You can find many frameworks with an example todo list for demonstrating a small but full application in the framework. You don't have to consider large problems like scaling or caching, but you still exercise most of the fundamentals of that framework in a todo list.
Is there an analogous application for systems-level programming?
Mark Rushakoff
  • 1,734
Not a single one, but different areas of computing have traditions. For writing network services, the canonical functional-though-useless example is to write an echo server (it listens on a port and parrots back everything it hears). The simplest command-line utility imaginable is one that simply returns a specific exit code (Here is an astounding example of just how simple it can be made to be) - it does virtually nothing, but can still be helpful to introduce someone to the code-compile-link-execute cycle. If you count programming languages and libraries, of course there's always "Hello, world!", and almost every language has its perceived weaknesses that everyone tries to fix. For C++, it's writing a better string type; of Perl, it is jokingly said, that every serious user has tried their hand at a better option-parsing library.
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
  • I feel like the relative complexity between "hello world" and a todo list in a web framework is much greater than the relative complexity from "hello world" and `exit($ARGV[0].to_i)` in a systems level language (C, C++, Go, etc.). But +1 for the echo server example. – Mark Rushakoff May 18 '13 at 07:21
