105
So, we've got a guy who likes to write methods that take Objects as parameters, so they can be 'very flexible.' Then, internally, he either does direct casting, reflection or method overloading to handle the different types.
I feel like this is a bad practice, but I can't explain exactly why, except that it makes it more difficult to read. Are there other more concrete reasons why this would be a bad practice? What would those be?
So, some folks have asked for an example. He has an interface defined, something like:
public void construct(Object input, Object output);
And he plans to use these by putting several in a list, so it sort of builds bits and adds them to the output object, like so:
for (ConstructingThing thing : constructingThings)
    thing.construct(input, output);
return output;
Then, in the thing that implements construct, there is a rickety reflection thing that finds the right method that matches the input/output and calls it, passing input/output.
I keep telling him, it works, I understand it works, but so does putting everything into a single class. We're talking about reuse and maintainability, and I think he's actually constraining himself and has less reuse than he thinks. The maintainability, while probably high for him right now, will likely be very low for him and anyone else in the future.
samthebrand
  • 368
Risser
  • 303
    Also what do you mean - an example would be useful – mmmmmm May 14 '13 at 16:55
  • 66
    If he insists on programming Java as if it were Python or Ruby, he shouldn't be programming in Java. – user16764 May 14 '13 at 18:00
  • @user16764: Exactly. This looks like someone who only knows dynamic languages and doesn't understand how a strong type system works. – Mason Wheeler May 14 '13 at 18:15
    Personally, I see this as a variant of ['stringly-typed'](http://c2.com/cgi/wiki?StringlyTyped) code - with largely the same downsides. – Clockwork-Muse May 14 '13 at 18:40
    even on dynamic type systems, that sounds awful and totally non-maintainable. The idea of polymorphism (be it dynamic, static, class-based, duck-based, whatever) is let different implementations do different things, not to differentiate types and operate differently. – Javier May 14 '13 at 19:28
  • thinking of it, I think he comes not from a dynamic-language background, but Objective-C, where it's common to just use `id` as type. – Javier May 14 '13 at 19:30
    Sounds like the sort of code that makes you feel cheap and dirty and stings the eyes... :( – Robbie Dee May 14 '13 at 19:43
    @Mark: I'm betting he's seeing a lot of methods like AppendNumberToString(Object, Object) instead of AppendNumberToString(String, Int). Obviously, if that method is public, there's no information about which parameter is supposed to be provided first. In the second case, the method is self-documenting. – Michael Blackburn May 14 '13 at 19:48
    I usually see people trying to write python as if it was Java, not the other way round... – Bakuriu May 14 '13 at 20:43
  • Did you see the the interface [`Function`](http://docs.guava-libraries.googlecode.com/git/javadoc/com/google/common/base/Function.html) of Guava (or a similar library)? It does exactly that. – Kru May 14 '13 at 20:48
  • Sure you mean: `for (Object thing : constructingThings) thing.construct(input, output); return output;` LOL – Kaz May 14 '13 at 20:50
    What is the danger of using Java as if it were Python and Ruby? Is it the risk of achieving the productivity of Python or Ruby? What if someone insists on programming Java as if it were Python and Ruby, but has no choice but to use Java because it is externally imposed? (Though I would say that the right solution would be to use a dynamic language targetting the Java platform. Writing Java code in which every third token is `Object`, is not much better than ... writing Java in which every third token isn't `Object`). – Kaz May 14 '13 at 20:53
  • Why isn't this closed at 0 votes? Is OP important? – Captain Giraffe May 14 '13 at 21:36
  • Remember Jeff, don't undermine us before your trials up! – marabutt May 14 '13 at 22:47
  • Late to the party here, but I think this question and the example/situation provided are different. The OP should talk to the "guy who likes to write methods that take Objects as parameters, so they can be 'very flexible'" about interfaces and inheritance. But, the question in the title, "Is it poor programming practice to pass parameters as Objects?" (meaning the type Object in Java), can be answered with, "If you really can take any Object, then no; otherwise, yes." I see no reason to turn it into an argument for/against duck typing, because that isn't the question. – Gary S. Weaver May 15 '13 at 02:00
  • When you have hammer, you see all problems as nails. – Manoj R May 15 '13 at 04:58
  • Switch-case on type always means something went wrong with the object oriented design, yet sometimes (rarely - and probably will involve a use of reflections) it is easier to go that path. – G.Y May 15 '13 at 08:18
18 Answers18
113
The method violates the Liskov substitution principle.
