52
I am a young programmer (finished computer science university but still under a year of working in the industry) and I recently got a job working on some C code for a decent size web service. Looking at the code the only places I saw comments were when people were stashing their old code. Function and variable names are similarly informative most of the time - futex_up(&ws->g->conv_lock[conv->id%SPIN]);. Confronting a senior programmer about the situation and explaining that adding comments and meaningful names would make the code more maintainable and readable in the future, I got this reply:
In general, I hate comments. Most of them time, like the case you mention with the return value, people use comments to get around reading the code. The comments don't say anything other than what the guy thought the code does at the time he put in the comment (which is often prior to his last edit). If you put in comments, people won't read the code as much. Then bugs don't get caught, and people don't understand the quirks, bottlenecks, etc. of the system. That's provided the comments are actually updated with code changes, which is of course totally unguaranteed.
I want to force people to read the code. I hate debuggers for a similar reason. They are too convenient and allow you to step through dirty code with watches and breakpoints and find the so-called problem, when the real problem was that there are bugs in the code because the code has not been simplified enough. If we didn't have the debugger, we would refuse to read ugly code and say, I have to clean this up just so I can see what it is doing. By the time you are done cleaning up, half the time the bug just goes away.
While what he wrote goes against a lot I have been taught in the university, it does make some sense. However, since experience in the studies sometimes doesn't work in real life, I would like to get an opinion of people more vetted in code.
Is the approach of avoiding commenting code to make people actually read the code and understand what is going on make sense in a medium-sized coding environment (one that can be reasonably read in whole by every person working on it within a month or two), or is it a recipe for a long-term disaster? What are the advantages and disadvantages of the approach?
gnat
  • 21,442
  • 112
  • 288
ThePiachu
  • 288
  • 53
    Anybody who says he hates debuggers has never had to find/fix a hardware bug. – Carl Norum Jun 15 '13 at 17:02
    "While what he wrote goes against a lot I have been tough[sic] in the university" - Funny how often this happens, and not just in programming and at universities. – Kevin Jun 15 '13 at 17:30
  • 26
    He hates comments and debuggers (a.k.a. he doesn't use them) and he calls himself a senior developer ? You still call him that ? No offense, but he should really pick up some books/articles about programming best practices from the 21st century. To be more specific: if the code is self-explanatory, then comments are indeed not needed. But when they are, you should put as many comments as necessary. – Radu Murzea Jun 15 '13 at 21:18
    Senior programmers aren't always the most qualified. They maybe just haven't moved on to better jobs. – Fuhrmanator Jun 15 '13 at 21:48
    Debuggers are very useful when [accidental complexity (vs essential complexity)](http://faculty.salisbury.edu/~xswang/Research/Papers/SERelated/no-silver-bullet.pdf) is high. Bad code is a form of unnecessary complexity, so I agree that debuggers are not intended as tools for this. – Fuhrmanator Jun 15 '13 at 21:55
    Linus Torvalds has some strong opinions on debuggers ( "Without a debugger, you basically have to go the next step: understand what the program does."): http://lwn.net/2000/0914/a/lt-debugger.php3 – timday Jun 15 '13 at 22:00
    You should be able to step through a piece of code in your head. In C programming this is even more important than in other languages since a task is usually expressed in several lines of code (while other languages would allow to wrap it up in another abstraction). I.e. you have to start your mental-debugger and be able to trace through these lines without invoking the debugger. The debugger is still useful of course since your brain can be tricked, but the point is that you should have the basic understanding first. – wirrbel Jun 15 '13 at 22:08
    I tend to agree with what he says about comments. Well written code tends to be self documenting. There are of course exceptions where comments make sense. I've always been taught that the code documents what is, the comments document why. If the why is obvious, then leave it out. But disliking debuggers, whaaat? – ConditionRacer Jun 15 '13 at 22:16
    "I saw comments were when people were stashing their old code." is another red flag. That's supposed to be what the version control system is for. – user16764 Jun 15 '13 at 22:30
    As a junior programmer I hated code without comments; as a senior developer I find code with too many comments is probably badly written. Rewrite the code until it *doesn’t need comments*. If after attempts to simplify the code it still need comments, then the comments are probably well-justified. There is no excuse for badly named variables or classes however. Name things ***well*** people. – mxcl Jun 15 '13 at 23:48
  • To certain extent I agree on the comments part, debuggers are powerful and not evil at all. I've seen programmers asking questions that could be easily answered in the documentation, and there's no need for a comment when you have hundreds of pages worth of knowledge that a new hire MUST read before touching any code. – ILikeTacos Jun 16 '13 at 01:01
