I've extracted interfaces from my repository classes, like ICustomerRepository, IProductRepository and so on. The project which contains the repositories is named X.DataAccessLayer. Should I call the project with the interfaces X.DataAccessLayerInterfaces, or what is better?
And I definitely have to keep the interfaces in a separate project (I have 2 projects with implementations of these interfaces).
Den
  • 4,827
  • 32
user278618
  • 565
The naming pattern also depends on your other projects. Depending on the contents of your implementation projects it could be something like this:
  • X.DataAccessLayer
  • X.DataAccessLayer.Sql
  • X.DataAccessLayer.Oracle
PS: I would drop 'Layer' as well, unless you have a mix of independent libraries and actual layers.
Den
  • 4,827
  • 32
I would go with x.DataAccess.Interface and have your implementations as x.DataAccess.Oracle, x.DataAccess.EF or whatever.
Mr Cochese
  • 1,556
  • Your answer would be stronger if you provided supporting evidence or reasoning to justify the claim you've made. –  May 08 '13 at 10:33
Use whatever name you can think of that correctly describes the contents and does not feel too long.
Personally, X.DataAccessLayerInterfaces feels too long for me, so I would probably opt for X.DataAccessInterfaces, but otherwise there is nothing wrong with it.
Bart van Ingen Schenau
  • 71,712
  • 110
  • 179