If a method accepts a parameter of type Object, I should expect that any object I pass to the method will work.
What it sounds like is that only certain subclasses of Object are allowed. The only way to know which types are allowed is to know the details of the method. In other words, the method is less flexible than advertised.
Aaron Kurtzhals
  • 2,138
    Yep - pretty much all the SOLID principles have been drop-kicked out the window here... – Robbie Dee May 14 '13 at 19:48
    This does not violate any such principle, unless you're prepared to defend the argument that all languages with typeless variables violate Liskov, including languages that Liskov herself was working with when she came up with that. – Kaz May 14 '13 at 20:31
    @Kaz, what do you mean? A language with weak typing is not typeless and I don't think Liskovs point has anything to do with compiler type checking. If I create a Ruby method called `def add_user(user)`, it should be fairly obvious that you cannot throw a Message instance, Hash or File handler into the method - the method presumably expects a User instance. Whether or not a compiler enforces this is irrelevant. However, if I define `def construct(object)`, I would expect the method to handle every imaginable object... which it obviously does not according to OP. That's a violation. – Niels B. May 14 '13 at 20:52
  • @NielsB I also don't think that Barbara Liskov's point has anything to do with compiler type checking, which is why this isn't the right answer. In your example, the only quibble is that `def construct(object)` uses a poor **name** for the argument. That's what `object` is; it is not a declaration of type. A Java argument of type `Object` can have descriptive name, like `void add_user(Object user)`. – Kaz May 14 '13 at 20:57
  • @Kaz, in weakly typed languages the argument name is often an implicit type or interface declaration. For instance `def add(users)` usually means an array of user objects. If you are certain that your method takes only users, why in the world would you declare Object as the type in a strict language like Java? If you have a method that can work on multiple classes that share traits you usually express them in an interface which the classes implement and the method accepts. – Niels B. May 14 '13 at 21:09
  • I don't use Ruby. I'm familiar with Lisp, in which the argument name means nothing. It could be `(defun add (x) ...)` instead of `(defun add (user) ...)` as long in the body of the function we replace all occurrences of `user` with `x`. The symbol name does not encode type information in any way. Methods specify their types explicitly: `(defmethod add ((u user)) ...)`. Now we have parameter `u` whose class is `user`. This isn't static, though; the method is just a specialization of a generic function, which is dynamically dispatched. – Kaz May 14 '13 at 21:18
  • If you're certain that the method takes users, why would you declare it as `Object` in a language like Java? Why indeed? Maybe because you're doing that as a global policy throughout the code base. In the future, you could have another kind of user object which can be passed to `add`, but which is not related by inheritance to the original user class that was initially used with `add` (i.e. the only thing the two kinds of users have in common is that they are both derived from `Object`). – Kaz May 14 '13 at 21:21
  • @Kaz - What happens if I pass a `cat` in where you have `(u user)` as your parameter? – Bobson May 14 '13 at 21:27
  • @Bobson In that case, that method would never be called (unless a `cat` is a kind of `user`). The generic function will find an applicable method that can take a `cat` class object in that argument position. Failing that, a method not found condition is signaled. A `cat` could be passed as a user into some regular, non-generic function. Then that function has to either deal with it, or delegate the problem to lower functions. It's no different from passing a character string to the `log` function. – Kaz May 14 '13 at 21:36
  • @Kaz - That behavior is exactly what you're arguing Java would be better without. Except Java checks it before you run your code and have it fail. – Bobson May 14 '13 at 21:46
    @Kaz, the argument has a semantic meaning for the programmer who reads it. That's why we call our methods `def delete(key)` instead of `def d(k)`. If you have multiple unrelated User classes and you want to be able to add both, then write two methods. `void addUser(legacy.package.User user)` and `void addUser(future.package.User user)` – Niels B. May 14 '13 at 21:57
  • @NielsB, Oh totally. I mean, if we call things `def F013(A0012, A0013)`, the program becomes indecipherable. – Kaz May 14 '13 at 22:16
    Okay, it seems we don't disagree then. Any method that by, its' signature, claims to accept something it doesn't, is a poorly programmed method that violates Liskovs substitution principle. `construct(Object input, Object output)` must take accept any subclass of object - meaning every possible parameter except null. – Niels B. May 14 '13 at 22:21
