22
I'm currently examining the possibilities and implications of linking against a GPL library for an application in a commercial context.
From what I've understood of the GPL, as long as the application is used internally there is no obligation to release its code (even if a copy is moved to a controlled subsidiary).
What I don't understand is the following point from the FAQ :
If a library is released under the GPL (not the LGPL), does that mean that any software which uses it has to be under the GPL or a GPL-compatible license? Yes, because the software as it is actually run includes the library.
If I take a look at the GPL-compatible licenses, some of them (like the boost one) don't seem to impose the release of the code. Using it would create a situation where you could be compliant with the GPL licence without having to respect its obligation of making your code public (which doesn't seem very credible).
(NB : there are components in Adobe Photoshop licensed under boost and I don't think the code is available on demand)
The most reasonable explication would be that I'm missing something... Could you please tell me where I made a mistake ?
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
Louis Morazzani
  • 321
How are GPL-compatible licenses like MIT usable in GPL programs without being subject to the copyleft provision?
Short answer: They're not. They'll become subject to the copyleft.
Long answer:
The Wikipedia article on license compatibility has a good section on GPL compatibility:
Many of the most common free software licenses, such as the original MIT/X license, ... are "GPL-compatible". That is, their code can be combined with a program under the GPL without conflict (the new combination would have the GPL applied to the whole).
[emphasis added]
And more explicitly from the FSF FAQ on GPL compatibility:
It means that the other license and the GNU GPL are compatible; you can combine code released under the other license with code released under the GNU GPL in one larger program.
And just for edification, here's the FSF's comments on various licenses
FSF's comment on the boost license
This is a lax, permissive non-copyleft free software license, compatible with the GNU GPL.
Which means that anything licensed under Boost is easily subsumed by the GPL.
Where it gets tricky
Let's say we have project Foo licensed under Boost, and project Bar licensed under GPL and which wants to use Foo.
Bar+Foo is allowed since the licenses are compatible, and the release of Bar+Foo must be GPL as Bar is GPL. Foo, by itself and without Bar or Bar+Foo, is still available under the Boost license. Said another way, Bar+Foo has no license impact upon Foo itself.
The resulting license of the project combination is a forward acting event for the combination only. It is not a retroactive event.
So if someone else wants to take Foo and do something else with it, they are still free to do so without the copyleft provision of the GPL. However, if they take Bar+Foo, delete Bar and only use +Foo then they are still bound by the terms of the GPL since Bar+Foo was GPL'd.
Your other question:
This is directly answered by the FSF GPL FAQ on source distribution
The GPL does not require you to release your modified version, or any part of it. You are free to make modifications and use them privately, without ever releasing them. This applies to organizations (including companies), too; an organization can make a modified version and use it internally without ever releasing it outside the organization.
Wholly owned subsidiaries are considered part of the parent organization, so you would legally be in the clear. FSF would point out that you are violating the spirit of Free Software though.
    I wonder: If an employee is *using* the [unpublished modified version](http://www.gnu.org/licenses/gpl-faq.html#GPLRequireSourcePostedPublic) in the company, would he have the right to get the source code from the company? – unor Jul 12 '13 at 11:46
  • @GlenH7 : thanks for your very helpful explication (especially the "Where it gets tricky" part) – Louis Morazzani Jul 15 '13 at 07:35
    @unor - No, that would constitute a private use by the Company (the employee is part of the company, not a separate entity). – iheanyi May 23 '14 at 21:26
  • "However, if they take Bar+Foo, delete Bar and only use +Foo then they are still bound by the terms of the GPL since Bar+Foo was GPL'd." Are you sure? Foo was still licensed under the Boost license. As I understand it, the Boost license shouldn't be removed, even when combined with GPL code. ("The [...] above license grant, this restriction and the following disclaimer, must be included in all copies of the Software, in whole or in part, and all derivative works of the Software [...]") – lesderid Mar 23 '16 at 15:55
  • @lesderid - you have to trace the distribution of the source of the project. `Foo` is available under the Boost license. But `+Foo` (e.g. `Bar+Foo` minus `Bar`) is bound to the GPL. If you go to the original providers of `Foo`, then you can use `Foo` under the Boost terms. But if you go to the providers of `Bar` and `Bar+Foo`, then they are giving you `+Foo` which reflects different license terms. Yes, it's the exact same source. But the licensing terms differ based upon the distribution channel. –  Mar 23 '16 at 17:42
    @GlenH7 Sure, but would they even be allowed to relicense `Foo` under the GPL? Sublicensing would be fine, but then they would also have to keep the Boost license in `Bar+Foo`, would they not? – lesderid Mar 23 '16 at 18:00
    I've always questioned if this would hold up in law, however...something that belongs to the MIT license arbitrarily having its license "replaced" but maybe what it is is that the project "as a whole" must have restrictions at least as open as the GPL, but, one they do that, the certain parts of them that are MIT could be extracted and "redistributed" as just MIT? Maybe. Or maybe something else... – rogerdpack Feb 27 '20 at 20:29
  • "FSF would point out that you are violating the spirit of Free Software though." -- can somebody give a reference to this claim? This seems like an assumption and I'm not sure it's true. FSF and the GPL explicitly allow doing that after all. – VasyaNovikov Feb 16 '22 at 20:55
By "GPL-compatible", they mean, a license that does not conflict with the GPL. A less restrictive license, like the Boost license, is "compatible" with the GPL because it doesn't restrict users of the code from doing anything that the GPL would allow a user to do. That is, the Boost license allows people to copy freely, which is what the GPL requires people are allowed.