    His point about comments I can agree with somewhat; code should explain by itself what it does and why. If you are going to add a clarifying comment, try to make the code say it instead. The problem with your example, though, is that the code example you posted is NOT clear. If that's what the code looks like, it needs to be refactored to make its intent clear. – Dave Cousineau Jun 16 '13 at 06:28
    see also: [“Comments are a code smell”](http://programmers.stackexchange.com/questions/1/comments-are-a-code-smell) _"A coworker of mine believes that any use of in-code comments... is a code smell..."_ – gnat Jun 16 '13 at 07:06
    He didn't give an explanation for the bad variable names. When you use few comments you need good variable names to make the code easy to read. – CodesInChaos Jun 16 '13 at 12:35
    Your co-worker stance on comments and debuggers is a nice example of "Throwing out the baby with the bath water". – plmaheu Jun 16 '13 at 13:37
    Don't worry about the horse being blind; just load the wagon. – JeffO Jun 16 '13 at 14:15
    Why did my car stop running? This gauge is pointing to the letter `E`. After reading the diagram on how this gauge works. It says `red` wire needs an electrical current to point the needle to the letter `F`. I connected it to a battery, but the car still will not start. Clearly there is something wrong with the diagram for the gauge. – Reactgular Jun 16 '13 at 15:59
    @timday Linus Torvalds has some strong opinions. – Fuhrmanator Jun 16 '13 at 16:16
    "By the time you are done cleaning up," you've introduced several new, unknown bugs. – Gabe Jun 16 '13 at 19:04
    What... closed as a duplicate of two other closed questions - one of which points at the other? Shouldn't at least one of these 3 be open? – Izkata Jun 17 '13 at 20:52
    @Izkata Hm, the three questions have a total of 74 answers, is there a reason for more answers? In any case, if you think we should re-open one of the three or do anything else, you should post a question about it on Meta. Your comment is hidden under a ton of upvoted comments, I only saw it because there was an (unrelated) flag. – yannis Jun 17 '13 at 23:07
    @YannisRizos I've tried before and was pretty much told off, so snarky comments like that are about all that's left. What the high-rep users on Programmers.SE don't seem to realize is that closed questions tell new users that these types of questions are bad, not that there's more than enough answers. – Izkata Jun 18 '13 at 01:39
  • related: [What's wrong with comments that explain complex code?](http://programmers.stackexchange.com/q/254978/31260) and [Self Documenting Code Vs. Commented Code](http://programmers.stackexchange.com/q/51307/31260) – gnat Sep 03 '14 at 16:17
19 Answers19
103
Well written code should be sufficiently self-documenting that you don't need any comments explaining what the code does, because it is obvious from reading the code itself. This implies also that all functions and variables have descriptive names, although it might be needed to learn the lingo of the problem and solution domains.
This does not mean that well-written code should be completely without comments, because the important comments are those explaining why a particular, non-trivial, function/block/etc is implemented as it is and why not a different solution has been chosen.
The problem with comments describing the code itself is that they tend to get outdated, because the code gets changed to fix a bug, but the comments remain untouched. This is far less the case with comments describing the reasoning for coming to the current solution.
Bart van Ingen Schenau
  • 71,712
  • 110
  • 179
    +1 - I'd like to add that this is a fairly universal best-practice these days. – Telastyn Jun 15 '13 at 16:31
  • This is especially true when you're working around a bug in the underlying language/environment. – Amy Blankenship Jun 15 '13 at 20:44
    +1 For comments not explaining what but why. – Benjamin Gruenbaum Jun 15 '13 at 21:26
    Now define well written code :) – Chris S Jun 16 '13 at 13:19
  • I agree. `What?` can be answered by reading code, but `Why?` definitely would require comments. – S.D. Jun 16 '13 at 17:00
  • Sadly a lot of programmers don't understand that they should explain _why_ instead of _what_. IDEs which generate comments make it even worse, because a beginner will asume the IDE does it right, whereas it doesn't. –  Jun 17 '13 at 09:24
    It should also be noted that there is a significant TIME aspect to comments. Comments can save a considerable amount of time when debugging or writing new code. Instead of reading through every line of complex code to understand what it is supposed to do, a well written comment will allow you to get the general idea and move on. When I want to know what a method in ArrayList does, it is much more efficient to check the JavaDocs than step through the code. – AnthonyW Oct 23 '14 at 20:45
    @user117: In some cases, why *not* may be more important than "why". If someone who looks at a code sees what seems like an opportunity for a huge optimization and then, after spending a couple days coding it, finds a problem which cannot fixed without making code slower than it was before the "improvement", it may be helpful to write a note about the optimization that doesn't work; otherwise, many people might waste time with the same "optimization". – supercat Oct 23 '14 at 20:51
55
Someone (attributed to Richard C. Haven, a Delphi programmer) once wrote:
  • Beginners comment nothing.
  • Journeymen comment the obvious.
    myVar = myVar + 1; // add one to myVar
    /* This method adjusts the page margin by the appropriate device offset */
  • Masters comment the reason for not doing it another way
    I already tried obvious approaches A, B, and C to solve this problem.
