In the Go Language Tutorial, they explain how interfaces work:
Go does not have classes. However, you can define methods on struct types. The method receiver appears in its own argument list between the func keyword and the method name.
type Vertex struct {
X, Y float64
func (v *Vertex) Abs() float64 {
return math.Sqrt(v.X*v.X + v.Y*v.Y)
An interface type is defined by a set of methods. A value of interface type can hold any value that implements those methods.
This is the only way to create an interface in Go. Google further explains that:
A type implements an interface by implementing the methods. There is no explicit declaration of intent [i.e.
interface
declarations].Implicit interfaces decouple implementation packages from the packages that define the interfaces: neither depends on the other.
It also encourages the definition of precise interfaces, because you don't have to find every implementation and tag it with the new interface name.
This all sounds suspiciously like Extension Methods in C#, except that methods in Go are ruthlessly polymorphic; they will operate on any type that implements them.
Google claims that this encourages rapid development, but why? Do you give up something by moving away from explicit interfaces in C#? Could Extension Methods in C# allow one to derive some of the benefits that Go interfaces have in C#?