    This doesn't violate the Liskov substitution principle, unless you're prepared to say that every method that accepts `int` parameters must accept negatives, and values that are out of range, etc. Also that folks who use interfaces in their public API as part of information hiding and then accept interfaces as arguments but expect them to be their own internal concrete types also violate the principle. My understand is that the principle says that an override of a method must accept at least the same types of input, and result in at most the same types of output. – Andrew Arnott Sep 22 '13 at 15:22
  • Would this still break the Liskov substitution principle and the "don't pass objects as parameters" "rule" if a certain object is specified? e.g. `private void method(cow myCow)`? – Sam Sep 27 '13 at 06:40
  • @AndrewArnott: Bingo. Type systems can encode a lot of useful information (IMHO they don't code as much as they should, especially with regard to the different kinds of reference that may exist to the same object) but it is better to have types with having "optional" abilities (things that some instances can do and some cannot) than to try to have types precisely correspond with abilities. While there are times when it might be helpful to have `NonNegativeInteger` and `PositiveInteger` types [for `int` values whose range could be compile-time guaranteed], any code which uses such types... – supercat Aug 20 '14 at 14:58
  • ...should expect to have to do a lot of narrowing type casts (e.g. after almost any subtraction). Further, if one e.g. defines different collection types for every combination of abilities that collections might have, then a method to produce a read-only wrapper for a collection would need to know about every possible collection type and be able to wrap it separately. If instead collections implement an interface with "optional" methods, along with a means of querying which methods are actually supported, then a wrapper can forward methods to the base whether they're supported or not. – supercat Aug 20 '14 at 15:06
105
From a practical point of view I see these problems:
  • A bloat of possible run type errors -- unless a lot of dynamic type checking which could be avoided with the Java included strong type checker.
  • A lot of unnecessary casts
  • Difficulty understanding what a method does by its signature
From a theoretical point of view I see these problems:
  • A lack of contracts of the interface of a class. If all parameters are of Object type then you aren't declaring anything informative to the client classes.
  • A lack of overloading possibilities
  • The incorrectness of override. You are able to override a method and change its parameter types thus breaking everything which is inheritance related.
samthebrand
  • 368
Jack
  • 336
    i misread your second point as "a lot of unnecessary cats". I was going to query which cats would then be necessary but realised none of it made sense. – bharal May 15 '13 at 12:55
    @bharal, well, if everything is typed as object, a cat is as valid to pass in as anything else. – Kyralessa Jun 26 '15 at 20:28
  • Also, completely throw away all useful IDE autocomplete. Rich type information is what allows you to generate / insert correct values very quickly. Not to mention functional interfaces; you can't pass a `()->"do " + stuff()` to Object... – Ajax Oct 04 '18 at 08:28
    @bharal Well, I guess we need an `@Meowable` type annotation now... – varun Apr 09 '19 at 12:17
53
I'd consider the following direct implications:
Readability
I guess working with him is not exactly the most pleasant experience in the world. You never know what the type is going to be in the end or what happens to the parameters. I doubt you appreciate wasting your time with that.
Type Signature
In Java everything is an Object. So what does that method do in the end?
Speed
Reflection, casts, type checks etc all contribute to a slower performance. Why? Because in his opinion it makes things flexible.
Against nature
Java has been strongly typed since birth. Tell him to start writing JavaScript or Python or Ruby if he wants a dynamically typed dialect. His background is probably strongly based on one of them.
Flexibility
To use the same term as the colleague in question, Java has already figured out flexibility long ago. There is no point to look at it with the horse glasses put on by a dynamically typed language.
Interfaces, polymorphism, covariance & contra-variance, generics, inheritance, abstract classes and method overloading are just a few of the things that contribute to the so called "flexibility". Flexibility is given by the fact that it is trivial to specialise virtually anything from any given type to another.(The usual case meaning specialising a direct upper type or lower type).
Documentation
One of the main goals of programming is to write reusable and stable code. How does the documentation of your example look like? What is the learning time for another developer before being able to use that stuff? I would suggest your guy to write self-modifying assembler code and stay responsbile for it.
flavian
  • 301
There are a lot of good answers here already. I want to add a secondary thought:
This pattern is most likely a "code smell."
