The first answer to an old, recently active question linked to a video which talks about how Google repository is done.
One interesting thing which was mentioned is the fact that everything is build from source, without relying on binaries. This helps avoiding issues with dependencies becoming obsolete but still being used in other projects, an issue I indeed encountered a lot.
How is it technically possible? If I try the same thing in my company, even considering the huge gap between the scale of my company codebase and the scale of Google's one, it wouldn't be possible for two reasons:
  • The IDE (Visual Studio) will quickly become unresponsive, given that is suffers a lot at even small solutions containing, say, 50 projects.
  • Any static analysis would be crunched by the size of the whole codebase. For example code metrics or static checking of code contracts would hardly be possible (code contracts would probably take days or weeks).
  • With continuous integration, compiling would take a huge amount of time too and would crunch the servers as soon as a project with lots of dependencies is modified, requiring a large tree of projects to be recompiled.
How can a small company circumvent those issues and be able to:
  1. Use the IDE without being affected by poor performance,
  2. Compile the code after each commit without crunching the server, even when the consequences of a change require a large amount of the codebase to be recompiled?
Arseni Mourzenko
  • 134,780
  • 343
  • 513
You are assuming a traditional build process, and Google's process is anything but traditional. There's a series of articles in the Engineering Tools blog that explain their process in some detail, elaborating on the 2010 presentation: Tools for Continuous Integration at Google Scale:
  1. Build in the Cloud: Accessing Source Code
  2. Build in the Cloud: How the Build System works
  3. Build in the Cloud: Distributing Build Steps
  4. Build in the Cloud: Accessing Source Code
  5. Testing at the speed and scale of Google
To summarise, they use a custom distributed build system that allows for a very high degree of parallelism and automation, taking full advantage of their existing infrastructure. It also relies heavily on caching, with a 90% overall cache hit rate.
But how can you apply all this in your company? The first step is distributing compiling, and for that you'd need:
  • A cloud
  • A distributed compiler
  • A compiler cache
On a gcc development environment, setting up a compile farm is relatively easy. distcc takes care of distribution and ccache takes care of caching, and they work beautifully together. I don't know of any similar tools for Microsoft's ecosystem (I'm assuming you are using a Microsoft language based on your choice of IDE), but I do know that MSBuild can run builds in parallel, taking advantage of multi-core CPUs. Not really a compile farm, but certainly a step in the right direction.
yannis
  • 39,547
  • 40
  • 183
  • 216
  1. You don't have to build all 2000 projects to use just the ones you need.
  2. The Go language was specifically designed to alleviate this problem by making compile times very fast. it was one of the reasons they invented the language.
That said, I'd be wary of "just-in-time building," unless the code that is being deployed company-wide has been verified as part of a (more or less) formal release cycle, and is not just a random nightly build. H
Having 5000 developers accessing 2000 projects that are all in a continuous state of flux sounds like a recipe for disaster, and Google hires very smart people, so I'm quite certain that's not what is actually happening.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
  • 1. Of course, but that's why I told about the case where a modification is done in a project which affects many other projects. This doesn't happen often, but it happens. 2. In the video, Ashish Kumar notes that the codebase is mostly in C and Java. There was no mention of Go. – Arseni Mourzenko May 08 '13 at 22:14
  • Then perhaps the creation of Go is a response to the difficulties they are having. – Robert Harvey May 08 '13 at 22:15
  • true, but still, Google was still able to make it work for years. How? – Arseni Mourzenko May 08 '13 at 22:26
  • Very carefully? Remember, they didn't used to be as large as they are now. Did you watch [the video](http://www.infoq.com/presentations/Development-at-Google) that Patrick linked? – Robert Harvey May 08 '13 at 22:35
    I'm not really interested in the epoch where Google codebase was tiny, nor in the epoch where Google magically migrated/will migrate the whole codebase to Go. I'm talking about 2010 (the moment Ashish Kumar is talking about the codebase, I guess it's 2010). *In 2010*, according to the video by Ashish Kumar, (1) the codebase is huge, (2) it contains primary C and Java, (3) everything is compiled from source, (4) Google developers can still open code in their IDE and servers can still compile the code. Note: no, I haven't watched yet the video that Patrick linked. I'll watch it tomorrow. – Arseni Mourzenko May 08 '13 at 22:47
  • @MainMa: Well, I still stand by my statement that you can't have that many projects in flux continuously and expect it to hold together. They must be utilizing *some* form of configuration control or continuous integration. – Robert Harvey May 08 '13 at 22:55
