Is there a difference between HttpRequest and xmlHttpRequest in terms of security? Is one more secure than the other?
Is it more secure to send important data such as passwords via HttpRequest than via xmlHttpRequest ?
Is data packing in both done the same way?
tdammers
  • 52,406
  • 106
  • 154
msoa
  • 149
    This is a pretty vague question. Both are equally insecure if you make the requests over unsecured connections. Both are equally secure if you make the requests over SSL connections. A request made over an SSL connection might (ultimately) be profoundly non-secure if you aren't protecting the data appropriately on the server, etc. – Craig Tullis Apr 20 '13 at 09:43
Short answer no. If your posting back to a https server in one and http in another then yes https is more secure. They do the same things internally but are triggered differently and lead to different outcomes. Ajax (xmlHttpRequest ) returns some text - xml or plain by calling a javascript function in same page; a form post navigates to a new page - could be back to same but browser does not care - it needs to re-render.
You can do a secure AJAX posting. Using https shoud be enough, to be extra careful can mask the sensitive data and clear (or change the value) of js variables and form that that holds password after sending to server. see https://stackoverflow.com/questions/12157970/codeigniter-how-can-i-encrypt-password-before-submitting-the-form-to-the-contro
tgkprog
  • 595
