • 5,107
  • 40
  • 58
  • "Groovy,Clojure,Scala etc which are functional". Some of those are more functional than others. I would use a scale with Groovy the least funcional and Clojure the most, with Scala in the middle. – Vorg van Geir Nov 11 '13 at 23:48
Compared to other VMs, the JVM actually isn't particularly versatile. It directly supports statically typed OO. For everything else, you have to see what parts you can use, and how you can build everything else your language needs on top of those parts.
For example, until Java 7 introduced the invokedynamic bytecode, it was very hard to implement a dynamically typed OO language on the JVM - you had to use complex workarounds that were bad for performance and resulted in horribly bloated stack traces.
And yet, a bunch of dynamic languages (Groovy, Jython, JRuby among others) were implemented on the JVM before that.
Not because the JVM is so versatile, but because it is so widespread, and because it has very mature, well-supported and high-performing implementations.
And, perhaps even more important, because there is a huge amount of Java code out there doing pretty much anything, and if your language runs on the JVM, you can easily offer facilities to integrate with that code. Basically, having your language run on the JVM is the 21st century version of offering interoperability with C.
Michael Borgwardt
  • 51,037
  • 124
  • 176
    Good answer (+1). The last point you mention is IMHO also responsible for the popularity of Java as a language: in the end, having a huge amount of code you can reuse for free can save you much more time than being able to use the latest and most fashionable language features. – Giorgio Jul 14 '13 at 13:05
The JVM was written to basically act like a CPU, there is a set of instructions, kind of like assembly, that the VM runs called bytecodes. If you can write a compiler that generates a valid set of bytecodes, then the JVM can run them.
Wikipedia has a list of the bytecodes:
http://en.wikipedia.org/wiki/Java_bytecode_instruction_listings
as well as an explanation of how the JVM loads the byte codes:
http://en.wikipedia.org/wiki/Java_virtual_machine
By using the invoke style bytecodes, a functional language can execute code, regardless of what the source looks like. Also, with the addition of invokevirtual, language implementations like jruby have been giving some flexibility with how they run.
sasbury
  • 262
    The same thing is true for every single other VM out there: the YARV Ruby VM, the Rubinius Ruby VM, the CPython VM (which after all predates the JVM), Parrot, various Smalltalk and Lisp VMs, and of course the Pascal P-Code system, after which the JVM is modeled. – Jörg W Mittag Jul 15 '13 at 00:47
  • Agreed, the JVM is definitely not the first VM out there. I think the JVM is popular for other languages because Java is popular, the VM is actively developed and well documented. – sasbury Jul 16 '13 at 02:19
I'll add that the JVM supports a well defined and pretty decent Memory Model (JMM) which means good support for consistent (albeit low level) threading behaviour. It also has a powerful Just In Time compiler (no more useful for dynamic languages thanks to MethodHandles and invokedynamic).
Last but not least is the JVM's Garbage Collection sub-system which (with the right tuning) manages memory for you regardless of the language on top.
Martijn Verburg
  • 22,006
  • 49
  • 81
  • The JMM is one of my least favorite things about Java. I'm a fan of effectively-immutable data (e.g. arrays whose contents will never change after they're visible to other threads), but given a statement like `someField = new int[]{42};` the only ways of ensuring that any thread that sees the new array will see the value 42 are to either make the field `final` or `volatile`. If the field is lazily generated but accessed frequently, making it `final` won't work, and making it `volatile` may impose a needless synchronization penalty every time it is accessed. In even the loosest .NET model... – supercat Feb 04 '15 at 21:29
  • ...code could request that the population of the array happen before the store of the reference. Other threads which read the field might or might not see the reference to the new array, but would at no cost to themselves be assured that if they see the new array, they'll see its content. – supercat Feb 04 '15 at 21:32
The key element in this is the separation of the compilation from the execution phase. By this it is possible to write other compilers compiling other languages to bytecode.
Bytecode there acts similar to machine code of a CPU - you have all the little operations needed to run a program - you can get a variable, do math on it, have conditional operations etc.
Java also isn't special. In Java the existance of multiple languages wasn't even a design goal, unlike other VMs. For Microsoft's .Net CIL the ability to run multiple languages (C#, VB.Net, ...) was a key design element, also the ParrotVM from the Perl6 project aimed to be a generic VM.
For the fun of it I once created a proof that even PHP's Zend Engine would allow that.
And frankly this isn't anything new - even on real hardware you can run multiple languages - i.e. C or Fortran.
The difference to this separation from compilation and execution are clssic interpreters, like some forms of Basic, shell scripts, etc. they often work in a way that they execute code more or less in a line by line way without bringing it in an immediate form in between.
johannes
  • 3,601
  • 26
  • 32
The JVM is the first virtual machine I'm aware of which combined garbage collection, performance, and a workable sandbox model. The emergence of many languages to support the JVM is probably not so much a result of its "versatility", but rather the fact that the Java language lacks some significant features that people want in a programming language. For example, while most machine languages have only half a dozen or so data types (e.g. byte, halfword, word, double-word, single-precision float, and double-precision float), the vast majority of programming languages allow code to use an arbitrary number of user-defined data types. The JVM recognizes a few primitive types similar to those on a typical machine, plus one more type: the Promiscuous Object Reference. The Java language likewise recognizes those primitives, and Promiscuous Object References. While a variable may be constrained not to hold references to anything that isn't a particular class, the language makes no distinctions between any of the following kinds of field of type List<String> that might be held by instance MyThing class MyClass:
  • A reference to something code knows to be an immutable implementation of List<String>
  • A reference to an instance of a mutable list type which will never be exposed to anything that might mutate it.
  • A reference to a mutable list to which, except during the execution of MyThings's methods, no other reference could possibly exist anywhere in the universe.
  • A reference to a mutable list which is owned by some other object, which that other object would like MyThing to use in some fashion.
  • A reference to a mutable list which MyThing owns, but which it has also exposed to some other objects so they may do something with it.
Even though all of those fields could have type List<String>, they hold very different things. An expressive language might allow a distinction among those meanings, but Java does not. Since a language could attach meaning to such things (at least outside generic contexts) and run on the JVM, that leaves a lot of room for JVM-targetted languages to express concepts which Java cannot.
supercat
  • 8,335