In other words, if you need to pass an Object to your method for "ultimate" flexibility, you most likely have a very poorly defined method. Having strongly typed parameters indicates a "contract" to the caller (I need things that look like "this"). Being unable to specify such a contract most likely means that your method does too much or has a poorly defined scope.
samthebrand
  • 368
    This is the coder equivalent of microwaving fish curry. – Michael Blackburn May 14 '13 at 20:14
  • Or it could simply mean that the method is actually very well defined, but the programmer does not belong to your political party (or religion) of static typing. Or perhaps the programmer wants to experiment with what happens if you just deal with objects as Object: how far can you take Java if you try to use it in a more dynamic way. – Kaz May 15 '13 at 03:47
    @MichaelBlackburn: ??? I don't understand that comment ??? What's so special about microwaving fish curry? Googling for it I only get interesting (if you like fish) recipe's and even video's. – Marjan Venema May 15 '13 at 06:22
    @MarjanVenema Microwaving a fish curry generates a lot of fish smell very quickly. – Jonathan May 15 '13 at 07:07
  • @Jonathan: Aha! Another reason not even to contemplate eating fish... :-) – Marjan Venema May 15 '13 at 08:07
  • @MarjanVenema or curry, some might argue. – bharal May 15 '13 at 12:59
    @Kaz Type casting in no way makes Java "more dynamic". It just hides the types hardcoding inside the method, instead of making types explicit in the method's signature, making the code more _brittle_ and harder to understand. How is that more dynamic, or a good thing? – Andres F. May 15 '13 at 13:12
  • @AndresF Making decisions based on type has to be handled somewhere, and it's done in dynamic languages. For instance the `+` function in Lisp somehow has to handle all combinations of numbers: a fixnum, bignum, rational, real or complex number can be added to another one in any combination. You can't get away from identifying an object's type to apply the correct operation. Dynamic is more about not having to deal with the object's type where it is irrelevant and severely inconvenient, like just for the sake of passing it as a parameter or storing it in a storage location. – Kaz May 15 '13 at 16:30
    @Kaz Disagreed. _Hardcoding_ the type casting in your method is not like letting a language (such as Python) handle it. Besides, if your method is going to crash and burn because the typecast was incorrect, how is it more "dynamic"? You are _subverting_ Java's compile-time checks, and getting nothing in return. – Andres F. May 15 '13 at 17:52
    @Jonathan Thank you for making us vegetarians understand! ;) – varun Apr 09 '19 at 12:20
22
It takes away the type checking that the compiler does and can lead to more runtime exceptions when the object is cast to the concrete type. Thus, the end-user will see the unhandled exception, unless the invalid casts are all caught and properly handled.
    This... He is throwing away static type checking. It means that the program will fail at run time rather than compile time. That's a bad thing. The language has types. Use them. To ignore that is like calling all your variables var1, var2, var3 etc. Sure it will work but it's not a good idea – JohnB May 15 '13 at 07:35
16
I agree with the other responses that this is generally bad practice.
There is one specific case where I find passing an Object may be superior: when you are eventually dealing with Strings, e.g. if you are creating XML or JSON. In that case, instead of something like:
public void addAttribute(String s) {
  //... add s to the XML
I prefer:
public void addAttribute(Object o) {
   String s = String.valueOf(o);  // perhaps check for null explicitly
   // now add s to the XML
This saves endless String.valueOf's in the calling code. Also, it works nicely with vararg's. And, with autoboxing, you can pass ints, floats, etc... Since all Objects have a toString(), this, arguably, does not violate Liskov etc...
samthebrand
  • 368
user949300
  • 8,679
  • 26
  • 35
    +1 for showing by example one of the few times to do this - thus being the exception that proves the rule. – fluffy May 14 '13 at 21:01
  • 'Prove' in the original meaning of the word, meaning 'test'. – Alan B May 15 '13 at 08:18
  • This raise more questions than it answers. Why are you making an API to manipulate XML? Why it allows anything to get in, unconstrained? – Lorenzo Boccaccia Sep 23 '13 at 15:32
    I'd call this an API enhancement, which, underneath, probably calls some more standard XML package. Not sure I fully understand your question. – user949300 Nov 14 '13 at 04:37
yes. java is supposed to be strictly typecasted . But having Object as parameter will virtually break this rule. Moreover, it will make your program more bug prone.
