Is there a guide out there on how to choose when to pay for web hosting vs. hosting your own? Assuming that root access is a must I would like to compare things like cost, scalability and personal stress.
Here is what I could come up with.
Paying for web hosting:
Benefits:
  • Much cheaper for a small scale. I assume anything under $50 a month would be cheaper than paying for the bandwidth of hosting.
  • No stress in dealing with power outages, server restarts or internet going down.
  • For the most part less busy work involved with setting up.
Negatives:
  • Cost goes way up when higher specs are needed (for example monthly cost triples with ability to use 8gb of ram that you can buy for $90 ). This means you have to target a particular ram usage and monitor so your instance stays within the threshold.
  • root access for the most part is a premium.
  • You may get tied into a vendor specific deployment process.
Hosting on own :
Positives:
  • 100% control of specs and software.
  • When you get past paying for the bandwidth you get much more bang for your buck by building your own machine.
Negatives:
  • Doesn't make financial sense if bandwidth costs are more than web hosting costs.
  • Having to deal with power outages, server restarts or internet going down.
I think the best of both worlds would be if there was a place that dealt with bandwidth, power outages and server restarts but you provided your own server. Kind of like a 24 hour day care for a server. Does anything like that exist?
pllee
  • 1,212
    Wherever you plan to host your server will not be nearly as nice as a professional datacenter. N+1 redundancy everywhere, fire supression, adequate cooling, etc... Sounds like what you really want is to [colo a server](http://en.wikipedia.org/wiki/Colocation_centre). – Mike May 06 '13 at 17:30
  • Generally, you only host your own when you've reached a certain size threshold. That threshold depends entirely on what you feel comfortable with and what your needs are in terms of bandwidth, reliability and ownership. – Robert Harvey May 06 '13 at 17:31
    Concerning the last paragraphy, there is [colocation](http://en.wikipedia.org/wiki/Colocation_centre). – CodesInChaos May 06 '13 at 17:32
  • @Mike Awesome I have never heard of a colocation before. My google search for server daycare didn't return anything useful :) – pllee May 06 '13 at 17:40
  • imo, if you are posting a question like this you should provide the server specs you require to allow people to provide answers more suited to your specific situation. – GrandmasterB May 06 '13 at 18:19
  • @GrandmasterB I really didn't want to post the specs I need cause I want others to find the question useful as well. Also I am just looking for a generic guide. – pllee May 06 '13 at 18:32
The 24x7 care are looking for is called Managed Hosting -- many firms exist that do that in various capacities for various fees. I'll note it is nice but it still won't necessarily replace having a good, knowledgeable engineer who knows your application and stack around to put out fires -- the host often can do little more than tell you your database server has locked up but they likely can't fix it.
In 2013, if you are building an internet facing application, there is very, very little reason to burden yourself with hosting the production instances yourself unless you happen to have in your possession a data center with all the typical niceties they come with like redundant power, redundant internet connections, 24x7 skilled labor around to support your box. If you've got those you'd also probably appreciate what stuff like that costs and why it seems dramatically more expensive.
Wyatt Barnett
  • 20,685
  • 50
  • 69
Would you consider leasing a VPS paying for hosting or hosting your own? I find it's the best of both worlds, and these days it's quite cheap. I've had better than 99.99 uptime in the last three years, which is also incredibly good.
Jonathan Rich
  • 2,958
  • Paying for a vps or even something like a nice hosting site the provides root access are really the only options I am considering now. The costs are just way too good. The only negative I can think of is that I have to target a certain spec which isn't a big deal. – pllee May 06 '13 at 17:45
  • What do you mean by certain spec? – Jonathan Rich May 06 '13 at 17:58
  • I mean spec as in server specs, for the plan the I am intending on using I only get 500mb of ram and limited cpu spikes. – pllee May 06 '13 at 18:05
  • You might want to look at different companies. I've found that some are much more flexible than others. – Jonathan Rich May 06 '13 at 18:27
  • Rackspace. Highly recommend you look at them, and similar companies for hosting. Depending on platform is what drives the costs, due to licensing really. Stick to Linux unless you have no choice, and your costs are going to be really low. Also, 512 on a Linux machine is far more useful than on a Windows machine. – JClaspill May 06 '13 at 20:46
I would say "paid" hosting has many many different flavors (shared, dedicated virtual, dedicated, etc..). And those comparisons are most likely available all over. When comparing that to hosting your own (I'm assuming in your home / garage), there is no comparison for any real world application if uptime, security and reliability are a concern.
Hosting your own machine is okay for information websites that wont sue you for going down, but you take on all the risk for uptime and security. both of which can drive your clients away (if that's your model), or compromise your customers data (if you're hosting their data).
you can get a basic hosting plan for very cheap, even free, and will require much less pain so it doesnt really make sense
if you want full control and 100% of the resources, then I would recommend getting a dedicated box from a hosting company, generally you just have to pay for the OS license if that even applies.. then you can RDP in and do whatever you want to it, you'll still have to worry about local security, but the power company wont be shutting you down during the day for their normal maintenance.
Amazon offers some free virtual instances, and I would recommend starting there.. the machines are pretty weak, but the price justifies the performance you get.
hanzolo
  • 3,111
  • I am targeting EC2 servers as of now. I have no problem paying for their next tier if need be, their prices seem pretty fair. And really if I can turn a profit paying for server costs is not a big deal. But since I haven't released yet it is impossible to know if the website will "take off". A couple hundred dollars a year is well worth that risk but to me a couple of thousand really isn't. I am no where near the couple of thousand mark but it is good to know there are other options if I end up needing a higher cpu specs. – pllee May 06 '13 at 18:14
