I have been seeing a lot of projects that have repositories that return instances of IQueryable
. This allows additional filters and sorting can be performed on the IQueryable
by other code, which translates to different SQL being generated. I am curious where this pattern came from and whether it is a good idea.
My biggest concern is that an IQueryable
is a promise to hit the database some time later, when it is enumerated. This means that an error would be thrown outside of the repository. This could mean an Entity Framework exception is thrown in a different layer of the application.
I have also run into issues with Multiple Active Result Sets (MARS) in the past (especially when using transactions) and this approach sounds like it would lead to this happening more often.
I have always called AsEnumerable
or ToArray
at the end of each of my LINQ expressions to make sure the database is hit before leaving the repository code.
I am wondering if returning IQueryable
could be useful as a building block for a data layer. I have seen some pretty extravagant code with one repository calling another repository to build an even bigger IQueryable