An example of a license that is not "compatible" would be a license that required a fee to the original authors for users to distribute copies. Since the GPL explicitly permits both free and paid distribution, this more restrictive license would not be compatible.
In other words, the GPL says "You must allow $A, $B and $C". Any license that allows $A, $B, $C and also $D and $E is compatible. A license that allowed $A and $B but not $C would not be.
Maximus Minimus
  • 1,498
Gort the Robot
  • 14,733
  • 51
  • 60
    So the new, combined work is wholly licensed under the GPL, correct? But the original code licensed under MIT can still be distributed separately under MIT without running afoul of the GPL, correct? – Robert Harvey Jul 11 '13 at 05:08
    IANAL, but yes, that is how it works. – Fabio Fracassi Jul 11 '13 at 06:31
    "_because it doesn't restrict users of the code from doing anything that the GPL would allow a user to do_" - And also because it doesn't prevent the user from doing anything that the GPL would require them to do. – Ross Patterson Jul 11 '13 at 11:03
    Minor nitpick but the GPL doesn't actually forbid charging fees for just about anything; see http://www.gnu.org/licenses/gpl-faq.html#DoesTheGPLAllowMoney – Maximus Minimus Jul 11 '13 at 19:37
  • Sorry, that was poorly worded. I meant that it forbids requiring fees for code that has already been downloaded. – Gort the Robot Jul 11 '13 at 22:51
  • I still think the wording is misleading; the GPL doesn't actually contain anything to the effect that it forbids requiring charges; it's own wording is quite permissive on the topic of charges: "you may charge", etc. It would be more accurate to say that the GPL permits both free and paid distribution, but a license that forbade (or required, for that matter) either wouldn't be compatible. That would also cover the case where a license that *required* free distribution is also incompatible. – Maximus Minimus Jul 11 '13 at 23:29
    I am pretty sure the GPL allows anyone to charge for distribution, but does not allow people to require others to charge if they distribute themselves. In other words, I can charge you for a copy, but I can't require you to send me a payment if you give a copy to a third party. – Gort the Robot Jul 12 '13 at 19:55
You didn't make a mistake: the FAQ answer was incomplete. It should have said that the combined program must be licensed under the GPL, not a GPL compatible licence. It has since been corrected (see below: I have emphasised the important bit):
Yes, because the program actually links to the library. As such, the terms of the GPL apply to the entire combination. The software modules that link with the library may be under various GPL compatible licenses, but the work as a whole must be licensed under the GPL. See also: What does it mean to say a license is “compatible with the GPL”?
I had earlier said that "if a library is released under the GPL then any software which uses it has to be under the GPL itself due to its so-called 'viral' nature. A permissive GPL-compatible license such as boost cannot be used." By "software which uses it" I meant the combined modules and library.
  • I believe that this is a common misunderstanding. It isn't necessary to release *your* part of the code under the GPL, as long as it has a compatible license. The license for your part can also be more permissive, but not less, than the GPL. Only the *combined* work remains under the GPL, so the additional restrictions of the GPL apply only if one uses your code together with the linked GPL library. See https://www.gnu.org/licenses/gpl-faq.html#GPLModuleLicense – ert Mar 07 '19 at 07:21
    Yes, that's right. My original answer could have been misinterpreted. Happily it's all moot now, as Gnu have updated their FAQ to say the right thing. – Bennett McElwee Mar 07 '19 at 21:55
