I mostly work in Python and Ruby, but I recently decided to learn some C so I have a better feel for how a computer actually works.
I've been wondering whether it is possible to take this even a step further. Does anyone learn machine code (whatever C is compiled into) anymore? Would I benefit from taking some time to learn it?
Phil Braun
  • 411
    Is there ever not a benefit from learning something? – GrandmasterB Apr 16 '13 at 20:24
    @GrandmasterB - yes the time you spent when you could have been learning something else. Would you have been better learning eg. a functional language than the details of compromises made by x86 20years ago – Martin Beckett Apr 16 '13 at 20:34
  • The content of this question has been rephrased over and over again in other questions.. it never ends well – hanzolo Apr 16 '13 at 20:40
    @MartinBeckett The question is whether there is a benefit, not whether the benefit is less than learning something else instead. – The Muffin Man Apr 16 '13 at 22:19
I learned it, but that was back in the days when Real Programmers Wore Mountain Boots.
Learning assembly will give you a wonderful appreciation for memory management, pointers, buffer overflows, caffeine, and the value of extreme patience.
My personal opinion is that it's worth writing a small test program or two, but not much more than that.
It takes a tremendous amount of effort to code features that are almost trivial to do in modern environments. (e.g., text to speech)
Martin Beckett
  • 15,776
  • 42
  • 69
Dan Pichelman
  • 13,773
  • 42
  • 73
    "Real Programmers Wore Mountain boots." was a great read – hanzolo Apr 16 '13 at 20:47
    Real programmers *still* say things like `if (i % 2 == 0)` – Robert Harvey Apr 16 '13 at 21:01
    Of course if you want to someday get a job writing compilers for a living, you might find it a lot more useful to learn assembly language for a couple of different CPU's than you would if you plan to work on a lot of line-of-business apps, but really have no plans to become a compiler programmer. Just saying... ;) – Craig Tullis Apr 18 '13 at 04:43
    My favorite: *Real Programmers don't write in FORTRAN. FORTRAN is for pipe stress freaks and crystallography weenies.* – Robert Harvey Dec 28 '13 at 03:25
  • I'm not sure text-to-speech is a good example because in both cases you are just calling an external library. – Zaz Jul 16 '23 at 23:11
Probably not.
There is an argument that knowing machine code will help you understand what the machine is doing in more detail. But so would knowing how the transistors work and nobody suggests you need to know semiconductor physics to be a good programmer!
Having some idea what the code is doing and what operations, such as copying memory or accessing a disk, are expensive is useful - but you can know these without being fluent in assembler. There was also an argument that assembler helps you debug a stack dump - but modern compilers can produce some very odd optomised code which is almost impossible to understand/.
If you want to understand assembler for the pure joy of it - then there are a number of synthetic assemblers, or at least more modern CPU designs which are cleaner than x86
Martin Beckett
  • 15,776
  • 42
  • 69
