70
Bug tracker for any decent sized project seem like a bit of a no-brainer to me - it makes it really easy to organise hundreds or thousands issues, without issues colliding or getting mixed up.
So when I see some really big projects, like Git, using a mailing list as the main method of coordinating maintenance and development, I get a bit blown away. Examples:
  • Git - Community page:
    ...Bug reports should be sent to this mailing list.
  • Debian bug tracking system, per Wikipedia:
    ...Its unique feature is that it doesn't have any form of web-interface to edit bug reports - all modification is done through email.
Many modern bug trackers have very good integration with email (you can receive comments or notifications about bugs you're watching, or that get assigned to you), as well as to version control systems (commits can be marked as resolving an issue, etc.). Much of this would have to be done manually with a mailing list, and you get tons of emails about bugs you're not interested in.
So what are the main advantages of a mailing list over a web-based bug tracker? Why do some big projects only use a mailing list?
gnat
  • 21,442
  • 112
  • 288
naught101
  • 1,210
    Yes, no, I agree wit you, Git uses mailing lists:) What I was saying is that you're lumping it in with "some really big projects" and I was just thinking that if you do that you should give a bit more examples for those really big projects. Otherwise the question comes down to "Git uses mailing list, why is that?" in which case Jörg W Mittag's answer is better suited... – Shivan Dragon Mar 26 '13 at 12:36
    Hrm, well I was under the impression that there were more... Debian uses a [mail based system](https://en.wikipedia.org/wiki/Debian_bug_tracking_system), albeit more complex than a mailing list. Ok, but the main point is 'what are the advantages of using a mailing list over a bug tracker?' Unless the answer is "there aren't any, git developers are just luddites". – naught101 Mar 26 '13 at 13:01
  • @naught101: why do you get blown away when you see that? Debian *unstable* can be installed and used without seeing any remote root exploit needing patching and without needing any reboot for six months easily. That's for the *unstable* version of Debian. I've got Debian servers locked down who reached 4-digits days of uptime (not a single remote root exploit requiring a reboot affecting my setup during that period). These guys may not be using the latest technology fad, but they're obviously doing things right. I'd give up web bug trackers for Debian stability anytime. – Cedric Martin Mar 29 '13 at 17:23
    @CedricMartin: I know, I agree. Mailing list bug tracking clearly works adequately for some teams, but it still seems less easy than a bug tracker, to me. I've been thinking though, that for the core project developers, the difference may seem very small: they follow nearly everything that's going on anyway. But for new-comers, a mailing list is nearly impossible to grok, so no simple overview of project fitness can be had. A bug tracker lets new users/devs quickly figure out how a project is moving, and get an idea of which kind of improvements are considered important by the core team. – naught101 Mar 30 '13 at 12:49
  • Greg Kroah-Hartman has a take on this as it relates to the Linux Kernel as [part of this discussion](http://www.reddit.com/r/linux/comments/2ny1lz/im_greg_kroahhartman_linux_kernel_developer_ama/cmi1wp9?context=10). In particular: *"There is* NO *way the github/gerrit/gitorious model would work at all for the kernel. The scale at which we work is a totally different level than could be handled by those tools. ... There really is no other known way to handle 10000 patches every 2 months, in a stable release, with peer review, with over 3000 developers, other than what we do today."* – naught101 Dec 10 '14 at 04:17
    Another big example I just came across is PyQt https://www.riverbankcomputing.com/mailman/listinfo/pyqt Which led me to google and find this question... I find it insane that any big project in 2020 would not have an issue tracker. I get Github issues on my own project related to PyQt bugs and I need to close them ask people to write an email and have no clue whether their bug is already a known issue or not and can't search for it unless I download and unpack Gzip'd text from archived emails for every month. – pyjamas Oct 28 '20 at 04:50
The preference you observe looks like a natural consequence of recommendation clearly stated in GNU Coding Standards. It suggests to report bugs by email, as you can see in below quote (I marked bold the part that directly addresses your observations):
4.7.2 --help
The standard --help option should output brief documentation for how to invoke the program, on standard output, then exit successfully. Other options and arguments should be ignored once this is seen, and the program should not perform its normal function.
Near the end of the ‘--help’ option’s output, please place lines giving the email address for bug reports, the package’s home page (normally ‘http://www.gnu.org/software/pkg’, and the general page for help using GNU programs. The format should be like this:
    Report bugs to: mailing-address
    pkg home page: <http://www.gnu.org/software/pkg/>
    General help using GNU software: <http://www.gnu.org/gethelp/>
It is ok to mention other appropriate mailing lists and web pages.
