74
An enum X : int (C#) or enum class X : int (C++11) is a type that has a hidden inner field of int that can hold any value. In addition, a number of predefined constants of X are defined on the enum. It is possible to cast the enum to its integer value and vice versa. This is all true in both C# and C++11.
In C# enums are not only used to hold individual values, but also to hold bitwise combinations of flags, as per Microsoft's recommendation. Such enums are (usually, but not necessarily) decorated with the [Flags] attribute. To make the lives of developers easier, the bitwise operators (OR, AND, etc...) are overloaded so that you can easily do something like this (C#):
void M(NumericType flags);
M(NumericType.Sign | NumericType.ZeroPadding);
I am an experienced C# developer, but have been programming C++ only for a couple of days now, and I am not known with the C++ conventions. I intend to use a C++11 enum in the exact same way as I was used to do in C#. In C++11 the bitwise operators on scoped enums are not overloaded, so I wanted to overload them.
This solicited a debate, and opinions seem to vary between three options:
  1. A variable of the enum type is used to hold the bit field, similar to C#:
    // With operator overloading:
    M(NumericType::Sign | NumericType::ZeroPadding);
    // Without operator overloading:
    M(static_cast<NumericType>(static_cast<int>(NumericType::Sign) | static_cast<int>(NumericType::ZeroPadding)));
    But this would counter the strongly typed enum philosophy of C++11's scoped enums.
  2. Use a plain integer if you want to store a bitwise combination of enums:
    void M(int flags);
    M(static_cast<int>(NumericType::Sign) | static_cast<int>(NumericType::ZeroPadding));
    But this would reduce everything to an int, leaving you with no clue as to which type you're supposed to put in the method.
  3. Write a separate class that will overload operators and hold the bitwise flags in a hidden integer field:
    class NumericTypeFlags {
        unsigned flags_;
    public:
        NumericTypeFlags () : flags_(0) {}
        NumericTypeFlags (NumericType t) : flags_(static_cast<unsigned>(t)) {}
        //...define BITWISE test/set operations
    void M(NumericTypeFlags flags);
    (full code by user315052)
    But then you have no IntelliSense or whatever support to hint you at the possible values.
I know this is a subjective question, but: What approach should I use? What approach, if any, is the most widely recognized in C++? What approach do you use when dealing with bit fields and why?
Of course since all three approaches work, I'm looking for factual and technical reasons, generally accepted conventions, and not simply personal preference.
For example, because of my C# background I tend to go with approach 1 in C++. This has the added benefit that my development environment can hint me on the possible values, and with overloaded enum operators this is easy to write and understand, and quite clean. And the method signature shows clearly what kind of value it expects. But most people here disagree with me, probably for good reason.
Daniel A.A. Pelsmaeker
  • 2,715
    The ISO C++ committee found option 1 important enough to explicitly state that the value range of enums includes all binary combinations of flags. (This predates C++03) So there's an objective approval of this somewhat subjective question. – MSalters Mar 16 '15 at 16:30
    (To clarify @MSalters' comment, a C++ enum's range is based on its underlying type (if a fixed type), or otherwise on its enumerators. In the latter case, the range is based on the smallest bitfield that can hold all defined enumerators; e.g., for `enum E { A = 1, B = 2, C = 4, };`, the range is `0..7` (3 bits). Thus, the C++ standard explicitly guarantees that #1 will always be a viable option. [Specifically, `enum class` defaults to `enum class : int` unless otherwise specified, and thus always has a fixed underlying type.]) – Justin Time - Reinstate Monica Sep 25 '19 at 19:23
  • This group won't let me post answers yet, but I have answered a similar question about bitfields on StackOverflow at: "https://stackoverflow.com/questions/3942426/how-to-templateize-variable-names-not-types/60782429#60782429". It boils down to using a macro "namedBitFields()" to create typed getters/setters for bitfields within a class member variable. – kch_PE_MSEE_BSCE Mar 20 '20 at 23:37
    Option 4: use an unscoped enumeration. – Caleth Mar 23 '20 at 13:20
  • Worthwhile reading: [Using enum classes as type-safe bitmasks](https://wiggling-bits.net/using-enum-classes-as-type-safe-bitmasks/) – Toby Speight Feb 19 '22 at 11:37
7 Answers7
39
The simplest way is to provide the operator overloads yourself. I am thinking of creating a macro to expand the basic overloads per type.