    They didn't work for the following reasons: ...
    Therefore I wrote this less-than-obvious approach which works and
    passes all unit tests.
Your "senior programmer" may be senior in terms of age / longevity, but it sounds to me like he has some professional growing up to do.
As for debugging, there's a lot to be said for clean code and liberal use of logging and/or print() statements. However, using a good debugger I can usually find the problem in a tiny fraction of the time it would take without it. It's a power tool. Use it.
LSerni
  • 2,411
Dan Pichelman
  • 13,773
  • 42
  • 73
    Comments at the tops of methods are good practice regardless of the experience level, as they can get picked up by automatic documentation tools for people who only need to understand your code's API, not its internals. – Amy Blankenship Jun 15 '13 at 20:45
21
Your senior programmer seems to have an understandable problem about coding style. He's wrong in how he tackles the problem, though.
Both comments and descriptive coding are essential: well-written code with descriptive names quickly tells you what code does; but the comments tell you what the code should do (and why not, why it does it one way and not another. Then you have unit tests to verify that the "contract" (what the code should have done) is actually fulfilled, and do it automatically, frequently and with no further effort on your part.
Without the comments, it would take a long time (or a unit test, which at this point I suspect your boss likes even less than comments, if he believes that "bugs get caught by people reading code) before finding the error:
// Multiply margin by a fixed amount.
page->margin += fixedMargin;
and, yes, the comment might be wrong, but now you know that in one of those two lines there's an error. This, plus another useful resource, version control, enables you to find the discrepancy in less than 30 seconds. Verifying the output and even stepping with a debugger might not (a value of fixedMargin of about 1.01 could give you ambiguous results, for example).
If your mentor is after simplicity (I agree with him that it's a desirable trait), he ought to deploy some way of checking metrics such as cyclomatic complexity and establishing metric goals. That goes for comments too: I agree that it makes no sense to document every single line of code, but you should strive to cover modules, functions and any "WTF point" in the code.
// Useless comment: multiply a by four
// Useful comment (even if maybe it shouldn't be in this exact point of code):
// Zooming 2:1, four pixels get mapped into one, divisor needs multiplying by four
a *= 4;
His method may give results - in the case he hates, you would have 20% coding and 80% documenting and testing. With his method you get 20% coding and 80% debugging and head-scratching.
The difference between the two cases are, I think, in people's morale and in overall productivity. If you properly document and mock functions and modules, a module can be implemented by someone who does not need to know the overall picture, does not have to study side-effects in a black box scenario, and for bottom line's sake, can be less experienced.
Your mentor is apparently comfortable running up a fearsome amount of technical debt. I'd check his stats on deadline slippage and/or ETAs; short of a miracle, any long-running project not kept up by a one-man-band or a tightly knit group of coding buddies is due to have its technical debt called in sooner or later.
LSerni
  • 2,411
    A unit test does a far better job than a comment of telling you that there is a bug somewhere between the two lines of code. – Telastyn Jun 15 '13 at 16:32
  • I agree wholly. What I meant to say is that descriptive coding, comments *and* unit tests are *all* useful (I'd even say *necessary*), each in its own way. – LSerni Jun 15 '13 at 21:03
    @Telastyn Unless the test is also wrong. – Izkata Jun 16 '13 at 05:52
    @Izkata - indeed, but if the code and test were wrong, what's the odds the code and comment are both wrong? Just as good if not better. If the code and test differ, you know immediately. If the code and comment differ, you _might_ notice if someone finds the bug. – Telastyn Jun 16 '13 at 13:16
14
If you can only "read the code", you will not get an idea of what the function is intended to do. So, if someone fucks up (I know nobody does, this is a hypotetical case) and do something wrong, you have no way of checking it in the code. You have to wait for unit tests to detect it (if they check it).
Add to that, that not adding comments forces me to read functions A1, A2, A3... from beginning to end while I am only interested in understanding function A, which calls all of the above.
I would bet on your senior programmer being lazy (bad) or wanting people to notice how cleverly he codes (way worse).
LSerni
  • 2,411
SJuan76
  • 2,532
    Then again, why would you give a function/method a name which does not convey what it's intended to do? – markijbema Jun 15 '13 at 20:23
    @markijbema I would be willing to wager that if all function/method names explained their intended. That the length of those names would be about the same length as the comments for that function/method. – Reactgular Jun 16 '13 at 16:07
    in my experience this isn't the case, because your method names already have the context of the object. But even if they would, I would like to have the explanation of the function on both definition-side and call-side. But I think if you have methods which do so much that you need a very long name, you probably need to split up your method. But it's a bit all or nothing, you cannot remove comments if you need real long methods for some reason. I however like no comments and short methods (max 5 lines, ruby). – markijbema Jun 23 '13 at 19:22
  • “If you can only "read the code", you will not get an idea of what the function is intended to do.” That’s only the case if you don’t have unit tests. In general unit tests are a better way of describing intent than comments, because they will let you know when they get out of sync with what the code actually does. – Marnen Laibow-Koser Nov 07 '19 at 21:32
Nothing like an opinionated idiot.