And that's the one of the top reasons, why generics were introduced.
Ankit
  • 153
Being flexible and able to handle multiple types of data is exactly what method overloading and interfaces were created for. Java already has the features that make handling these situations simpler while guarenteeing compile time safety via type checking.
Also, if it is impossible to narrowly define what data the method operates on, then that method may be doing too much and needs to be decomposed into smaller methods.
I like a rule of thumb I've read about (in Code Complete I think). The rule states that you should be able to tell what a function or method does just by reading its name. If it is really difficult to clearly name a function\method using that idea (or have to use And in the name) then the function/method is really doing too much.
Peter Smith
  • 2,587
First, if you pass the parameters as the concrete object, any error of using the wrong object (instance of a non expected class) will be detected in compile time, so will be faster to fix. In the other case, the error will be shown at runtime and will be harder to detect and fix.
Second, the code of checking the real class of the instance, reflection, etc, will be slower than a direct call
The rule that I follow is... parameter definitions should be as specific as needed by the method, and no more and no less.
If all I need is to iterate an enumerable, the param is defined as an enumerable, not an array or a list. This allows any type of enumerable to be used, avoiding converting to a specific type.
I also will not define it as an object because I need an enumerable. Any object that is not an enumerable will not work in this method. It's confusing to read a method signature and not know what it means, and only run-time testing can find the error.
What he does is throwing away all advantages of having a static type system.
Simply: It's much less clear to what such methods do, both to a compiler and to people reading the code.
One of the biggest reasons for a static type system is to have compile-time guarantees about what a program does. The compiler can check that a piece of code is used correctly and if not, issue a compiler-time error. Methods like you're colleague is writing are much more prone to run-time errors, because compiler-time checks are missing. Be prepared run-time errors and for writing a lot more tests.
Another big problem is that it's not at all clear what a method does. Reading such a code, maintaining it, or using it is a big pain.
Java added generics to give stronger compile-time guarantees about code, Scala is going even further with its functional approach, and sophisticated type system with covariant and contra-variant types. Your colleague is going backwards against this line of development, throwing away all its advantages.
If he used properly typed, overloaded methods instead, he (and you all) would gain:
  • Compiler time checking for correct usage of those methods.
  • Clear indication what combinations of arguments are allowed and what aren't.
  • The possibility to properly and separately document each of these combinations.
  • Code readability and maintainability.
  • It would help him to split his methods into smaller parts, which are easier to debug, test and maintain. (See also How to convince your fellow developer to write short methods?.)
Petr
  • 5,507
  • Some people don't regard a static type system as being advantageous, with numerous solid arguments to defend the position, as well as the good track record of dynamic languages in productivity and quality. – Kaz May 14 '13 at 21:02
    @Kaz Yes, I respect their arguments, but Java is then a very bad choice for such an approach. – Petr May 14 '13 at 21:48
  • But you don't always get to choose the tools which ideally match the approach. That doesn't automatically mean that the approach has to be dropped. – Kaz May 14 '13 at 21:51
    @Kaz: I think everyone can agree that a static type system has *some* advantages. Not everyone agrees on whether these advantages outweigh the advantages of the opposite approach; but this developer isn't getting the advantages of the opposite approach. (No ducktyping, no implicit typing, no terseness.) He's sacrificing *all* of the benefits of static typing, while shedding almost *none* of the costs. – ruakh May 15 '13 at 02:54
    @Kaz That's absurd. If you program in Java, follow Java conventions. If you program in Python, follow Python's. And not all of us think the arguments for dynamic type systems are "solid". – Andres F. May 15 '13 at 12:06
  • The only problem with always following conventions is that you live your life as a convention follower. Then why be in the software business. Software is infinitely malleable, unlike, say, wood. Go work with wood. (Java may be close, but not quite.) – Kaz May 15 '13 at 21:54
    @Kaz If you want to write experimental code against the conventions and assumptions of a language, by all means do it... on your own. If working with a team, follow the conventions. It's as simple as that. Also you are turning this into a debate about creativity, which is absurd. If you use a hammer as a hammer, instead of as a screwdriver, you are not being any less creative; you are using a tool for its best job. – Andres F. May 16 '13 at 12:14