#include <type_traits>
enum class SBJFrameDrag
    None = 0x00,
    Top = 0x01,
    Left = 0x02,
    Bottom = 0x04,
    Right = 0x08,
inline SBJFrameDrag operator | (SBJFrameDrag lhs, SBJFrameDrag rhs)
    using T = std::underlying_type_t <SBJFrameDrag>;
    return static_cast<SBJFrameDrag>(static_cast<T>(lhs) | static_cast<T>(rhs));
inline SBJFrameDrag& operator |= (SBJFrameDrag& lhs, SBJFrameDrag rhs)
    lhs = lhs | rhs;
    return lhs;
(Note that type_traits is a C++11 header and std::underlying_type_t is a C++14 feature.)
AntonioCS
  • 179
Dave
  • 391
    std::underlying_type_t is C++14. Can use std::underlying_type::type in C++11. – ddevienne Aug 04 '15 at 15:21
    Why are you using `static_cast` for input, but C-style cast for result here? – Ruslan Jan 05 '16 at 17:29
    @Ruslan I second this question – audiFanatic Jul 08 '16 at 16:18
  • Why are you even bothering with std::underlying_type_t when you already know it is int? – poizan42 Nov 13 '18 at 10:02
    If `SBJFrameDrag` is defined in a class and the `|`-operator is later used in the definitions of the same class, how would you define the operator such that it could be used within the class? – HelloGoodbye Dec 19 '18 at 15:36
  • Also, how can I make an expression like `if (mySBJFrameDrag & SBJFrameDrag::left)` work without changit it? The expression within the parenthesis generated a new `SBJFrameDrag` and not a `bool` which is required by the condition, and it seems like it cannot be automatically converted to a `bool`. – HelloGoodbye Dec 19 '18 at 15:40
    Using `std::underlying_type` provides greater forwards compability, @poizan42, in that the operators will automagically update if the enum's underlying type is changed in the future. – Justin Time - Reinstate Monica Sep 25 '19 at 19:26
  • Typically, @HelloGoodbye, that particular example would be the more verbose `if ((mySBJFrameDrag & SBJFrameDrag::left) == SBJFrameDrag::left)`, with or without extraneous parentheses depending on the style. Alternatives include supplying a `Test()` function, or wrapping the enum in a type that can provide conversion operators. – Justin Time - Reinstate Monica Oct 18 '19 at 21:58
Historically, I would always have used the old (weakly-typed) enumeration to name the bit constants, and just used the storage class explicitly to store the resulting flag. Here, the onus would be on me to make sure my enumerations fit in the storage type, and to keep track of the association between the field and it's related constants.
I like the idea of strongly-typed enums, but I'm not really comfortable with the idea that variables of enumerated type may contain values that aren't among that enumeration's constants.
Eg, assuming the bitwise or has been overloaded:
enum class E1 { A=1, B=2, C=4 };
void test(E1 e) {
    switch(e) {
    case E1::A: do_a(); break;
    case E1::B: do_b(); break;
    case E1::C: do_c(); break;
    default:
        illegal_value();
test(E1::A); // ok
test(E1::A | E1::B); // nope
For your 3rd option, you need some boilerplate to extract the enumeration's storage type. Assuming we want to force an unsigned underlying type (we can handle signed too, with a little more code):
template <size_t Size> struct IntegralTypeLookup;
template <> struct IntegralTypeLookup<sizeof(int64_t)> { typedef uint64_t Type; };
template <> struct IntegralTypeLookup<sizeof(int32_t)> { typedef uint32_t Type; };
template <> struct IntegralTypeLookup<sizeof(int16_t)> { typedef uint16_t Type; };
template <> struct IntegralTypeLookup<sizeof(int8_t)>  { typedef uint8_t Type; };
template <typename IntegralType> struct Integral {
    typedef typename IntegralTypeLookup<sizeof(IntegralType)>::Type Type;
template <typename ENUM> class EnumeratedFlags {
    typedef typename Integral<ENUM>::Type RawType;
    RawType raw;
public:
    EnumeratedFlags() : raw() {}
    EnumeratedFlags(EnumeratedFlags const&) = default;
    void set(ENUM e)   { raw |=  static_cast<RawType>(e); }
    void reset(ENUM e) { raw &= ~static_cast<RawType>(e); };
    bool test(ENUM e) const { return raw & static_cast<RawType>(e); }
    RawType raw_value() const { return raw; }
enum class E2: uint8_t { A=1, B=2, C=4 };
typedef EnumeratedFlags<E2> E2Flag;
This still doesn't give you IntelliSense or autocompletion, but the storage type detection is less ugly than I originally expected.