Next time when you are shopping for a book to read. Besure to read it cover to cover before you buy it. Otherwise you'll never know exactly if it's what you were looking to buy. That's basically what he's telling you to do.
He has made a few assumptions that are foolish.
  1. Reading the source code will provide you with the purist perspective of what it does.
  2. Comments pertain to the scope of the source code they are associated with.
That is his narrow perspective about comments, and as such he sees no value in them. Here are the limitations of not having comments.
  1. Source code is an instruction set for a computer. It does not expression concepts or ideas. Therefore, source code will never tell you what the programmers objectives were. Source code that compiles without errors and does not crash can still fail to meet the objectives. How will you know any different from the computer by reading the source code? The computer already does that, yet it could still fail to meet the objective.
  2. Source code does not explain the programmer's intent. open window, prompt for deposit does not explain that the programmer intended to communicate a warning to the user.
Next time you have a conversation with this guy and he asks why you are adding comments to your source code. Reply with this statement.
"I write source code to tell the computer what to do, and I write comments to tell people what to do."
Reactgular
  • 13,040
  • 81
    Reading the source code provides the _purest_ sense of what the code does. Comments **inevitably** get out of date. Documentation gets out of date. Requirements are out of date once the code hits a user. The computer couldn't care less how your variables or functions are named. With modern optimizers, they care less and less how the code is structured too. If I'm working with code, I read the code - comments lie, code cannot. – Telastyn Jun 16 '13 at 02:33
    @Telastyn comments are human forms of communication and subject to the same flaws, but to think that a programming language is flawless is a mistake. Java, C#, C++, and others are *not* good communication tools to explain `why` a person did something. The source code will only tell you in the obscure nature of the language `how` something is done, but not `why`. Having to read the source code to infer the answer to `why` is simply *extra* work. If you are a programmer so talented as to never misunderstand a single line of code you've read, then you are the best programmer on the entire planet. – Reactgular Jun 16 '13 at 15:27
  • of course but your answer doesn't say that. Your answer (as I read it) is that it's somehow foolish to read the code to understand `what` and `how` something is going on, and that comments should be used for that. Code does that, and the _code_ should be clarified if that's not readable by programmers. – Telastyn Jun 16 '13 at 15:52
    @Telastyn so you read the answer, misunderstood and found clarity in the comments. How ironic :) – Reactgular Jun 16 '13 at 15:55
    Unless you are programming in machine code, you write source code for people to read. Comments should be used when despite the best effords of the programmer he cannot express himself in code. – Lefteris E Jul 08 '18 at 13:36
  • Downvoting for the false idea that source code can’t express intent or objective. It can and should, especially if you have sufficient automated tests. I find that nearly anything that *would* have been a comment if I’d written it 20 years ago now gets put either in an automated test or in a well-chosen implementation abstraction. This keeps my code readable, understandable, and almost completely free of comments that might go out of sync with the implementation. – Marnen Laibow-Koser Nov 07 '19 at 21:36
    @MarnenLaibow-Koser yes, I agree with what your saying. Wrote the above answer years ago, and I think it could have been better. Tests are the proper way to document intention and the scope of the source code. I think there are valid cases for using comments, but the answer takes on a bit of an attitude that isn't helpful and should have just listed the edge cases where it helps. – Reactgular Nov 08 '19 at 10:39
Comments should be used as a written record which explains something confusing. If you're writing something that is potentially confusing and cannot be simplified, such that you suspect that even you will have a hard time understanding it six months later, then write a comment.
If you comment liberally, everything and everywhere, then comments lose their effectiveness at flagging the difficulties. (Rememer the fable of the boy who cried "Wolf!")
Comments occupy "screen real estate", unless you have a good folding editor; you have to keep skipping past them when moving around in the code. And of course comments like /* increment i by one */ next to i++ are complete garbage.
If the code is so complicated that it requires a guide to the internals, then, by golly, write a guide to the internals. Call it README-internals.txt (or perhaps HTML) and stash it in the same directory as the code, and put in a comment which says /* this is all explained in README-internals.txt */.
About debuggers: any tool which helps you find a bug is valuable. It is silly to dismiss tools. Breakpoint debuggers should not be used to verify that code is working. At least, not relied upon as a primary means. A debugger will cheerfully step over a statement like a[i] = i++ in C and confirm a bad intuition.
Debugging tools which actually catch some kind of run-time violation, however, can be relied upon as a test tool. If you have a debugger that catches misuses of dynamic memory, and the code passes numerous test cases under that debugger, that is a source of confidence that memory isn't being misused.
