I'm thinking of building a language for PIC microcontrollers. I want to be able to use non-fixed size arrays, like this:
- Declare the variable as
int[]
- Wait for input from serial connection
- Make the variable
input
long
I think such a feature would be useful, but don't know how I should go about implementing this in a compiler which compiles to assembly. I want the arrays to be stored on consecutive register addresses, of course. Since I'm working with PICs, this has to be very memory efficient.
When someone writes int[]
, I don't think it's a good idea to reserve memory space for the variable yet, is it? Then the array would have a fixed maximum size. For example, when the array gets reserved memory address 5-100, and other variables get 4 and 101, the array has fixed borders and can't grow any bigger than 96 registers. Also, when I'd reserve memory from the start, let's say x bytes, and I in the end only need y bytes, I'm wasting x - y bytes. I don't want that.
That means the only option I see is initializing the array and reserving space in the microcontroller, on the fly. This will take up some memory and execution time, of course. I thought of a system like this:
- Initialize an array
int[
x
] = {int, int}
which holds pointers to the start and end of arrays that are not initialized from the beginning -x
would be the maximum amount of arrays (this is a concession, but is better than a maximum length for all arrays) - Store a variable c = 0 to indicate the number of arrays used
- Store the borders of the initialized (reserved) memory in a variable somewhere
When an array gets a length:
- Put pointers to the start (the current border) and end (the current border + the length) in the array from the first point at index c
- Increment c
I think this would work (wouldn't it?), but there a few cons, mainly concerning memory: I need to store the array, c and the current memory borders as overhead.
Would there be a better way to implement non-fixed size arrays in a language for PIC microcontrollers? My requirements are:
- Low memory overhead
- The array length does not have to be changed on the fly
- With the system I thought up, one cannot store values in arrays that haven't been initialized yet. If there would be a system that can store values in an array of undefined length, that would be an advantage
- Faster systems (at runtime, compile time doesn't matter) are preferable