Now, I did find an alternative: you can specify the storage type for a weakly-typed enumeration. It even has the same syntax as in C#
enum E4 : int { ... };
Because it's weakly-typed, and implicitly converts to/from int (or whatever storage type you choose), it feels less weird to have values which don't match the enumerated constants.
The downside is that this is described as "transitional" ...
NB. this variant adds its enumerated constants to both the nested and the enclosing scope, but you can work around this with a namespace:
namespace E5 {
    enum Enum : int { A, B, C };
E5::Enum x = E5::A; // or E5::Enum::A
Useless
  • 12,380
    Another downside of weakly typed enums is that their constants pollute my namespace, since they don't need to be prefixed with the enum name. And that may also cause all kinds of weird behavior if you have two different enums both with a member with the same name. – Daniel A.A. Pelsmaeker Apr 09 '13 at 13:44
  • That's true. The weakly-typed variant with the specified storage type adds its constants to both the enclosing scope _and_ its own scope, iiuc. – Useless Apr 09 '13 at 14:00
  • The unscoped enumerator is only declared in the surrounding scope. Being able to qualify it by the enum-name is part of lookup rules, not the declaration. C++11 7.2/10: Each enum-name and each unscoped enumerator is declared in the scope that immediately contains the enum-specifier. Each scoped enumerator is declared in the scope of the enumeration. These names obey the scope rules defined for all names in (3.3) and (3.4). – Lars Viklund Mar 10 '14 at 20:56
    with C++11 we have std::underlying_type that provides the underlying type of an enum. So we have 'template struct Integral { typedef typename std::underlying_type::type Type; }; ` In C++14 these is even more simplified to'template struct Integral { typedef std::underlying_type_t Type; }; – emsr May 02 '14 at 21:22
You can define type-safe enum flags in C++11 by using std::enable_if. This is a rudimentary implementation that may be missing some things:
template<typename Enum, bool IsEnum = std::is_enum<Enum>::value>
class bitflag;
template<typename Enum>
class bitflag<Enum, true>
public:
  constexpr const static int number_of_bits = std::numeric_limits<typename std::underlying_type<Enum>::type>::digits;
  constexpr bitflag() = default;
  constexpr bitflag(Enum value) : bits(1 << static_cast<std::size_t>(value)) {}
  constexpr bitflag(const bitflag& other) : bits(other.bits) {}
  constexpr bitflag operator|(Enum value) const { bitflag result = *this; result.bits |= 1 << static_cast<std::size_t>(value); return result; }
  constexpr bitflag operator&(Enum value) const { bitflag result = *this; result.bits &= 1 << static_cast<std::size_t>(value); return result; }
  constexpr bitflag operator^(Enum value) const { bitflag result = *this; result.bits ^= 1 << static_cast<std::size_t>(value); return result; }
  constexpr bitflag operator~() const { bitflag result = *this; result.bits.flip(); return result; }
  constexpr bitflag& operator|=(Enum value) { bits |= 1 << static_cast<std::size_t>(value); return *this; }
  constexpr bitflag& operator&=(Enum value) { bits &= 1 << static_cast<std::size_t>(value); return *this; }
  constexpr bitflag& operator^=(Enum value) { bits ^= 1 << static_cast<std::size_t>(value); return *this; }
  constexpr bool any() const { return bits.any(); }
  constexpr bool all() const { return bits.all(); }
  constexpr bool none() const { return bits.none(); }
  constexpr operator bool() const { return any(); }
  constexpr bool test(Enum value) const { return bits.test(1 << static_cast<std::size_t>(value)); }
  constexpr void set(Enum value) { bits.set(1 << static_cast<std::size_t>(value)); }
  constexpr void unset(Enum value) { bits.reset(1 << static_cast<std::size_t>(value)); }
private:
  std::bitset<number_of_bits> bits;
constexpr typename std::enable_if<std::is_enum<Enum>::value, bitflag<Enum>>::type operator|(Enum left, Enum right)
  return bitflag<Enum>(left) | right;
constexpr typename std::enable_if<std::is_enum<Enum>::value, bitflag<Enum>>::type operator&(Enum left, Enum right)
  return bitflag<Enum>(left) & right;
constexpr typename std::enable_if_t<std::is_enum<Enum>::value, bitflag<Enum>>::type operator^(Enum left, Enum right)
  return bitflag<Enum>(left) ^ right;
Note the number_of_bits can unfortunately not be filled in by the compiler, as C++ doesn't have any way to do introspect the possible values of an enumeration.
