I was working with a query I wrote today had to change the code from the WHERE
clause to use a IN(list of stuff) filter instead of using something like
item_desc = 'item 1'
OR item_desc = 'item 2'
OR item_desc = 'item 3'
OR item_desc = 'item 4'
The above ran for 15 minutes and returned nothing, yet the following gave me my result set in 1.5 minutes
item_desc IN (
'item 1'
,'item 2'
,'item 3'
,'item 4'
I did this in SQL and am wondering why the IN(list of items) performed so much faster then the OR statement.
-- EDIT -- SQL Server 2008, I do apologize for not putting this bit of info in in the first place.
Here is the Query in its entirety using the OR
statements:
DECLARE @SD DATETIME
DECLARE @ED DATETIME
SET @SD = '2013-06-01';
SET @ED = '2013-06-15';
-- COLUMN SELECTION
SELECT PV.PtNo_Num AS 'VISIT ID'
, PV.Med_Rec_No AS 'MRN'
, PV.vst_start_dtime AS 'ADMIT'
, PV.vst_end_dtime AS 'DISC'
, PV.Days_Stay AS 'LOS'
, PV.pt_type AS 'PT TYPE'
, PV.hosp_svc AS 'HOSP SVC'
, SO.ord_no AS 'ORDER NUMBER'
--, SO.ent_dtime AS 'ORDER ENTRY TIME'
--, DATEDIFF(HOUR,PV.vst_start_dtime,SO.ent_dtime) AS 'ADM TO ENTRY HOURS'
, SO.svc_desc AS 'ORDER DESCRIPTION'
, OSM.ord_sts AS 'ORDER STATUS'
, SOS.prcs_dtime AS 'ORDER STATUS TIME'
, DATEDIFF(DAY,PV.vst_start_dtime,SOS.prcs_dtime) AS 'ADM TO ORD STS IN DAYS'
-- DB(S) USED
FROM smsdss.BMH_PLM_PtAcct_V PV
JOIN smsmir.sr_ord SO
ON PV.PtNo_Num = SO.episode_no
JOIN smsmir.sr_ord_sts_hist SOS
ON SO.ord_no = SOS.ord_no
JOIN smsmir.ord_sts_modf_mstr OSM
ON SOS.hist_sts = OSM.ord_sts_modf_cd
-- FILTER(S)
WHERE PV.Adm_Date BETWEEN @SD AND @ED
AND SO.svc_cd = 'PCO_REMFOLEY'
OR SO.svc_cd = 'PCO_INSRTFOLEY'
OR SO.svc_cd = 'PCO_INSTFOLEY'
OR SO.svc_cd = 'PCO_URIMETER'
AND SO.ord_no NOT IN (
SELECT SO.ord_no
FRROM smsdss.BMH_PLM_PtAcct_V PV
WHERE OSM.ord_sts = 'DISCONTINUE'
ORDER BY PV.PtNo_Num, SO.ord_no, SOS.prcs_dtime
Thank you,
