I want to build a command line interface with menus and sub-menus and eventually the leafs of the tree should be operations like.. bank management -> account management -> add acount (insert account info) And I'm looking for a good way which works with the OO principles...
Thanks for any piece of advice!
aclowkay
  • 131
    navigating a CLI can be seen as traversing a state machine, with each state a menu and the edges the commands at each menu – ratchet freak Mar 27 '13 at 10:38
  • yeah..but should do it with a while loop? or what..im stuck with it – aclowkay Mar 27 '13 at 11:10
  • I tried making a "menunude" abstract class which has the sub classes menu and operation..menu has a list of menus and operation has an execute function which does whatever it's supposed to do...the problem is what to put in the main thingy – aclowkay Mar 27 '13 at 11:27
if you want OO I suggest a Menu interface with methods to write out the options and parsing the input and returning the next Menu
so your main loop becomes:
Menu menu = new StartMenu();
    while(menu.isExit){
    menu.writeOptions(stdOut);
    Menu res = menu.parseInput(stdIn.readline());
    if(res==null)
        writeError(stdOut);
    else
        menu=res;
ratchet freak
  • 25,706
  • 62
  • But what If I want to encapsulate the whole loop inside a seperate menu class,How should I do that? – aclowkay Mar 27 '13 at 11:58
  • You could put this code inside a static method in the base class if you really wanted to. Call it RunMenu(). – Ben313 Mar 27 '13 at 16:33