Above preference, in turn, reflects universal acceptance of email as a form of electronic communication. Any user reading --help message like suggested above is supposed to easily understand what to do if they see a bug - mailing is easy.
Issue tracker might be (and I think is) better for a developer working in the project, but for a wider audience it would be harder to present and explain how to use it, especially taking into account wide variety and differences between different issue tracking systems.
One project can use Bugzilla, another will stick with JIRA, third with... GNATS, etc etc, etc. There's just no way to present all this "zoo" in a way that would be as standard and uniform as
Note above doesn't mean that projects shouldn't be using issue tracker internally. As explained in an excellent answer to related question,
Your bug tracker is for your convenience, not your customers'. If you can't be bothered to take their phone or email issue and enter it yourself, how do you think they feel?
You need to be able to enter issues and assign them manually to a client...
gnat
  • 21,442
  • 112
  • 288
    Great answer! Email is better known than issue trackers, and easier to understand (which is not to say everyone "gets" email :P ) – Andres F. Mar 26 '13 at 15:59
    Also, that GNU advice is ancient, **way** older than the web and web-based issue trackers. – Ross Patterson Mar 27 '13 at 00:24
  • @RossPatterson I was thinking that. But it seems unlikely that it's older than the web, considering it contains a bunch of URLs... – naught101 Mar 30 '13 at 12:56
    @gnat: A major part of that linked answer being so great is the *"if it's easy for you, you can enter that sort of thing right there"* part. That is key to many open source projects, as there is no funding for phone support. A mailing list is a turn-off for me as a bug-reporting user, as I don't want to have to sign up for responses. With a bug tracker, I can see that the issue I have is in the system, and can come back and search for it later, and see if it's been updated. This is difficult with a mailing list, unless there is a really good web-based list tracker, which often isn't the case. – naught101 Mar 30 '13 at 13:08
    @naught101 It might not be older than the Web but it's definitely older than Web-based trackers – sakisk Oct 16 '13 at 14:11
  • I can quickly send a mail, but don't want to sign-up for a web based bug tracker. – chris Dec 31 '15 at 17:54
    @chris for the matters of issue tracking, mail is [not really convenient](http://programmers.stackexchange.com/a/149146/31260 "as discussed eg here")... "in the mail you sent us two months ago, you mentioned... no not that email, you sent us five emails this day, three of them were with subject _Re: blue button click_, look at the second one, the one with 10Mb screen shot attached to it... what? you can't find it?" – gnat Dec 31 '15 at 18:40
31
With Git, in particular, there is a simple historic reason: Git was started by Linux hackers for Linux hackers, and it uses the same development model and tools as Linux itself does. Linux, however, is older than the WWW, so, when Linux was started there simply were no web-based issue trackers, because there was no web!
As a consequence, the Linux community has developed extremely efficient tools and workflows for dealing with bug reports and code reviews over email, and there was no reason for them to throw all of that work away and start from scratch when they started the Git project.
Jörg W Mittag
  • 101,921
  • 218
  • 318
    I thought that the WWW preceded Linux. Slightly. They were both very much done at about the same time and by different groups of people; it wasn't really until the mid '90s that either took off. – Donal Fellows Mar 26 '13 at 11:17
    Ok, but the linux kernel now has a bug tracker: https://bugzilla.kernel.org/. Clearly that's not such a large barrier. – naught101 Mar 26 '13 at 11:22
    But that bugtracker is maintained by volunteers outside of the core kernel hackers who enter bugreports from the mailing lists. Conversely, bugs entered directly into the bug tracker are automatically forwarded to the mailing lists, because a lot of the core kernel hackers don't even look at the bug tracker. – Jörg W Mittag Mar 26 '13 at 13:05
    +1, beyond linux many big old projects -- and even internet organizations like the IETF -- are built around mail lists. Or really newsgroups which feel more like mailing lists than online communities. – Wyatt Barnett Mar 26 '13 at 15:33
18
For Git:
There are several discussions on the mailing list where people propose to use some kind of bug tracker. These initiatives seem all to have fizzled, so the reason Git does not uses a bug tracker is probably simply that most contributors do not find it useful.
In a post to the mailing list, Junio C Hamano (Git's maintainer) summed up why he feels a bug tracker is not very useful. I don't want to include the whole post (it's quite long), but it boils down to:
  • If you are only looking for information on solved problems, searching the list archives works just as well as searching a bug tracker.
  • If you report a genuine bug, and people want to take care of it, the list also works well.
  • If no one is interested in working on a problem, it will fall through the cracks, even in a bug tracker.