So, keep in mind that "debugger" refers to more than one kind of tool, not only a breakpoint/step debugger. Some debuggers only provide a view into the program, leaving you to do the reasoning about what is wrong, whereas other debuggers look for problems for you.
Code cannot always be simplified for the sake of not having a debugger or refusing to use one. What if you follow your boss' suggestion and simplify the code to the point that it cannot be simplified any further, and you still need a debugger?
Kaz
  • 3,572
  • 30
I find that code review is a fantastic process for answering this question in concrete ways. If I read someone's pull request (putting forth actual effort to read it, not just glancing at it with the attitude that everything must be immediately apparent) and can't understand what it does, I tell people to add a comment. Or you can do this by yourself with a rubber duck.
Most people inuititively know what ideas needs to be commented - It's whatever you would say to someone standing next to you if they asked you a question about the code. Often I'll ask someone to explain something in a review, they'll give a great answer, and my response is "Copy that explanation you just wrote into a comment in the code."
But for some reason that's rarely the content that people end up writing in their comments. Instead people write inane stuff like
 * Gets the {@link List} of {@link Author}s for the given {@link Book}.
 * @param book The {@link Book} for which you want the {@link Author}s.
 * @return All of the {@link Author}s for the given {@link Book}.
List<Author> getAuthors(Book book) { ...
and
// increment i by 1
i += 1
and that's the kind of stuff that the experienced coworkers are reacting to. I myself tell people when I'm reviewing code to remove these sorts of low-level comments that add no more information than can be found in the immediately surrounding lines.
One prime example of a trivial thing that does need to be commented is descriptions of duck types in dynamic languages. If a function's argument or return value is a dict with a bunch of properties on it, you're in for some insanity later on if you don't comment exactly what those properties are.
No amount of commenting will raise any nontrivial code to the level that an 8-year-old could understand, so you shouldn't try. You have to make some assumptions that the reader knows how to read the code, because otherwise it's a completely futile effort.
Finally, comments are very often wrong. People often skip over them when reading, and don't update them when things change. You can't write a unit test for your comments, so only the way to defend your code against the rot that occurs when your careless coworkers start monkeying with it is to comment only the ideas are are essential. Comments that don't add value add negative value when they become erroneous.
Document design, ideas, architecture, history, rationale - not lines of code.
In a perfect world without deadlines his approach might work.
A user reported a bug in application X. We'll let the new guy spend two months to get a deep and thorough understanding of the code, and then maybe add a few weeks of refactoring. If the bug still occurs, he should be able to find it then and won't even need a debugger!
In the real world, this sounds like a reliable way to get out of business.
Heinzi
  • 9,646
  • 59
  • But isn't the real world with deadlines the one in which many people are forced to write crappy code without comments or any sane identifier naming whatsoever? :P "I'll write comments and refactor this piece of c...ode later. Not enough time now, must deliver this for yesterday!" – Andres F. Jun 16 '13 at 00:38
    @AndresF. - being a pro means being able to write decent code and meet the deadline (more or less). I say decent, not great or perfect: The 'real world' is about compromises, and this is where a good relationship between technical staff and business people is CRITICAL. – Vector Jun 16 '13 at 01:08
  • @Mikey Oh, fully agreed. My remark was merely a sort of "meanwhile, in the real world..." What you say is definitely valuable. Unfortunately, in the real world people seldom write comments or, for that matter, good code. – Andres F. Jun 16 '13 at 08:04
  • @AndresF: 'people seldom write comments... good code' - I think most programmers want to write good code. But whether that's going to happen or not depends on the technical leads, and management. The hard part is explaining to management how they are adding something to their bottom line by giving programmers the time and resources to write good code. BTW, +1 for "In the real world, this sounds like a reliable way to get out of business." I wrote essentially the same thing. – Vector Jun 17 '13 at 05:37
  • @Mikey I wouldn't say it's _always entirely_ management's fault, though that plays a big part too. I've seen too many mediocre programmers who just don't care, so I cannot blame everything on management. I also doubt mediocrity is a surefire way to go out of business, unless you're building mission critical software and you lack any friendly contacts in the customer's side. It's amazing how far you can go with crap, hard to maintain software. And it's top business for outside contractors who eventually get paid to rebuild it from scratch. – Andres F. Jun 17 '13 at 12:35
  • @Mikey Needless to say, I don't like this. I'd rather we all wrote good, clean code. I just think the notion that what matters the most is building good, clean, well-commented software is incredibly naive _in the real world_. And that writing bad code won't necessarily put you out of business, unlike what we'd like to believe. – Andres F. Jun 17 '13 at 12:41
Example of bad comment
foo(); //calling function foo
Good comment
foo(); // must call function foo, because of a bug {link to bug}
Lukasz Madon
  • 1,496
  • This happens to be an excellent answer IMO. Not sure why someone would downvote it. The point is: a comment should explain what is not obvious from the code, or help someone get oriented in code they are not familiar with. No reason to comment on the obvious: '//calling function foo' - **DUH** – Vector Jun 16 '13 at 00:16
  • I do like your answer, because it is short and precise. But it could be better, because "a bug in the library" is not a good example for being precise in comments. – Arne Jun 16 '13 at 00:28
  • @Arne better? :) – Lukasz Madon Jun 16 '13 at 00:42
Code Complete, the seminal work on coding style, devotes several sections (starting with 19.3 in edition 1) to the question of comments: the good, the bad and the ugly. So you, and your senior developer, should probably take a look there.
