-2
I know there are some products for reverse debugging.
I am wondering that does reverse debugging mean going to one step back or starting over again up to one step back?
I've found an explanation here.
yfklon
  • 1,752
  • 30
    I can't tell you if it means "really debugging backwards" because I don't know what *you mean by* "really debugging backwards" ;-) –  Apr 16 '13 at 16:49
    @delnan: He means "does it reverse the previous step or does it run from the beginning with a virtual breakpoint on the previous line." – pdr Apr 16 '13 at 16:54
    Reverse debugging is putting the bugs back in. – Anthony Pegram Apr 16 '13 at 16:59
    Are you thinking of the [omniscient debugger](http://www.lambdacs.com/debugger/)? –  Apr 16 '13 at 17:00
According to the link you posted, "reverse debugging" means being able to undo instructions in the debugger. So you'd have something like a 'step back' command that tells the debugger to reverse the effect of the last instruction executed. It doesn't mean re-running the program to get back to the previous instruction.
Caleb
  • 38,959
  • 94
  • 152