  • A bug tracker would be one more system that needs to be maintained, checked for new bugs regularly, have fixed bugs closed etc., in short, extra work for little benefit.
sleske
  • 10,095
  • 44
    Good answer, but I would argue that your 3rd point is a major disadvantage of email: If a bug is hard to fix and the current devs are lazy it gets significantly more buried than an entry in an issue tracker. This could mean certain bugs are never fixed, simply because people don't know their there – TheLQ Mar 28 '13 at 08:32
    @TheLQ: True. However, apparently that's a risk some projects are willing to take. And to be fair, git is a fairly solid piece of software, even without a bug tracker. – sleske Apr 22 '13 at 08:47
    @TheLQ: Wouldn't a simple web page mentioning all known bugs (And their related threads) resolve that? Something similar [to this](https://www.mozilla.org/security/known-vulnerabilities/firefox.html) except that links point to archive threads. – Hello World Sep 17 '14 at 06:21
    @HelloWorld: Well, that would be a (simple) issue tracker. And just like an issue tracker, someone would have to manage it... – sleske Sep 17 '14 at 07:32
  • Is there a good way to get an offline copy of the email that was sent out while I wasn't a subscriber, though? – Petr Skocik Feb 26 '19 at 20:50
  • @PSkocik: Hi! Please don't ask questions in comments. Ask a new question instead :-). – sleske Feb 26 '19 at 22:12
Debian does use a bug tracker, its default interface is email. And it is convenient. Lucas Nussbaum, current Debian Project Leader, posted a few days ago:
debbugs is the piece of software behind the Debian Bugs Tracking System (BTS). It is also used by the GNU project. Despite often being perceived as old-style, it features several unique features, such as the tracking of the status of bugs in each version and branch of a package ), or the ability to perform all interactions via email, making it very easy to work offline or in poorly-connected environments.
The last part is a killer feature here - just queue those reports in your local mail queue until you got off the plane!
gnat
  • 21,442
  • 112
  • 288
Dominik George
  • 170
  • Keeps 9 year olds out.
  • No need to create a separate account for each forum.
  • [minor]Consistent user experience across different mailing lists and a zero learning curve when subscribing to a new list.
  • Works offline. you could connect to the Internet and download a batch of mails, then go hiking, write your replies while enjoying mother nature and send them later.
  • Allows mail encrypting and/or signing via GPG.
  • Decentralized - If the forum crashes, you'd still have a copy, it's also tamper resistant, an evil moderator/hacker cannot easily tamper with what you've said. No one can undo history.
  • Allows filters, folders, and all the advanced organizational features of an Email client.
  • "Push notifications" - you can leave your Email client open and get notifications of new replies.
  • One place to rule them all - no need to jump between different sites.
  • Immune to all the security vulnerabilities involving the web (html/javascript/injections, etc)
  • No bloat - No badges, fancy moving signatures, ads, web beacons, javascript bloat. It's all simple and to the point - discussion.
  • Less server burden than a LAMP setup.
One disadvantage of mailing lists that comes to mind is that forums are dividable into categories and subcategories while mailing lists are not. This can be emulated by dividing a mailing list into several mailing lists, and then users can use the appropriate filters to put each message with its corresponding folder (Each folder being a category). In web forums, this is automatic.
Hello World
  • 184
  • why do people insist on creating web based versions to track issues (BTW this question is not about _everything_) is discussed in another question: [Getting users to write decent and useful bug reports](http://programmers.stackexchange.com/a/149146/31260) "User-editable online bug reports are the most efficient way to teach users improve..." – gnat Sep 17 '14 at 06:51
  • Thank you. But does this justify a downvote? The main topic of this answer is the advantages of a ML, and it answers the original question rather well. I have removed the "web forums" rant. – Hello World Sep 17 '14 at 07:01
  • Note: I used "web forums" and "web based issue trackers" interchangeably because the answer is suitable for both. – Hello World Sep 17 '14 at 17:16
    The disadvantage mentioned in this answer actually fundamentally precludes me from sticking with most dev mail lists. They send through *everything*, so after reporting a bug I usually unsubscribe a mere two weeks later. Bugtrackers nicely solve this problem by letting me subscribe to specific bug reports. – Roman Starkov May 10 '15 at 00:28
    Correction: keeps **25** year olds out. Only recently did I learn how those mailing lists things work to contribute to some *real* projects. And I hate it!! – Ciro Santilli OurBigBook.com Jul 31 '15 at 11:16
    "No need to create a separate account for each forum." - often to prevent spam you need to sign up for list. But that subscribes to all emails. So you need to subscribe AND opt out from 'spam' AND add request to keep you in CC or TO. Compared with a bugzilla it's much more to do. – Maciej Piechotka Oct 19 '17 at 18:44