  • It's a Java convention that objects are of type `Object` and that you can pass them to a function that takes `Object` without eliciting a compiler error. – Kaz May 16 '13 at 14:45
    @Kaz Nope. In fact, since the advent of generics in Java 1.5, it's frowned upon to write code that expects `Object` arguments, _except in very specialized situations_. Before, due to a limitation of the language, containers and collections had `Object` elements which you were forced to cast to the appropriate types -- an error prone task, and not very "dynamic" either since the typecasts were explicit! – Andres F. Sep 20 '13 at 18:35
  • @AndresF All dynamic languages (or their implementations) have to have some leaf level routines that inspect the type of an object, do some conversion to obtain a pointer to it (or other representation) and then do the type-specific operation. Once you build up these lower levels, the higher levels are easier: they just rely on these operations E.g. to add numbers together, you just call some `add(o1, o2)` or just `o1 + o2` via syntactic sugar. You don't have to check and convert `o1` and `o2` yourself; that's in the library (and eventually in the compiler, in a mature dynamic language). – Kaz Sep 20 '13 at 18:39
    @Kaz But Java is not a dynamic language, and if you use `Object`, you -- the programmer -- are later forced to do an _explicit_ conversion when you want to use the value. Therefore, _in Java_, it's a bad idea to use `Object`. Not in Python, not in whatever dynamic language you're thinking of, but in _Java_, which is what this question was about. – Andres F. Sep 20 '13 at 18:52
I actually had to work on a package like that once, it was a GUI package--the designer said he came from a Pascal background and thought passing around nothing but a base class everywhere was an awesome idea.
In 20 years, working with this toolkit was one of the most annoying experiences of my career.
Until you have to work with code like that you don't notice how much you rely on the data types in your parameters to guide you. If I said I had a method "connect(Object dest)", what does it mean? Even if you see "connect(Object website)" it's not much help, but "connect(String website)" or "connect(URL website)" you don't even have to think about it.
You might think "connect(Object website)" is a GREAT idea because it can take a string or a URL, but that just means I have to guess which cases the programmer decided to support and which he didn't. At best it moves most of the trial and error part of development from coding time to compile time, at worst it it make the whole development process muddy and annoying.
I (And most Java programmers, I believe) constantly figure out API call chains by examining a group of parameters to constructors to see which constructor to use, then how to build the objects you need to pass until you get to objects you have or can make--it's like putting a puzzle together instead of searching crappy documentation for incomplete examples (my pre-java experience with C).
Although building code like a puzzle seems ad-hock, it works amazingly well--all the time.
I know this has been answered, but this was an annoying enough experience that I really felt motivated to make sure as few people as possible need to go through it again.
Bill K
  • 2,699
  • The fix for that is "connect_httpd(Object url)". Look, countless programmers Get Stuff Done in languages that lack declarations: static languages with type inference, as well as dynamic languages. The anecdotal evidence of millions trounces the anecdotal evidence of one. You're arguing that since names of functions and arguments are badly chosen, and will stay that way, we should have declared types. Well, what's to stop me from having uselessly named types too that are not Object? "blurch(Widget foo)" Can't you understand? The function blurches the Widget! It's typed an everything! – Kaz May 15 '13 at 16:38
  • I've worked in Ruby and Groovy. Although I like coding small tasks in them, they are horrific when dealing with a poorly documented library or integrating with code from an adjacent team (that you aren't in contact with). Not enough information in the code is the reason. People get stuff done in Basic, Fortran, Cobol and machine language too--all have their place, many have advantages and disadvantages, but programmers Get Stuff Done isn't a good argument to chose any of them for a given task. – Bill K May 15 '13 at 17:12
  • "They are horrific" is not a fact, just your anecodtal experience. People get stuff done in Fortran and machine language, but beople get stuff done faster and easier in dynamic languages. Some of the things you can do in Ruby in minutes would you months in Java. – Kaz May 15 '13 at 17:24
  • People do small things quicker in Ruby and dynamic languages--say twitter. Large things not so much (say twitter). There are appropriate tools for every job, Ruby isn't the best answer for them all--are you suggesting it is? – Bill K May 15 '13 at 17:29
To give something a type give:
  1. Users an interface to code to with a semantic description.
  2. Compilers an interface to parse from to allow their optimizers to increase code execution time or shrink code size more easily.