Having said that, well written and well placed comments are very important IMO, for any large scale/long-term project.
In a perfect world, it's true that comments would not be important. But unless you have a photographic memory and everyone who works on your code is a genius, good comments just help to understand the code that much quicker when you have to go back to it a year or two later and modify it, or someone else inherits your code. (I'm saying this having worked professionally for 20 years, and as many as 5 or 7 years on one project with several other developers involved)
A few years ago I inherited a complex application that gets the job done but suffers from poor architecture and an inconsistent, bloated coding style. Luckily, the code is fairly well commented, which saved me days and weeks of getting up to speed with that code base.
Another thing that helped me get up to speed was the debugger I use. When I go to analyze a new piece of software that I have to work on, one of the first things I do is go through all the menus, make invalid or weird selections and see if I can break the app. When I do break it, I run that scenario with the debugger and see where that failure leads me. Almost invariably this leads me to important modules and junctures in the code base: A quick way to find the important places on the map.
Although with my own code I generally don't have to use the debugger very much, there are occasions where it does help - nobody is perfect, even if they are meticulous about unit testing (Which is often impossible when you've inherited tightly coupled legacy code.) And if I use a new module or component, the debugger helps me find quickly the errors and misunderstandings I have to deal with to help me get up to speed with the new stuff.
In short: Time is money, and most of us program to deliver products and pay the bills. Sitting for weeks on end going through hundreds of lines of code to find a bug the debugger would reveal in 10 seconds, or poorly written code that might be illuminated by some good comments, won't help your bottom line very much....
Your senior developer apparently is not concerned with efficiency and would prefer to have developers spend hours and days messing with complex code, when a few comments would save the day. Same goes for his ideas about debugging. (Just curious: does the senior developer use an IDE? Why not just type everything out in a text file and do a compile and link from the command line, etc? What better way to understand every single line of code...)
Vector
  • 3,180
You know, it's an extremely theoretical approach. I wouldn't surprised, if it was said by theoretical mathematician, but in sounds of senior developer it doesn't sound as if it was someone with really long practice.
Well, theoretically you can analyse the code in head, but it works only with very simple programs. With more complex, real-life ones you come across Halting problem, which is one of the most complex problems in computation theory. If someone says he can analyse programs in head, he can probably do RSA decryption in memory :)
It seems as either your senior developer has no real-life experience with complex problems, or is trying to impress you with tricks as taken from Hackers movie, or he want to justify his own laziness when it goes to writing comments.
I have been writing code for about 40 years now and I may have said something very similar to what said that senior programmer. I'm also very aware of maintenance problems.
Still I believe some very important points were forgotten in the above answers:
I have unit tests for most of my code. Don't you ?
The why of the functions (the intent behind the code) is usually expressed through tests and if tests by themselves are not enough they are commented, sometimes very heavily (if some of you heard of litterate programming they may understand what i'm speaking about).
On the opposite comments in my code are very sparse, nearly nonexistent, except for two special cases: - if what is implemented is following some normative references (like implementations of network protocols, what I'm currently working on) I usually put the reference as comment above the code. - I also use comments to avoid breaking programming flow. I insert comments like: this or that look wrong, fix it later when I'm coding some unrelated feature. These are short term comments (like programmer defined warnings) and should be fixed later.
My rationale on doing that is that comments in code can be misleading. You can easily read a comment and believe the code is performing what the comment pretends, even if it's not true.
When comments about code are in tests, things are different. It explains how code should be called and the test ensure it is actually doing that.
I usually not much use debuggers. I keep them for some special cases (mostly when I do not understand what the code does, like strange hardware bugs).