Edit: Actually I stand corrected, it is possible to get the compiler fill number_of_bits for you.
Note this can handle (wildly inefficiently) a non-continuous enum value range. Let's just say it's not a good idea to use the above with an enum like this or madness will ensue:
enum class wild_range { start = 0, end = 999999999 };
But all things considered this is a quite usable solution in the end. Doesn't need any user-side bitfiddling, is type-safe and within its bounds, as efficient as it gets (I'm leaning strongly on std::bitset implementation quality here ;)).
Inobelar
rubenvb
  • 580
  • I'm sure I missed some overloads of the operators. – rubenvb Dec 19 '16 at 23:33
    `std::bitset`'s API takes bit _position_ arguments, so using `1 << size_t(e)` is **not** correct. At least when using an `enum` with continues values (0, 1, 2, ...). Adapted your code, and wrote a test, and found it out :) – ddevienne Jan 04 '22 at 12:02
  • That `number_of_bits` isn't what you think it is - that's the number of bits used to represent `Enum`, not the maximum value declared for it. – Toby Speight Feb 19 '22 at 21:32
I hate detest macros in my C++14 as much as the next guy, but I've taken to using this all over the place, and quite liberally too:
#define ENUM_FLAG_OPERATOR(T,X) inline T operator X (T lhs, T rhs) { return (T) (static_cast<std::underlying_type_t <T>>(lhs) X static_cast<std::underlying_type_t <T>>(rhs)); }
#define ENUM_FLAGS(T) \
enum class T; \
inline T operator ~ (T t) { return (T) (~static_cast<std::underlying_type_t <T>>(t)); } \
ENUM_FLAG_OPERATOR(T,|) \
ENUM_FLAG_OPERATOR(T,^) \
ENUM_FLAG_OPERATOR(T,&) \
enum class T
Making use as simple as
ENUM_FLAGS(Fish)
    OneFish,
    TwoFish,
    RedFish,
    BlueFish
And, as they say, the proof is in the pudding:
ENUM_FLAGS(Hands)
    NoHands = 0,
    OneHand = 1 << 0,
    TwoHands = 1 << 1,
    LeftHand = 1 << 2,
    RightHand = 1 << 3
Hands hands = Hands::OneHand | Hands::TwoHands;
if ( ( (hands & ~Hands::OneHand) ^ (Hands::TwoHands) ) == Hands::NoHands)
    std::cout << "Look ma, no hands!" << std::endl;
Feel free to undefine any of the individual operators as you see fit, but in my highly-biased opinion, C/C++ is for interfacing with low-level concepts and streams, and you can pry these bitwise operators out of my cold, dead hands and I'll fight you with all the unholy macros and bit-flipping spells I can conjure to keep them.