  3. Early(static) binding which catches code errors early in the development cycle.
Using just an object conveys almost no information, thus removing all of these features that were put into the language for the reasons listed above.
Also, the type system was designed for flexibility with its is-a relationships allowing for all of these conditions. So use it to your advantage. Don't waste it by making unmaintainable code.
There may be a particular reason to do something like this at a particular time, but to do this it this generically all the time is poor practice. If you are doing it, get others to look over the problem and see if it can be done another way. In the majority of cases (99.999%) it can be.
In that 0.001% that it can't be, at least you are all on board and know what is happening (though you probably just need some fresh eyes on the problem).
Adrian
  • 157
Yes, this is poor practice because it makes no guarentee that the method will be able to do what it needs to for any particular input passed in. The goal of making a method that is widely useable is not a bad goal, but there are better ways to accomplish it.
For this particular case, it sounds like a perfect situation for the use of interfaces. An interface would ensure that objects being passed to the method provide the needed information and allows the casting to be avoided. There are some situations where this won't work well (like if it has to work with either sealed or base classes that you can't add an interface implementation to), but overall a method should only take input that is valid for it as parameters.
AJ Henderson
  • 701
Great in-depth answers so far, I really have to say that before even getting into high level philosophy and methodology, they are being lazy, short and simple.
They are not providing good information in their code for others to maintain and understand, and they are going against the design of the programming language at hand. I love PERL, I love Objective-C. I do not however make efforts to bend Java, C#, or C++ for that matter, toward my preferences at the expense of having maintainable, readable, and efficient code.
Yes, if they need to change how a function works, or what the inputs are, they saves a few line changes here and a few refactoring steps. However, the cost to others having to maintain the code is greater, not to mention most modern IDEs such as eclipse and Xcode can handle doing the refactoring automatically with a simple right click command. Furthermore, as others have mentioned, the processing cost is increased with each cast, with each unknown object type that's passed, and I imagine basic built in speedups that runtime would perform by knowing the proper classes are also thrown out the window.
Syntax sugar is always better than salt for the developer, but a balanced diet of both ensures the health of the project and others involved (customer, application, other developers, etc.)
FaultyJuggler
  • 179
There is no problem with this. In languages that do not have typed variables, this is what happens in every function. Formal parameters are just values, and the type is in the object that is passed, not in the formal parameter.
People Get Stuff Done (TM) in Lisp, Python, Ruby, ...
Though you benefit less from compile time type checking, you also suffer less from compile time type checking.
The real solution is to use some dynamic language that targets the Java virtual machine, instead of writing ugly Java code in which every third identifier is the word Object.
I does make sense to have a completely generic function called construct which takes arbitrary objects.
I think I would enjoy collaborating with this programmer. It would take some of the sting out of using a bletcherous programming language.
Note that this type of code occurs in C in the implementation of the run-time support for dynamic languages implemented in C. E.g. you might see something like this in a Lisp implemented in C:
/* Map each object in a list through a function, in order to produce
   a list of the return values. */
val mapcar(val function, val list)
   val iter = car(list);
   val out = nil;  /* nil is really a null pointer */
   for (iter = car(list); iter; iter = cdr(iter))
      push(funcall_1(function, car(iter)), out);  /* push is a C macro */
   return nreverse(out); /* destructively reverse list */
The val type is actually something like:
typedef struct object *val;
and struct object is a complicated structure that overlays various kinds of type information for various kinds of objects.
I developed a very nice little programming language, whose internals are all done in this style, which I deliberately kept as clean as possible: more so than in the internals of some other language implementation which take a similar approach.
In this style, amazing things are possible in a small amount of C code.