That changed with time. 30 years ago I heavily used debuggers. What I've observed is that finding bugs is usually much slower that other methods. What I usually do now is pinpoint bugs in unit tests, the earlier the better. That has the additional advantage to give a non regression test. Never bitten twice by the same bug.
kriss
  • 1,040
    What happens when you inherit a large code base that doesn't have unit tests? Comments have always been around - TDD, not. Comments are more for the next developer than for you. And unit tests do not help for complex logical problems when dealing with disparate modules that span different languages, time frames, data types and business rules. Skillful use of debuggers with all their bells and whistles becomes **very** important in such cases. – Vector Jun 16 '13 at 03:52
    Basically I read code and I write tests (and that is not TDD in this case, that is unit testing after coding). When code is so poorly written you can't easily read it, comments are usually very poor. And it may be worse, comments may be "lies". Typically it happens when after changing code, programmer didn't bothered to update comments. In this case they are useless anyway and you *have to* read code. In some case dropping parts of code can also be a possible outcome. And I agree unit tests do not help whith poor overly complex design, neither do comments. – kriss Jun 16 '13 at 11:04
    But basically I said it : debuggers are for when you do not understand the code you are working on. – kriss Jun 16 '13 at 11:04
  • No argument here. Of course you have to read code. And no, you shouldn't be relying on the debugger to write your code. Unit Tests: all depends on the context. I used to use them a lot, but I get kind of sour on them: they don't help with the HARD stuff IMO: subtle problems with business rules and logic when you have data crossing modules and contexts. – Vector Jun 16 '13 at 21:31
    @Mikey: yes, of course Unit Tests are just another tool, like debuggers. – kriss Jun 17 '13 at 07:46
    @Vector For subtle problems with business rules and logic, you need acceptance tests. Unit tests are only the lowest level in a comprehensive testing plan. – Marnen Laibow-Koser Nov 09 '19 at 16:23
Comments are for who, when, why, assumptions, dependancies, and possibly how.
Who wrote this? Who do I go and bug if I have questions about it?
When did they write it?
Why did they write it? What was the business reason that they spent time writing code?
Why did they pick this approach and what other approaches did they reject, and why?
What assumptions did they make? What beliefs about the organisation did they hold?
What things are required to happen for this code to execute successfully? What libraries, objects, environments or other things is it dependent on?
What are the situations in which the code might fail and how does the code deal with those failures? How do I deal with them?
As for the "how", comments should only explain how the code works if it is complicated and hard to understand (and if it is then perhaps the programmer should have put more effort into simplifying it).
What your senior developer is referring to is code entropy. I imagine he's referring to cases where code is badly designed, and the only way to understand it well and work with it are comments and debugger.
In other words, comments and debuggers can be used to work around underlying issues. However, they are both tools, and blaming the tool is not an effective way to go about anything.
For your example, if a codebase has a lot of broken code, then the solution is not to leave out comments and make everyone read as much code as possible. In fact, this is a waste of time and resources. Instead, set up processes like peer review and pair programming, where code written by one person is sure to have been reviewed by another. These processes not only achieve the same goal with better accuracy, they also avoid a waste of resources where dozens of developers have to understand one complex bit of code, just because it lacks comments and documentation.
Furthermore, efficient comments can actually reduce the amount of error in code. Reading them makes source code easier to understand, and often saves you from having to search through whole batches of source files, just to find out why a line of code is necessary. Sure, the comment may turn out to be wrong - But unless the overall quality of the project is downright horrible, you'll end up saving more time by trusting accurate comments, than you will lose to those that are outdated. And saved time on understanding, means more time for refactoring, which is a much better way to combat code entropy.
cib
  • 111
Any time you write code, you should be thinking about the next programmer who will inherit what you wrote. If you write comments because you were taught to do so as a best practice or just out of habit, you should probably stop writing comments all the time because anybody reading your stuff will start to ignore them as useless.
If you only comment when naming conventions and structure can't explain some weird element of what you're doing (usually because of something else in a codebase that's completely batshit), they'll pick up on that. If you're marking problematic bits of code, for crying out loud put a date on it so it's easier to review changes that led to the shenanigans in source control.
On the subject of debuggers, I can feel a twinge of solidarity on the (I'm guessing) old-school, primarily procedural guy because I come from JavaScript starting back when all IE told you was "Object not found." Why they even bothered, I don't know but when you occasionally have to deal with that sort of thing, you think a lot harder about how to structure your code in such a way that it's going to be a lot more obvious where something went wrong so you can rapidly diagnose with logging/alerts.
That said, I wouldn't trade Chrome Dev tools or Firebug for anything short of a Time-Travelling police box. But the point, I think, is this. If the first thing you do is start a trace in the debugger without even looking at the code that's involved, you may not be structuring your code as well as you could. Always strive to be as direct and obvious and minimalist and easy to read as if there were no IDE or debugger to help you. Start by looking at your code when you hit a snag first. If it's not easy to even guess where things are going wrong, you may want to put some more thought into how you'd go about writing code without modern tools. Most of the Java and C# I've ever seen is clueless about the basic fundamentals of OOP.
Erik Reppen
  • 6,243
I used to comment a lot, now very little, making the code and variable names readable is the way to go.
I add comments for real 'gotchas' and 'why this was done that isn't (yet) obvious from the code'.
But to your REAL question.
I note that your title starts with the word: "forcing"
I also note that the first paragraph mentions "confronting"
I used the exact same words 20 years ago myself :)
This (IMHO of course) is what programming is really about - how different people with different styles, opinions, experience, knowledge and background can work together.