    If you detest macros so much, why not use a *proper* C++ construct and write some template operators instead of the macros? Arguably, the template approach is better because you can use `std::enable_if` with `std::is_enum` to restrict your free operator overloads to only working with enumerated types. I've also added comparison operators (using `std::underlying_type`) and the logical not operator to further bridge the gap without losing the strong typing. The only thing I can't match is implicit conversion to bool, but `flags != 0` and `!flags` are sufficient for me. – monkey0506 Oct 26 '16 at 07:50
  • @monkey0506 because you only want to define bitwise operators for *some* enums – Caleth Mar 23 '20 at 12:47
  • @Caleth if you're using `std::enable_if` then you could use *any* compile-time constant constraint of your choosing, including a cherry-picked list of types to implement the operators for. There's nothing about that requirement, to only have bitwise operators for certain types, that precludes using templated overloads of free operators. – monkey0506 Mar 24 '20 at 22:28
A short example of enum-flags below, looks pretty much like C#.
About the approach, in my opinion: less code, less bugs, better code.
#indlude "enum_flags.h"
ENUM_FLAGS(foo_t)
enum class foo_t
     none           = 0x00
    ,a              = 0x01
    ,b              = 0x02
ENUM_FLAGS(foo2_t)
enum class foo2_t
     none           = 0x00
    ,d              = 0x01
    ,e              = 0x02
int _tmain(int argc, _TCHAR* argv[])
    if(flags(foo_t::a & foo_t::b)) {};
    // if(flags(foo2_t::d & foo_t::b)) {};  // Type safety test - won't compile if uncomment
ENUM_FLAGS(T) is a macro, defined in enum_flags.h (less then 100 lines, free to use with no restrictions).
Yuri Yaryshev
  • 237
Typically you'd define a set of integer values that correspond to single-bit set binary numbers, then add them together. This is the way C programmers usually do it.
So you'd have (using the bitshift operator to set the values, eg 1 << 2 is the same as binary 100)
#define ENUM_1 1
#define ENUM_2 1 << 1
#define ENUM_3 1 << 2
etc
In C++ you have more options, define a new type rather that is an int (use typedef) and similarly set values as above; or define a bitfield or a vector of bools. The last 2 are very space efficient and make a lot more sense for dealing with flags. A bitfield has the advantage of giving you type checking (and therefore intellisense).
I'd say (obviously subjective) that a C++ programmer should use a bitfield for your problem, but I tend to see the #define approach used by C programs a lot in C++ programs.
I suppose the bitfield is the closest to C#'s enum, why C# tried to overload an enum to be a bitfield type is weird - an enum should really be a "single-select" type.
gbjbaanb
  • 48,354
  • 102
  • 172
    C++14 allows you to define binary literals (e.g. `0b0100`) so the `1 << n` format is sort of obsolete. – Rob K Mar 16 '15 at 20:55
  • Maybe you meant [bitset](https://en.cppreference.com/w/cpp/utility/bitset) instead of bitfield. – Jorge Bellon Dec 21 '18 at 16:49
  • @RobK Ugh, I rather prefer the rhs of `<<` to indicate the set bit directly and don't want to count the 0's around the 1. – Ray May 20 '20 at 00:50
There is yet another way to skin the cat:
Instead of overloading the bit operators, at least some might prefer to just add a 4 liner to help you circumvent that nasty restriction of scoped enums:
#include <cstdio>
#include <cstdint>
enum class Foo : uint16_t { A = 0, B = 1, C = 2 };
// ut_cast() casts the enum to its underlying type.
template <typename T>
inline auto ut_cast(T x) -> std::enable_if_t<std::is_enum_v<T>,std::underlying_type_t<T>>
    return static_cast<std::underlying_type_t<T> >(x);
int main(int argc, const char*argv[])
   Foo foo{static_cast<Foo>(ut_cast(Foo::B) | ut_cast(Foo::C))};
   Foo x{ Foo::C };
   if(0 != (ut_cast(x) & ut_cast(foo)) )
       puts("works!");
    else
        puts("DID NOT WORK - ARGHH");
   return 0;
Granted, you have to type the ut_cast() thing each time, but on the up side, this yields more readable code, in the same sense as using static_cast<>() does, compared to implicit type conversion or operator uint16_t() kind of things.
And let's be honest here, using type Foo as in the code above has its dangers:
Somewhere else someone might do a switch case over variable foo and not expect that it holds more than one value...
So littering the code with ut_cast() helps alert readers that something fishy is going on.
BitTickler
  • 201