Kaz
  • 3,572
  • 30
    -1 Except in the OP it's made clear the programmer is not doing a form of duck typing, but in some cases actually casting to the "correct" type. This isn't at all a recommended practice in languages with dynamic typing such as Python, Ruby, etc. Instead, it's a deep misunderstanding of how OOP works, regardless of type system. – Andres F. May 15 '13 at 12:04
  • @AndresF Can you use an `Object` in all the necessary ways without obtaining a more specifically typed reference to it? Do Python and Ruby have the equivalent idea: that a variable is reference to a base, and has to be cast so that you can invoke the subclass operations? – Kaz May 15 '13 at 16:05
  • I don't think you have to explicitly cast in Python or Ruby (that runs contrary to their philosophies, as far as I can tell). E.g. you are encouraged to use [Duck Typing](http://en.wikipedia.org/wiki/Duck_typing) in Python; if you are casting, you are doing it wrong. And in Java, if you receive an `Object` but then cast it to a more appropriate subtype **you are also doing it wrong!** You are subverting Java's static type checks to gain nothing in return; you are essentially saying "I know how this will be used, but I don't want to let the compiler know. Just because." – Andres F. May 15 '13 at 17:56
  • Python casting is the conversion of a value to another type: essentially a construction of a new value based on another one. For instance an integer can be cast to boolean but what that means is that a boolean value is constructed which is true for a nonzero integer, false otherwise. This is not the same thing as casting static references in order to gain access to the full type of an object. I don't think Python has anything like Java references so to say that it's not a recommended practice is misleading; it's an impossible practice. – Kaz May 15 '13 at 18:28
  • But, of course, inside the Python interpreter, casting has to take place so that objects can be operated upon properly. If some object comes into a string function, the interpreter has to validate that it's a string, and then cast the pointer to the right type to work with it as a string object. Does that mean that the developers of Python do not understand how OOP works? – Kaz May 15 '13 at 18:31
  • I don't know how Python works internally (I suspect its dispatch system doesn't work like you describe it, but I may be wrong), but that's **irrelevant**. How a language is implemented internally is orthogonal to the paradigm it supports. An OOP language may very well be implemented internally using a paradigm incompatible with OOP. When writing Java code, however, you're supposed to use OOP; otherwise you've chosen the wrong tool for the job. – Andres F. May 15 '13 at 20:21
  • You don't seem to understand that there are different kinds of OOP. So if a language supports type B OOP, but I somehow work to bring about type A OOP, that doesn't mean I don't understand OOP, and it doesn't mean that I don't understand type B OOP (just that I'm rejecting some of it in that project). – Kaz May 15 '13 at 21:52
  • But what you call "type A OOP" is not what happens when programming in Python or Ruby either. So not only you'd be subverting Java's type system, you wouldn't even be doing what's recommended in Python. Duck-typing means _you don't explicitly cast_. This is _regardless_ of how it's implemented internally in Python, which has _nothing to do_ with the programming paradigms it supports. – Andres F. May 15 '13 at 22:38
-3
Assume for a minute that "Object guy" has reason for using a generic "loosely" typed object. We do not know his reasons, but it reminds me of the value of using inheritance and Generics (Templates). In the off chance that Object-guy is actually trying to make sense, this is the sense he might be trying to make:
I always base my objects on a single base object. This base object handles additional duties like exception handling, logging, profiling, and garbage collection.
I always base mathematical objects (those that might support mathematical operators) on a single base class. This helps provides utilities to handle exceptions in the event a derived class does not handle a certain operation. For example, using a Taylor series in the event an explicit representation for a function is not available.
So I do not know Object-guys reasons are: perhaps they are just because he like dynamic typing offered by other languages. But perhaps he is trying to appreciate the value of inheritance.
He may also want to explore Generics (Templates). I used them in C++ to define two, three, and four dimensional images, where the pixels can be bytes, ints, floats, complex, or spectra. I had to do a fair bit of casting, but the pay-off was significant in terms of separating the geometry of images from the computation of pixels.
xxyzzy
  • 101
    The value of inheritance is not "appreciated" by type casting. That's throwing OOP and polymorphism completely out the window (_regardless_ of type system!). – Andres F. May 15 '13 at 12:08
-6
Don't forget that this is a good pattern for languages like JavaScript which don't support passing parameters by name. Consider a function
function dialog( message, cancelButton, okText, notOkText ) { ... }
which has to be called like
dialog( "...", true, "...", "..." );
When you study the client code, it's not easy to remember the meaning of, say, the third parameter of the call. The readability of the client code suffers. Therefore, it is better to declare it with a param object
function dialog( options ) { ... }
which enables you to call it with named parameters:
dialog({
  message : "...",
  cancelButton: true,
  okText: "...",
  notOkText: "..."
Principle: We should reduce the number of parameters of a function (zero is excellent, one is frequent, two and more should be rare)!
rplantiko
  • 119