There is no simple fix, no list of programmatic steps to take, no single conversation to set things right. I would recommend that you think over the following points that I have learned from my experience of 20 years.
  1. Listen
  2. Listen
  3. Listen. Sorry to make it such a big deal but nothing will help you more in your career now than asking questions and listening even if the answer don't make sense.
  4. Ask question and just listen to the answers even if you disagree or don't fully understand them. There is nearly always a second chance to revisit things.
  5. Accept that wring things get done sometimes. If they are really bad decisions that will continue to show and one can make a case later to make them better. But emphasis on the later. Good enough for now is something you have to accept sometimes so you can more on for now.
  6. Pick your battles on things that are wrong. Learn to hold your tongue unless the item is really really important to you and even then pick your battles very carefully - and try to make then conversations and not battles!
  7. Accept differences. Outside of academia you will need to accept more differences and focus a (little) less on finding the 'correct and true' way to do things and more on what works for today and for the business you are workgin in.
  8. Avoid black and white conversations. Don't be absolutist about the 'right thing' avoid words that are absolutist like 'must', 'only', 'impossible', etc. and use words like 'should' 'often' and 'hard'.
  9. Use concrete examples in conversation rather than theory. Don't avoid theory but in conversations try to have real examples for your points. If you don't have real world examples yet this may be a indicator that you should listed more than talk.
  10. Emphasize your youth and ignorance in conversations with more experienced programmers such as the one you mention. You will impress them more with humbleness than boasting about your recently gained knowledge.
Michael Durrant
  • 13,101
  • 60
  • +1 - "pick your battles on things that are wrong". Not sure if you answer the OP's question but your post does present a lot of very savvy advice. With the same 20 years on some fairly large teams and complex long term projects under my belt, I have learned exactly the same lessons you have. Writing software for a living is a business, and like in any other business you have be open to other points of view, and think/work pragmatically: delivering product is the endgame. Hopefully you will become a better programmer in the process. – Vector Jun 16 '13 at 21:22
Comments are very overrated and most frequently misused. Though I don't know about your current situation (since I don't find the quoted quote speaking for good code readability), in general you shouldn't spray comments all over your code (with perhaps the exception of highlevel comments, which are already close to documentation0.
It's for a reason that commenting is one of the code smells described in Martin Fowlers Refactoring book (for a summary, see: http://www.industriallogic.com/wp-content/uploads/2005/09/smellstorefactorings.pdf, the book is not freely available afaik).
However, you should substitute comments with meaningful method and variable names, and I don't think w and gs classify. However, personally I would press more on good naming, than on commenting.
Btw, if you search for 'clean code' and 'comments' or 'code smell' and 'comments' you find great reads about this, ie. http://franksworld.com/blog/archive/2010/07/01/12035.aspx (with a summary of why Uncle Bob Martin of Clean Code dislikes comments)
markijbema
  • 379
Comments in code are a Godsend when used correctly but as others here have pointed out they are often overused. I'm not going to re-iterate what has already been pointed out but I will say that you should only comment if you know that the code you are writing is complicated and there is no other viable way.
If you feel you have to comment, think about the code first and ask yourself; Why are you writing that comment? Is there another way of writing the code which wouldn't need a comment?
Don't write comments for the sake of writing comments. Comment only as a last resort or where it will help those who are going to have to work on the code further down the line. If you find yourself writing comments describing what a variable is doing then the chances are you're over-commenting. Bad programmers comment everything, good programmers comment only when necessary.
On the subject of debuggers, I work with some engineers who have gone their whole career without ever firing up a debugger. Why? A debugger is a tool like any other. Just like in most instances a ball-peen hammer will do the job, sometimes you need something with more finesse.
A debugger serves two purposes.
  1. It is used for finding bugs
  2. It shows a path through your code.
They can be very useful in bringing newcomers up to speed and they can be even more useful in tracing those very hard to find bugs but they are not the only way and there are times when a debugger is actually a hinderance more than a help.
As for function summary, well every function should have a docblock, this is a must but don't go making them long and elaborate. The summery should be a 1 line description with each parameter being clearly described.
 * A getter method for foo
 * @param bool $bar If true, bar will be attached to foo
 * @return foo
Only use a detailed docblock if there is cause to. If the method is over complicated then yes, put in an explanation but where possible, try and avoid it. Good code should document itself.
Remember, everybody enjoys reading novels but nobody wants to read war and peace at 9am on a Monday morning.
mproffitt
  • 101
  • +1: "...If you feel you have to comment, think about the code first ..." Don't know why anyone would have down-voted your answer. – Vector Jun 17 '13 at 10:02
-1
Comments are very useful, and can be the difference between clear code, and unclear code.
Just because it was done one way "back in the day" doesn't mean another way is unacceptable.
CaptainXD
